Dashboard setup for “economical driving”
Discussion in 'Gen 4 Prius Fuel Economy' started by JohnF, Apr 30, 2016.
  1. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Based on my ScanGauge, when that happens, the engine's running at about ~1080-1230 RPM at basically no load, usually to either generate coolant temperature or run the transmission oil pump.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    Possibly - but it's very soft if that's so. The transmission oil pump is part of the transmission, I believe, not ICE driven.
  3. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    It is part of the transmission, but it's driven by the planet carrier, which is driven by the engine.
    1:26:43 if it didn't jump there:
    On the Prime, it's driven electrically instead, so the engine need not be running for the transmission to be lubricated.
    alanclarkeau likes this.
  4. alanclarkeau
    7,045
    7,592
    Yes thanks, now I see that - and TOYOTA agrees:
    What's interesting, being driven by the ICE means that the pump is only lubricating when the ICE is running - or there might be an oil slinging as well by gears sitting in ATF.
    I'd thought I'd read somewhere that it's still pumping when the ICE is off - but that must be the PRIME as you mentioned. I assume the PRIME, because it could be driven 20+ miles without the ICE running would need lubrication some other way - hence being pumped electrically.
    Any idea how the Gen 3 PIP lubricated it - or did it have an electrical pump too?
  5. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    Gen 3 PiP was mechanically driven off the ICE - that was one of the big things about the Prime, that it finally had an electric pump.
