Dashboard Clock versus Navigation Clock
Discussion in 'Prime Main Forum (2017-2022)' started by Captmiddy, Jan 3, 2017.
  1. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Unless I am missing something, which wouldn't surprise me in the least, I find it annoying that the two clocks do not sync with each other and that you must manually set the Dashboard Clock. I was somewhat excited when I found clock settings in the navigation screens but annoyed when I noticed it didn't set the dashboard clock which my dealership didn't think to fix before delivering the car to me. Honestly, this was probably a good thing because it would have annoyed me more later than it does right now, as I am sure the clock will drift and at least now I know they aren't in sync rather then thinking they are and finding issues between the two and trying it figure out which button or gadget to monkey with to fix it.
    So am I missing something? Should the dashboard clock be able to be synced with GPS? The manual is pretty skimpy on explaining the dashboard functions.
    52,891
    it never has before. although, i'm pretty sure my nav doesn't have time.
  3. Pizza Driver
    Pizza Driver Active Member
    158
    156
    United States
    What's got your nav so busy that it can't spare a millisecond of its precious time to update the dash clock? ;)
  4. Captmiddy
    225
    204
    Massachusetts
    Perhaps I should clarify, when I say Navigation Clock I should specify that this clock is used for destination time estimates and for the charging calendar features. It is GPS set and can auto adjust to time zones. The Dashboard clock is up in the upper display to the right of the speedometer in with the warning lights. If you allow the navigation clock to adjust by position you will see things like the time to reach a place being off by an hour if you cross timezones because the navigation system will adjust but your display will not. The navigation clock isn't a display clock as far as I can tell, it just manages things like internal calendars in navigation time details. It is also helpful for time of day navigation information which are somewhat predictive and are based on past time of day details.
    That said, it is annoying that such a high tech car doesn't use the very simply time data contained within the navigation feed. Honda vehicles that have navigation have (at least in my experience) set the system clock from this information (at least since 2005 and probably well before).
  5. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Ever since the daylight savings time change I'm having a similar issue and it's kinda annoying.
    My dash clock is correct, but my GPS "time to arrive at destination" is an hour off, just like it never updated from the time change!?
    Does anyone know how to update this GPS "clock"? I sure as heck can't figure it out...
    Thx.
  6. Captmiddy
    225
    204
    Massachusetts
    On the Navigation system, click Settings, then General Settings then System Time. There are three options to adjust within this panel, Timezone, Daylight Savings and GPS Auto Adjust. What is interesting is that the system documentation doesn't tell you if it automatically adjust to daylight savings time on its own with GPS Auto Adjust set. Having not owned the vehicle through a time change yet, I don't know what it will do.
    priuscatprimeguy likes this.
  7. bisco
    52,891
    gotcha. so my nav must have an internal clock? either way, the dash clock loses a minute or two a month, and i have to reset it manually.
    hopefully prime has fixed all that! (but i don't it, there isn't much high tech going on with entune)
  8. liskipper
    liskipper Member
    374
    79
    Long Island, NY
    The navigation time comes from the satellite, which has an on board atomic clock.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    So Liskipper, I also am frustrated with this clock set. Have you found the procedure?
  10. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    They don't sync. and can't be set to sync. Maybe one day the engineers at Toyota will put it in the standard. They don't actually make either the GPS or the clock.
    All GPS units know the time to nano-seconds. They can even adjust for timezones if the manufacturer bothered. And daylight savings too! What a concept!
    Some parts of our cars are still stuck in the 20th century. ;)
    Data Daedalus and Bluegrassman like this.
  11. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    The system doesn't know it's DST. You have to manually set it twice a year.
    iPhone ? Pro
  12. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Hopefully soon they will just forget about DST altogether so we dont have to deal with this each year.
    Mendel Leisk and Andyprius1 like this.
  13. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    I wish we changed more often.
  14. Prodigyplace
    12,720
    11,852
    Central Virginia
    Here at work, we use time servers that get their accurate time from GPS. Ideally you should just need to set Timezone & DST values.
  15. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    If we did not have DST how would we know when to change the batteries in our smoke alarms?
    Since2002 likes this.
  16. Prodigyplace
    12,720
    11,852
    Central Virginia
    Mine "chirp" and flash their light when low...
  17. jbhybrid
    jbhybrid Junior Member
    16
    On my new Prime, the dash clock is correct (PST, for SF Bay Area), but the navigation screen clock shows expected arrival times 1 hour late. If it thought daylight savings time was in effect, it would be 1 hour early. Obviously the GPS knows both the actual time and the geographic time zone, so I'm surprised such a high-tech machine can't connect the dots, or make the two clocks agree. I also wonder if the navigation system is making proper use of real time traffic updates, when it doesn't know the real time.
  18. Lee Jay
    5,850
    4,036
    Extracting time zone from a geographic location turns out to be a way harder problem than it sounds like it would be.
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    With the PiP, the calendar skips one full day every 4 years! It does not recognize February 29th. Somehow I feel the Prime calendar is the same - let's wait to 2020.
    #19 giora, Feb 24, 2017
  20. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Cars have gotten so automated nowadays, they needed to give the driver something to do to feel involved so they still let us set the dash clock.
