Dash not coming on?
Discussion in 'Gen 2 Prius Technical Discussion' started by KitsuneVoss, Jan 2, 2024.
  1. donbright
    donbright Active Member
    241
    151
    33
    oklahoma
    The AC vents are not guaranteed to be saved by being careful or using heat guns, its about chemistry of plastic and environmental conditions. Around here, about 1 out of 20 Prius in the junkyard have an AC vent that is in tact and the one i got was a 2005 so it didnt fit my 2007 without modification. One in particular I pulled out of the junk car, laid it down on the ground, turned around, and when i turned back it had cracked apart right there on the ground.
    You can get replacements pretty reasonable on Ebay these days .
    CPate2020 likes this.
  2. KitsuneVoss
    KitsuneVoss Member
    373
    55
    Virginia
    Are you talking about the vent itself or the molding around the vent?
    ir: This?
    For Toyota Prius 2004-2009 Left+Right Center Inner A/C Dash Air Vent Cover Trim | eBay
    donbright likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    Yes, those. They are made from plastic that's about the thickness of a potato chip, and after enough years in the sun they are just as brittle.
