dashboard with speedometer not displaying when lights are on
Discussion in 'Gen 2 Prius Main Forum' started by wfz, Nov 9, 2020.
  1. wfz
    wfz Junior Member
    36
    US
    With the pandemic, I didn't drive the car often and roughly driving on 1 to 2 times a week for the groceries. I noticed that the left panel with speedometer, gas, gear info was totally off when I had the headlights etc. on (manual or auto) last night. This did not affect the right panel with consumption, temperature control. That panel was on all the time. To see the panel display, I had to turn off the lights. To drive that way would be very dangerous at night, so I drove without the speedometer for the short trip I was on. Then when I drove the car this morning, the panel displayed the info normally no matter I had the lights on or not.
    Since it happened once, I am afraid it would happen again. Do you know what has caused this and if there is a simple fix without going to a shop? My car is a generation 2 Prius.
    Thanks,
  2. PriusCamper
    PriusCamper Senior Member
    13,065
    5,306
    Pacific Northwest, USA
    Did you try to adjust your dimmer dial on the left?
    TMR-JWAP likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Definitely the dimmer dial...……..or that circuit
    Look directly above your left knee when sitting in the driver seat. It will be in that general area.
