Dash radio white tint
Discussion in 'Gen 3 Prius Main Forum' started by priusbeachmax, Jan 23, 2017.
  1. priusbeachmax
    priusbeachmax Junior Member
    San Diego, Ca
    My dash radio display has a white tint when I start the car and then for the first few minutes. Then it is back to normal Any ideas?
    52,878
    that's a new one. how long has it been doing it, have you owned it since new? maybe pull the fuse for a minute or two.
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    It could be a moisture problem. Has the car had any history of a windshield replacement that may be cause for a leak. It could also be a bad circuit board in the radio causing low voltage to the screen (bad capacitor)
  4. James Analytic
    415
    63
    Michigan
    Following up to see if you found any causation and what your course of action was. Any updates? I took a photo today and decided I'd try to touch bases with anyone else experiencing and what was done.
    I've wondered the same and maybe some sort of connection that has some sort of expansion contraction connection issue or part sensitive to moisture content. I just posted my latest image regarding in a few post threads.
