Dash not coming on?
Discussion in 'Gen 2 Prius Technical Discussion' started by KitsuneVoss, Jan 2, 2024.
  1. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I am sure this has been covered before but did not find anything in my searching.
    My personal car is a 2009 Prius and had trouble last night getting the dash to come on. The usual tricks did not work. I don't know what I did but after five minutes or so was able to get it to come on.
    My understanding is that it is almost always a certain 100 microfarad capacitor which Toyota now replaces with a new instrument cluster with a 220 microfarad capacitor in that place. There are multiple videos online of people either replacing the original capacitor or piggybacking a second one.
    I went ahead and ordered a set of five 220 microfarad 16 volt volt capacitors from Amazon. They are like $6. I was taught to solder 35 years ago but have never soldered since and am concerned that I cannot do it safely. Looking up online "electronics repair", you get repair of computers and cell phone screen repair. Most just do component replacement.
    Any suggestions on what to look for? Who could do the work?
    Also how much does Toyota charge for replacing the whole board?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    donbright likes this.
  3. Buckinghambob
    Buckinghambob Junior Member
    23
    Virginia
    52,878
    you could look for an electronics repair service, computers, etc.
    toyota gets around a grand for labor, but i don't think they will repair it, just put in a new one.
    if you buy a rebuilt, most places still want close to a grand due to the compexity of removal and replacement.
  5. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Your post is empty
  6. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    That is not a bad idea actually. It is not that much money and allows me to retain mine until I can get a replacement.
    Waiting for a couple of payment first unless it gets to the stage of not working at ll.
  7. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I will likely pull the board myself and then replace it. There are quite a number of videos showing how it is done. Just need to disconnect the 12 v first I assume?
  8. Buckinghambob
    23
    Virginia
    The real issue/expense with the cap repair is taking out the dashboard, guessing you'd spend a couple hundred on that alone.
    The cap replacement seems pretty straight forward, use a low temperature iron, and do a couple test runs first. One trick I saw was crushing the old cap with pliers while it's still on the board, that greatly speeds removal of the wires left over and replacement with the new cap much easier.
    also, it looks like ebay has some sellers doing the repair,you send in your board, and they replace it about 40$, but again, you still have the dash to remove and then reinstall
  9. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    I have found a number of videos on YouTube and while removing ti looks like a bit of a pain, it does not look impossible.
  10. CombinationMeterChris
    CombinationMeterChris Junior Member
    Los Angeles
    Yes, it is just time consuming and removing the dash vents without breaking them is tricky. I do this service for people in Southern California for $150 total if I remove the dash and $50 if they bring me the combination meter but it looks like you are on the east coast. Yes, disconnect the negative terminal of the 12v battery before you start as you will be disconnecting the passenger side airbag when you remove the dash. You can just grab the old capacitor with pliers and twist and it will break off at the solder points. Just make sure the negative side of the new capacitor is facing toward you (away from the cluster display)
  11. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    Just lots of small steps to the process. Take pics of everything, esp all electrical connectors. Nothing is more of a pain than to get it all back together then realize you overlooked a plug then have to pull things apart again.
    I would also recommend subbing the board repair out. Not that difficult, but you don't want to be practicing on a part you can't easily do without if mistakes are made.
  12. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    My semi-debate is that my dash is still working. Seems a lot of work while the usual tricks still work. I guess I will see the next time it happens. At least I have a bookmark of a seller who will ship you a replacement display for minimal down time.
  13. ChapmanF
    19,042
    I only played that game with my washing machine for about a week before I bit the bullet and changed that capacitor. Way too annoying to play games with it.
    Of course the game I really hated was the one where it lost its place midway through the cycle and left me a load of soggy sudsy clothes.
  14. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    Where are you in Virginia?
  15. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    Gloucester. I can drive anywhere in Virginia if it would help.
    I am sorry, I was gone for a while because my sister died and had to go up to New Hampshire for her wake and deal with other issues involving her. .
    #15 KitsuneVoss, Jan 21, 2024
  16. Carall
    316
    104
    Harrisonburg, VA
    You are about 3 hours away from me. I could only help with repairing the сombination meter at this time.
    The dash vent with the parking button must be warmed up before removing. If prius is from the hot sunny south they break like potato chips.
    CPate2020 and donbright like this.
  17. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    So run an electric heater in the car for a while? Wait until summer and park it in the sun?
  18. Carall
    316
    104
    Harrisonburg, VA
    The cheapest Harbor Freight heat gun does it all. In order to do this you'll need a warm garage or warmer days.
  19. KitsuneVoss
    KitsuneVoss Member
    376
    55
    Virginia
    So I need to use a heat gun where the silver trim where the vent and parking button is? Just heat it up so it is softer?
  20. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I had a similar issue on mine and I usually just disconnect the battery for 1 minute then reconnect it and dash works all over again. I heard its a sign of a failing combo meter
