Dashboard warnings - When do they light up?
Discussion in 'Newbie Forum' started by Hpike, Jul 31, 2019.
  1. Hpike
    Hpike New Member
    Philadelphia
    I
    Hey, I recently bought a 2016 Prius. I noticed that when I turn the car on (before the engine) all of the dashboard symbols light up. I'm worried because some of them, notably the check engine and charging system warning lights, stay on after the others shut off. I'm unsure if there is a problem or not because all of the warning lights shut off after the engine starts.
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Have you looked in the owners manual to see if that’s normal?
    Raytheeagle likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    I heard you aren't allowed to look at the owner's manual unless you pay for the dash light vehicle upgrade package? Maybe that's not true? But that's what the dealership told me.
    Skibob and fuzzy1 like this.
  4. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    The lights are generally color coded. Green lights are something you turned on, or are normal. Yellow lights are caution lights. You may have a problem. Red lights are warning lights. You do have a problem.
    The green ones can be ignored, the yellow ones should be monitored. The red ones, you should operate your car at your own risk.
  5. bisco
    52,380
    the blue lights, pullover immediately
    Data Daedalus, Skibob and PriusCamper like this.
  6. PriusCamper
    13,051
    5,304
    And if you see a tunnel of white light, no need to pull over cause you're already dead....
    Data Daedalus and bisco like this.
  7. Elektroingenieur
    2,515
    3,287
    Three Touring
    It sounds like you’re starting the car by pressing the power switch without the brake pedal pressed, which puts the car into ON mode. This mode is similar to the key-on/engine-off state on a conventional car, and it’s not needed for normal operation. The warning lights you describe are correct for ON mode, since the hybrid system isn’t available to start the engine or charge the auxiliary (12-volt) battery.
    Instead of using ON mode, I’d suggest starting the car directly to READY mode, as described on page 225 of the Owner’s Manual (PDF). Set the parking brake, press the brake pedal and keep it pressed, and then press and release the power switch only once.
    Mendel Leisk, Hpike and PriusCamper like this.
  8. bisco
    52,380
    if there were a problem, the lights would stay on. it's just going through a standard health check
    Data Daedalus, Mendel Leisk and Hpike like this.
  9. Hpike
    Hpike New Member
    Philadelphia
    I
    Thanks all for the help!
  10. PriusCamper
    13,051
    5,304
    Yea... We're hoping @bisco to do this for himself for years now. Problem is he never stops so there's no startup health check... He just keeps going and going. Seriously do you ever take a break from PriusChat? How can 80K comments not be enough yet?
    Data Daedalus, Raytheeagle and bisco like this.
  11. bisco
    52,380
    i just took my wife out to dinner, have you been here all this time?:p
    Data Daedalus, Skibob and Raytheeagle like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Your 80k comments are getting a lot of attention this evening:).
    How many of those do you think are 12 volt related :whistle:?
    For dinner I hope your splurged on the wine(y).
    Data Daedalus, bisco and Skibob like this.
  13. Skibob
    2,912
    1,505
    Northern California
    Perhaps Bisco is living in his own private Idaho? :whistle:
    With Quiche Lorraine
    On planet Claire
    I know this because I have seen him driving a Plymouth Satellite, faster than the speed of light.:ROFLMAO:
    #13 Skibob, Aug 2, 2019
    RRxing, bisco and Raytheeagle like this.
  14. bisco
    52,380
    most of my posts are related to the wine :p
    Data Daedalus and Raytheeagle like this.
  15. Mendel Leisk
    41,893
    I'm a distant second, cus I don't drink. :oops:
  16. bisco
    52,380
    but look at how healthy you are!(y)
    i can't even crawl under the car anymore :p
  17. Skibob
    2,912
    1,505
    Northern California
    I can’t crawl under either. I have to lift the car up. ;)
  18. bisco
    52,380
    i could crawl under an mg back in the day
    #18 bisco, Aug 2, 2019
  19. Skibob
    2,912
    1,505
    Northern California
    Me too, and when I drove an MGB that was practically every day.
  20. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    You do Black box again:whistle:?
