Dashboard illuminated with too many warning lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ambrosia5, Jan 13, 2016.
  1. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You should not check across the fuse for voltage, as you did for ohms. Pull the fuse and check from each of the two terminals to chassis ground. One side should read battery voltage (12V +/-), the other side should read zero. If both read zero, there's a problem with the wiring harness upstream and that's what we're looking for.
  2. Ambrosia5
    Ambrosia5 Junior Member
    63
    Colorado
    Oh goodness thank you for telling me! I dont want to mess up anything more than the problems I already have. I will do how you've instructed and post the results.
    Just to be sure
    Red lead to the where the fuse goes (fuse removed of course) and black to the chassis? Should read +/- 12v?
  3. andrewclaus
    993
    326
    Golden, CO
    Yes, that's it. While you're doing that, inspect the fuse and contacts, look for broken and loose contacts as described in an earlier post.
  4. Ambrosia5
    63
    Colorado
    Ok bo
    I retested the 15A dome and got 0 on both sides. What harness is that connected to? I'll be checking the others now.
  5. Ambrosia5
    63
    Colorado
    Just all the other recommended by Patrick Wong except the Power 30A which I cannot find. They all measured 0 on both sides. I find that very odd. I think the power 30A is hidden.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Aha!
    Now we're getting somewhere.
    Dome light is always a good place to start with these types of issues.
  7. Patrick Wong
    18,214
    6,531
    To reiterate, you should have your multimeter set to measure DC voltage, not DC current or AC voltage. The black test lead is connected to body ground. It needs to be connected to unpainted metal, for example one of the nuts on the coil tower behind the main relay/fuse box.
    The car is set to IG-ON, where all instrument panel warning lights are on.
    The red test lead is used to measure for voltage at the fuse socket. When the fuse is removed, you should be able to measure 12V at one of the two fuse socket contacts.
    If you are still getting zero volts at the 15A DOME fuse socket, then you have a serious wiring harness problem. The only other fuse between that point and the 12V battery is the 120A MAIN fuse which is located in the battery positive terminal. If any circuits are working, then that 120A MAIN fuse is OK.
  8. Ambrosia5
    63
    Colorado
    Ok I retested. I guess I was using a painted portion for a ground. Now I'm getting 13.99. Does this sound right or no?
  9. Patrick Wong
    18,214
    6,531
    Yes. Now you need to test the fuse sockets of the other fuses I had identified in post #71, and see whether 12V is not present at any of the sockets for those fuses.
    The 30A PWR fuse is located at the relay/fuse box under the instrument panel, driver's side.
  10. Ambrosia5
    63
    Colorado
    7.5A ACC 13.99
    7.5 A ECU-IG 13.97
    10A GAUGE 13.99
    20A FR DOOR 14.00
    I'll get to the 30A in a bit.
  11. Ambrosia5
    63
    Colorado
    Ok the 30A was blown. Just replaced it. 13.99v running to it. Windows work. Passenger rear will not roll up. Lol
  12. Ambrosia5
    63
    Colorado
    Driver rear window does not operate. Both front windows work good. Fob does not work. I did smell a small electrical burning so I immediately shut off the car.
  13. Ambrosia5
    63
    Colorado
    I
    The car blew the second fuse I just put it. So I think much power is overloading it.
  14. Patrick Wong
    18,214
    6,531
    Excellent troubleshooting work and good observation of symptoms. Now we have some clues that will be helpful.
    Since you say both rear windows do not work, my guess is that the power window master switch has a short which is causing the burning smell; or else the wiring harness that connects the 30A PWR fuse to that switch has a problem.
    See if you can detect the burning smell at the switch, located in the driver's door, inside panel.
  15. Ambrosia5
    63
    Colorado
    Thank you for that information I'll be checking that wiring harness in a bit. Also I guess I wasn't clear. The burning smell was coming from the rear part of the car. I checkedthe 12V wiring harness and fusible link and the wiring to the brake box and nothing melting or burning.
  16. Ambrosia5
    63
    Colorado
    I opened up the driver door. Noticed an exposed wire. Wrapped it with electrical tape. Cleaned it out. Did the unplug, plug in test. Only three windows work in IG-On mode. Last time I started it it blew the fuse and none but the driver worked. Rear passenger side inside door panel looked good no exposed wires, good connection. Behind the fuse 30A inside dash. Did the same unplug, plug in test. Still only 3 windows work. No exposed wires. Here are some pictures of inside the driver door and behind the fuse location. Also noticed there is wiring with a plug that is capped. Essentially goes to nothing. Any ideas what that could be. 20160507_165314.jpg 20160507_165620_001-1.jpg
  17. Ambrosia5
    63
    Colorado
    Ok scary thing happened today. I was driving my car like normal. I smelled smoke again. FROM THE HYBRID BATTERY. I pulled over got my baby out and disconnected all power to it. What do I do. My first instinct is to pull out the upholstery and expose the hybrid battery and check the grounds for the modules. Any thoughts?
  18. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    OK, so something is clearly wrong in the battery area where you did your work.
    You'll have to dismantle everything again and start checking things.
    I would make sure there is not a high voltage leak/grounding issue before digging around too much back there.
    Then proceed methodically checking every connection. Maybe taking some pictures along the way.
    I had a HV battery done by a dealer mechanic who accidentally forgot to tighten some important connections. It created some orange which damaged other components.
    I've also seen eBay replacement cells which literally blew up, leaving chunks of plastic exploded inside the case. Smoke and residue inside the car.
    Hopefully the problem is self evident as you start to investigate.
    Good luck and post some pics if you want to.
  19. Ambrosia5
    63
    Colorado
    I will start very carefully starting from the back and following the wires. Ill be taking pictures of each step and post.
    Thank you for the confirmation. When I get time I will be carefully checking all connections and grounds. I will post pictures of each step I take. I appreciate your quick response.
  20. Ambrosia5
    63
    Colorado
    Ok
    I took the first step
    Ok I took the first step and began with the 12V and surprise surprise this happened. Ground wire snapped 20160509_122734.jpg
