Dash vent trim
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thomas Rose, Jun 17, 2022.
  1. Thomas Rose
    Thomas Rose New Member
    Clearlake, CA
    I am putting in a replacement stereo in my 2004 Prius which involves removing much of the dashboard including the trim around the dash vents. Unfortunately, due to either my excessive force, or the deterioration of 18 year old plastic (car sat outside in the California sun for its whole life), three of the vent trim pieces broke. I have been able to find replacements for some, but not all of the vent trim pieces. Does anyone have a good source for vent trim replacements? If no one has a source for new vent trim, I will try a junk yard, but I assume their vent trim pieces will be as brittle as mine.
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Check the thread linked by @Another. The vent covers from Toyota are pretty dear. The Amazon ones are much cheaper. You will probably notice that, with the aftermarket ones, the dash panel behind the steering wheel doesn't fit quite perfectly agains the new left center trim, but it's better than a broken or missing trim.
    These things get unbelievably brittle over the years. Example The other day, I replaced the MFD on an '08 and the two center trims were both already cracked. (Those two are usually the worst.) I managed to get them off and back on without further damage. Takes lots of patience. Then I saw that, in my excitement over not breaking the trim, I forgot to reinstall the two 10mm screws that secure the MFD. I got them out again without further damage. As I held one of them in one had getting ready to put it back in, it fell into three pieces just under its own weight.
  4. PriusCamper
    PriusCamper Senior Member
    11,089
    4,512
    Pacific Northwest, USA
    Most soldering gun kits come with a plastic melting attachment... Simply melting the broken plastic tabs back in place is least expensive way to fix this.
  5. Thomas Rose
    Clearlake, CA
    Thank you for the suggestions and the link to the earlier post on this subject (I tried searching "dash vent trim" and found a lot of other posts, but not that one). I found some replacement vent trim pieces on eBay. Used and kinda spendy, but I can't run around with broken trim pieces for long.
