Dashboard direction signal green lights don't work
Discussion in 'Prius c Main Forum' started by CARSFAN4, Jul 15, 2024.
  1. CARSFAN4
    CARSFAN4 Junior Member
    62
    Los Angeles
    2015 Prius c
    At my 2015 Toyota prius c the dashboard direction green lights don't work.
    The other dashboard lights work.
    Outside yellow blinkers don't light up.
    Could be a fuse...or...?
    Anybody can help??
    Thanks
  2. John in Vermont
    John in Vermont Junior Member
    50
    22
    Rochester, Vermont
    2018 Prius c
    Why not check the fuse, it isn't hard to do.
  3. CARSFAN4
    62
    Los Angeles
    2015 Prius c
    I did and I found out that there was no voltage with the switch on contact on. When I replaced it with another one from the horn fuse of same value 10 the green dashboard lights started to flash but in the same time the yellow light for " check hybrid motor" lighted up.
    I didn't have the right fuse size and that's why I took out the horn one.
    After I bought and replaced the right size hazard 10 fuse nothing happened, nor even when I replaced it with a 2nd one from the same box I bought from Autozone.
    My question is: did this happen because I installed a generic fuse instead a Toyota genuine part??
    I don't know who to continue further the diagnostic. Should I buy a Toyota genuine fuse and replace it to see if it helps.??
  4. ChapmanF
    19,019
