Dashboard working abnormal, ABS, VSC, Break and HV issue checklights ON
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Obaid, Jun 20, 2018.
  1. Obaid
    Obaid New Member
    Pakistan
    2015 Aqua
    Hi experts,
    I am facing this issue from last 2 days, that my Toyota Aqua 2015 model giving different warning lights, ABS, VSC, Break and HV error, i am posting my error screenshot along with scanner results.
    Also speedometer is showing abnormal readings. Apart from that i have already tested my 12v Battery its working fine and giving 14v while engine starts and without engine start it gives 12v.
    Car Mileage is 58000km only and year of manufacture is 2015.
    One error which i dont have a photo from scanner that was " Can bus is off" in ABS, VSC section.
    [​IMG] [​IMG]
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Do you have anything plugged into your OBD port? I can't see your pictures, but the ABS and Traction error come on for me periodically when I'm using my cheap OBD bluetooth device. I pull it and restart the car and the errors go away.
