Dashboard Clock versus Navigation Clock
Discussion in 'Prime Main Forum (2017-2022)' started by Captmiddy, Jan 3, 2017.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I just bought a new Tacoma. The timezone and daylight savings time sets automatically from the GPS. On the Prime, not. Weird.
    albus and sonomac like this.
  2. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    Clocks will all have to change again in a few weeks.
    Data Daedalus likes this.
  3. nanobozho
    nanobozho Member
    61
    38
    desplaines, il
    we just went thru a time change last weekend, and the nav time is now off an hour...
    ok, this worked, just selected daylight savings along with gps auto and it is now correct... interesting that gps auto would not get it right by itself... but whatever works...
    #23 nanobozho, Mar 15, 2018
  4. albus
    albus New Member
    28
    San Jose, CA
    GPS time is oblivious to time zones and even leap seconds, although, as per wikipedia, "... satellite broadcasts include the necessary information to convert GPS time to UTC." And, of course, DST is a political decision anyway... and a pretty fine-grained database would need to be maintained worldwide.
  5. MikeDee
    1,581
    597
    Yeah well my Tacoma adjusts automatically for DST, so why not the Prime?
  6. Prodigyplace
    12,720
    11,852
    Central Virginia
    It sounds like you just need to tell the system that your area uses Daylight Savings Time. Not all areas in a timezone use it.
    The Prime is not (yet) omniscient. :)
  7. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    To put it as simply as possible, GPS satellites essentially broadcast only two pieces of information; the satellite's current location in space and the current UTC time when the transmission was sent. Yes to get into the techie stuff it actually broadcasts current GPS time plus UTC conversion factor, but that's essential saying the same thing.
    At its most basic, all that the GPS receivers do that are built into our phones, our cars, etc. is receive the broadcast signal from four different satellites, and based on the time difference between the four signals calculate the latitude and longitude of the receiver. In fact many early portable GPS devices used by hikers only displayed latitude and longitude on a small LCD display, the hiker then used this information to find their location on a USGS map.
    A modern GPS receiver however also contains a map database, on which it displays the receiver's current position. Or if using Google Maps on a phone it uses an online map database. The GPS receiver's database can (or at least should) contain internal time zone maps as well as information about DST such as the dates for switching and rules for different states/countries. A GPS receiver that cannot automatically adjust for time zone or daylight savings time is pretty weak in my opinion.
  8. albus
    albus New Member
    28
    San Jose, CA
    As you stated, Toyota could indeed maintain such a database and all you said falls within the realm of the technically possible. However, what happens if/when our Indiana friends (no sarcasm intended) decide to switch a county to another time zone and/or on/off DST? Now you get stuck with an obsolete database until you pay (dearly) for a Toyota update.
    Just curious now: given that in Europe the regulations concerning time zones and DST are much more rigid, does the Primes sold there automatically adjust for DST?
  9. Since2002
    936
    1,098
    Duluth, GA
    But only people who live in or drive through those counties would be affected. And actually systems that I have used that have auto DST, you also have the option to manually adjust DST, so the people in those counties wouldn't have to buy a new database if they don't want to, they could manually adjust for DST twice a year, something that currently everyone in the country has to do who owns a Prime even with a current database.
  10. albus
    albus New Member
    28
    San Jose, CA
    You're probably right and I'm being overly picky. And as @MikeDee stated, other Toyotas do have this functionality...
  11. Since2002
    936
    1,098
    Duluth, GA
    I don't think you are being overly picky, it is a problem, but it's one that has affected pretty much all nav systems with built in databases. The answer I think is either free updates like most of the portable GPS units now have, or an online database, which is actually a huge benefit not just for time zones but for everything else. That's one of the huge benefits of Google Maps, so much so that I use it almost exclusively now instead of my Garmin even though I like the Garmin interface better, because it's so important to have up to date data. I hate when I'm traveling and I search for a store or restaurant on my Garmin and drive all the way to it and find out it's no longer there, meanwhile there was probably a new one closer to where I already was. I never have that problem with Google Maps. The only draw back to Google Maps is it doesn't work very well when you lose Internet connection. It allows you to store the current map on your phone, but you have to do that proactively. I wish it would automatically store whatever area I am currently driving, of course it would need a way to set a storage limit, otherwise if you were on a long trip across several states you might fill up your phone's storage.
    albus likes this.
  12. Thump553
    Thump553 Junior Member
    CT
    2020 Prius Prime
    I have this thread bookmarked so twice a year I can look it up to see how to correct this "feature" of Toyota engineering. Fortunately they are way behind the Germans in the frequency of such annoying "features."
  13. ChapmanF
    19,058
    The nav unit used in the 2010 gen 3 (so presumably also 2011) just needs to be told twice a year whether DST is on or off. It's under Setup ➡ Clock.
    In my house, the programmable thermostat happens to know the current rules for when DST comes and goes in (most of ) Indiana, so it doesn't need any attention. because I bought it after 2006, when the rules most recently changed here. (Most of the state had formerly not observed DST at all, which led to people elsewhere saying stuff like "so you're, like, on Eastern time in the winter and Central in the summer?" and we had to keep saying "no, we're just on Eastern Standard all year".)
    People still keep talking about wanting to change the rules again, which will make this thermostat really annoying if it happens. Of course it'll keep springing forward on the second Sunday in March and back on the second Sunday in November, and will have to be corrected on those dates, and corrected again on whatever the new rules say the right dates are.
  14. Mendel Leisk
    42,376
    In the decade or so our central heating’s had a programable thermostat, I’ve never once used it that way, just run it up/down as needed.
  15. BiomedO1
    BiomedO1 Senior Member
    4,638
    2,434
    Left Coast
    Yes, once your retired - your kinda home most of the time. When working, I just program it once and just walk out the door. I've got a newer thermostat that'll automatically adjust for DST. I do have to change the backup batteries every year - It went 3 years before I noticed it suddenly lost programming and the little battery lamp was flashing.:sick::sleep:o_O:cry:
    My neighbor has a fancy internet controlled one. Lasted less than 4 months - software locked up; I had to reset it for them. They were without central heat-n-AC for 2 days. Told them to call the company that installed the system to get that controller software upgraded so it doesn't do that again. Luckily we don't get below freezing very often or this would be dangerous.
    Now I've got to go out and reset the clock on my car....:unsure::whistle::giggle:
