Dash Rattle and Vibration Noise
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Benjamin Pon, Dec 21, 2023.
  1. Benjamin Pon
    Benjamin Pon New Member
    Tennessee
    2023 Prius
    Hello, I've been trying to troubleshoot a rattling or vibrating noise in the right passenger side dash of my 2023 Prius. I've tried to find exactly where the noise is coming from but haven't been able to pinpoint it. I'm curious to know if anyone else has heard this rattling noise and if there is anything that can be done to stop it? It might seem like a minor issue but it gets annoying when it's quiet in the car and all you hear is that noise. I've heard it when it's cold outside and hot outside and mainly hear it on rougher roads but also hear it while driving on the freeway. It seems like this could be an issue of plastics barely vibrating against each other but don't know for sure.
    I had a similar issue in a Camry I owned previously but couldn't find a way to stop it. This seems to be a Toyota problem.
    Below is a link to a video I recorded of the rattling or vibrating noise. I'm hoping someone can help pinpoint where it could be coming from and to find a solution to stop the noise. I'm hoping it's as simple as putting some padding or tape down to stop the noise but would like input from the community if anyone else has had this problem. Thank you!
    ptweezy likes this.
  2. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    I couldn't hear anything on the video, but have you checked if it's coming from your glovebox. You might try emptying it or rearranging the items and see if the noise disappears or changes.
  3. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    If you ever have passengers in the front passenger seat, check that the seat belt buckle is not twisted and rattling up against the pillar. That may sound like it's coming from the right front dash.
    daisy555 and soft_r like this.
  4. Hammersmith
    Hammersmith Senior Member
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I can't hear the rattle in your recording, but I wonder if it's the same as mine. I've got one that's on the driver's side. Sounds like two pieces of plastic just barely rattling(almost buzzing) against each other but only in a particular set of conditions. I can only hear it in EV with everything off(radio, HVAC, windy day, etc). Even the ICE at idle tends to cover it up. It's not linked to any specific action(acceleration, braking, terrain), so I think it's a form of sympathetic vibration. I can almost reproduce it at will; I succeed maybe 75% of the time when I try. But I haven't been able to pinpoint it beyond "somewhere inside the dash"
    I've considered taking it in, but I'm afraid the dealership would have to rip apart the dash to try and find it, and I could end up with them not fixing it and adding even more rattles if clips, tabs, or slots get broken during the work. Plus I can't really be without the car for the multiple days it would likely take them to try and find it/fix it. I think I've decided to just live with it and just turn on the radio or something when it gets annoying. Thankfully you can't hear it at highway speeds, so that's not an issue.
    If I ever decide to do the ambient light color swap from blue to red, I'll probably try to find and fix it myself since I'll have to disassemble a big chunk of the dash anyway.
  5. Benjamin Pon
    Tennessee
    2023 Prius
    I tried a couple months ago but will try again. I don't think it's near the glovebox though. The sound seems like it's coming from the top of the dash near where it meets the windshield. I appreciate the suggestion.
    Definitely a good thought. I've tried looking at the seatbelt and it doesn't seem to be coming from there. I've been able to hold the seatbelt so it's not touching anything and I am still able to hear the rattle near the top of the dashboard. I appreciate the suggestion.
    Yes, it sounds exactly like two pieces of plastic barely touching each other and creating the noise. Like you said almost creating a buzzing sound. I don't hear it on the driver side like you mentioned but I imagine it's the same type of thing occurring on the right side of the dashboard for me. I've also considered taking it in and having them look at it but I don't trust they'll do a great job at searching for it. If you do eventually do an ambient light color swap and happen to find any solution with the noise, I'd love to hear about it. Thanks.
    #5 Benjamin Pon, Dec 22, 2023
  6. bisco
    52,863
    the dealer might have to pull the whole dash apart to find it, then you might have even more rattles after they reassemble it
  7. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    I had a very similar buzz on my Gen 4 and I traced it down to the speaker grill on top of the dash. I took the grille off and put a little foam padding in, replaced the cover and it disappeared.
    It's a bit of a stretch, but if you can get a passenger to reach forward and press down on the grill to see if that stops it, if so try the above.
    daisy555 likes this.
  8. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Rattles are "tough".
    FWIW Sometimes one thinks the rattle is at the right front and it is actually at the left rear.
    Just perhaps it is not in the interior but in the wheel well/ liner or undercarriage...there are plastic panels with push-in retainers in those two areas.
    Some good advice is driving with a passenger who can apply pressure here and there and listen around.
    That's the first step, find the area that is rattling.
    There are tools for rattle locating including a stethoscope (inexpensive) and electrical (expensive).
    If you could vibrate the car, I not so how to accomplish that, in the garage creating the rattle and fit yourself under the dash to poke around, well, that could help isolate the rattle greatly.
    Lastly, I could agree dash disassembly could create more issues.
    If this avenue is chosen, I would DIY as I have great hesitancy of shop labor and flat rate taking quality assembly time.
    Foam, Velcro, felt, and double-sided stick tape are you friends :)
    Wishing you the best of luck.
    Rattles suck :(
    PS Let us know what you find.
  9. Schize
    Schize Junior Member
    United States
    2023 Prius Prime
    XSE
    I have a 2023 prime, and I think we might have a similar rattle. I hear the same buzzing noise that sounds like two pieces of plastic just hitting each other, or maybe a thin piece of metal vibrating in the open. Mine is pretty audible from the drivers seat, and sounds like it could be coming from either the cover for the forward recognition (behind the rear view mirror) or from the center dash behind the infotainment. I've tried to apply felt tape around the forward recognition cover to no avail - I did remove and replace that early on in order to use an adapter to power a dashcam, but I don't see visibly damaged clips, and applying pressure while the vehicle is in motion doesn't prevent the rattle. When in the driver's seat I hear it on my right, and the left when in passenger, so we're fairly certain it's at least bouncing in from the center, if not originating.
    I'm also hesitant to take it to a dealer, as it's possible it's not a covered defect, which would be expensive and potentially not even a solution. My rattle rears it's head on textured roads, is loudly audible over other road noise, the ICE, and even the radio at like 20-30 volume.
    My next steps are probably to remove my dashcam and see if that's the cause of the rattle.
  10. Benjamin Pon
    Tennessee
    2023 Prius
    Yep, that's true about the sound possibly coming from a different spot in the car based on where you're sitting. I haven't been able to have someone drive it while I'm in the passenger seat but I'm going to try that soon to see if I can pinpoint it. Hope to find some kind of solution!
  11. Benjamin Pon
    Tennessee
    2023 Prius
    That's exactly what it sounds like. I haven't been able to sit in the passenger seat while someone else drives but hoping to do that soon. I've tried reaching and softly pushing down on the dash as I'm driving while I hear the sound but can't seem to find it. Maybe it's just based on where I'm sitting but it really sounds like it's coming from the right dash where it meets the windshield or the right speaker up at the top near the windshield. I'm going to work on it this weekend to see if I can find it. It definitely seems like now that the weather is colder I'm hearing the noise more frequently. Let me know if you find anything on your end!
  12. ken2023
    ken2023 Member
    71
    56
    new jersey
    2023 Prius Prime
    XSE Premium
    You can sometimes locate these more easily with a stethescope, by placing it on parts you think are generating the noise. Inside the engine compartment, there are "mechanics" stethescopes with a long metal probe you can hold against them, but for the interior a normal stethescope is probably better. And would get into the passenger side and move it around to help locate. I've found the car has a lot of rattles and creaking noises. Although yours might be more severe. The difference between a 60-70K car and a 40K car, and cheaper interior compared to a Lexus, Volvo, etc. So just imagine every rattle is the sound of a pennies dropping into jar as you save money on the cheap interior.
  13. priusdriver223
    84
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, I have experienced this rattle sound quite a bit in the beginning of my ownership, but recently (4 months in) I have noticed it has almost went away. From my experience, my rattle was specifically coming from the front left corner on the dash, at first I thought it was my loose temporary registration but later found out that wasn't the issue. As the noise went away, I simply stopped researching about this rattle but I do wish you a good luck and will keep track of this post. Cheers!
  14. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    I've also had a plastic rattle sound and I've narrowed it down to the 3 pieces of plastic behind the rearview mirror. They cover the mirrors mount to the windshield and alternate rattling depending on which one I've nudged back into place. Seems like there's always one of them loose that rattles loudly at higher speed and/or rough roads. I haven't installed a dashcam or removed those covers at all. I hesitate to remove them completely for further troubleshooting - I don't want to make it worse by breaking anything.
    Can any of you confirm that's the same place you have a rattle?
  15. Benjamin Pon
    Tennessee
    2023 Prius
    It's definitely possible the rattle is coming from the mirror area. I haven't been able to confirm where exactly the noise is coming from but will try to see if it's coming from the mirror area or not. I've tried to record a video with my iPhone to try to pinpoint where the noise is coming from in the video because I move the phone around the car as I'm recording. But it can be hard to hear it when you play back the video on the phone.
  16. Schize
    United States
    2023 Prius Prime
    XSE
    I initially thought this was my issue, but it's not likely to be the main cause for my vehicle. I did an extensive test over the past weekend - sat in the passenger seat with a stethoscope while someone else repeatedly drove back and forth over a stretch of road that has just the right texture to cause the vibrations.
    My rattle has a persistent buzzing over some roads, annoyingly including a textured part of my daily commute. There is a second, much louder rattle/buzz that is accompanied by some bigger bumps in the road, like connecting parts of asphalt, some potholes, rapid deceleration on a textured road, etc. This louder rattle sounds like it comes from multiple parts of the dash/car at once, while the primary rattle seems more localized.
    • Main rattle wasn't coming from the plastic cover behind the rearview mirror (forward cognition cover). I did remove this to install a dashcam, but have since went and lined every piece of plastic that touches something else (other than the latches) on the cover and smaller panel with foam tape. The primary rattle is still present even with the entire cover fully removed, though I wouldn't rule out it contributing the louder second type of rattle.
    • With the stethoscope, I've noticed the following parts seem to present the most rattle/noise that closely matches the audible rattle:
      • Passenger side door, particularly near the armrest
      • The retention clips for the sun visor on both the driver and passenger sides
      • The steering wheel column
    If I unlatch the sun visors, a lot of the primary rattle becomes almost imperceptible. The second type of rattle is still present, though maybe just slightly subdued. I'm guessing certain types of road texture/vibration travel up through the car, including up above to the roof and through the clips for the sun visor latch. When connected, the sun visor acts as an amplifier for the vibrations. More powerful vibrations caused by deceleration, bumps in the road, etc. travel through all the potential rattle spots.
    For now, I'm probably going to leave the sun visor unlatched - I'm not sure if foam tape would hold up on the latch, as I swivel the visor around relatively frequently. Perhaps there's some other product that could dampen the vibrations while not impeding the function of the visor? I can't imagine this rattle is unique to this car. For the louder "surround sound" style rattle, I might just have to deal with it - it's probably multiple interior panels/components, and I'm hesitant to know if this would even be covered in any sort of year 1-warranty. Maybe it's worth a shot?
    Maybe you guys can give this a shot and see if you notice any difference with the visors latched/unlatched?
  17. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I think I found my rattle/buzzing, but those of you with the same problem are not going to like the fix.
    In my car, it appears to be a relay deep behind the dash, bolted to the body.
    I have my dash out for my mirror and lighting upgrades, and I could hear it more clearly. I drove around to make the rattle, then poked at different things with a stick until the rattle stopped.
    The nut holding the relay bracket was pretty tight, but I was able to give it a little more with a wrench. I'll be driving around for another week without the dash, so that should be enough to see if it's fixed or not.
    The pic is the drivers side, just below the windshield. The relay is straight below the dash speaker, but you can't access it that way as parts of the dash pad are in between. 20240606_112606.jpg
    SM-S901U ?
    Kenny94945 likes this.
  18. Hammersmith
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The "fix" only lasted a couple days. I'm going to have to investigate further before putting the dash back together.
    My current theory involves that little bit of play where the tab on the bracket(metal) goes into the body(red). When you tighten the nut, the bracket rotates clockwise as much as it can before the tab hits metal. I'm thinking it eventually vibrates back just enough to start a rattle between the two parts.
    My next attempt at a fix will probably be to put something soft on both sides of the tab to see if that prevents the rattle. The other likely culprit is the interface between the bracket and the relay. I also need to check the back side of the relay to see if something is touching it back there.
  19. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Given where you're at, how about relaxing with a noob-level question?
    I think I've got an "easy" rattle from one of the dash surface parts - the slightest pressure on it mutes it, so I fancied putting a little padding in there - but I'm stuck on how to remove it. Step 1 of dash disassembly failed.
    It seems like it should be straightforward, but I've not detected any inclination to move, and I'm reluctant to apply too much force.
    I was initially thinking the instructions were implying that just pulling forwards would be sufficient - but should I be doing something specific to disengage clip latches?
    Any chance of a photo of this part and how it secures?
  20. ptweezy
    ptweezy Junior Member
    North Carolina
    2023 Prius
    XLE AWD-e
    I am so glad you posted this because I thought people would think I was crazy if I posted. I have been dealing with this since I got my 2023 Prius AWD. It drove me absolutely nuts but I've gotten mentally used to it almost. Weirdly enough it seems to get worse when its cold??
    Anyway...I am desperate also for a fix for this. I have this hunch it's part of the glove box assembly.
