Dashcam time
Discussion in 'Gen 4 Prius Audio and Electronics' started by Dngrsone, Aug 4, 2020.
  1. Dngrsone
    Dngrsone Underwhelmed, to say the least
    189
    Lost in a desert somewhere...
    My employer has decided to send me to a major city for some training... for like three months. Since I have a long history of being rear-ended (it's not me, I swear), I decided this would be a good time to get a dual dashcam.
    My current choice is the Viofo A129 Dual. Any tips or tricks for plugging this into my 2016 model 2?
    I think I will put a switch on the dedicated 12v line so my battery doesn't drain when I am at home, but I think the parking mode will be a good idea when at the hotel...
  2. Dngrsone
    189
    I have my kit, and I managed to get the hatchback wiring run. The flexible conduit between the body and the hatch can accomodate teh rather thick data/power wire for the camera, but it's some work to massage the Mini-USB connector through it. You'll want to free both end of the conduit: either end has four clips hold it into the sheet metal; free two of them and you can remove it.
    Right now I am stuck trying to figure out how to get the grab bars off. Meanwhile, I will likely start on the front camera.
  3. Dngrsone
    189
    The camera is in! It is hidden by the mirror from my point of view, and I am going to order the BT remote at some point so I can lock files at need.
  4. Dngrsone
    189
    So, forward is down in this picture. The camera requires two taps: 12v (always on) power and Accessory (on with ignition), which enables parking mode and driving mode. Luckily, on the 2016 Prius 2, there are a few open spots. The one all the way in the back (bottom of this picture) is Accessory power, and the one in the middle is always hot. You can see the bolt that secures the fusebox to the frame, which makes a handy grounding point, as well.
  5. Queueball
    Queueball Junior Member
    16
    17
    Saline, MI
    2019 Prius
    Thanks for the posts, especially the hardwire kit. I recently purchased a 2019 Limited and am looking for a front and rear camera. I lam considering the VAVA VD009 which has a rear facing camera on the main body so it looks through the cabin rather than using a camera in the hatch window. The rear looking site line looks to be unobstructed when I eyeball it. Obviously simpler than running wires to the hatch but I wonder did you have a reason to prefer separate cameras? Now that you've had it for a few months, is there anything you would have done differently? Thanks in advance.
  6. Dngrsone
    189
    I picked the Viofo set because it was highly rated and reasonably priced. I am slightly paranoid about privacy: I don't like GPS tracking, and have the GPS and Location turned off on my phone as well as on the dashcam, for instance, and so having a camera turned into the cabin is not something I would welcome.
    My biggest regret is not having all the tools on-hand that I wanted to when I went on my trip. I was out of town for two weeks, and it took me five or so days after work to finish the install, and a good chunk of that time was wasted in me searching an unfamiliar town looking for tools and accessories.
    The rear camera sits a little high... the upper tenth of the view is obscured by the middle divider of the hatchback, and I can definitely tell on the video when my brakes are on (though maybe that is a good thing?), and I regularly feel the need to manually clean the dust off of the glass for optimal video quality.
    To be honest, I haven't taken the time to pull video off the device to check for quality... it's on the bottom of my extensive to-do list, hah
  7. Queueball
    16
    17
    Saline, MI
    2019 Prius
    Tx for the reply.
    I feel there is a greater chance that I will have reason to track my vehicle or have it tracked than any loss of privacy considerations so I will have GPS and it will be on. But as to cabin view, after further consideration and digging I will go with the dual camera arrangement because it provides clearer and more complete information about traffic behind me which is what is important to me since it's what I don't control. I intend to fabricate a sheet metal cover with flanges adhered to the glass by two sided tape which will cover and protect the camera as well as keep it clean. It appears most effective to mount this on the lower hatch glass but before choosing a location I will test it to confirm brake lights don't interfere with the view; thanks for mentioning that.
    Hopefully you never have the need to view the video but in that event it would be unfortunate if you found it inadequate due to something entirely fixable. That said, all tinkerers have to-do lists considerably longer than time permits, that's what makes us tinkerers.
    Dngrsone likes this.
  8. Dngrsone
    189
    Too true
    As I mentioned above, I placed my forward camera behind my rear-view mirror, to the right, which makes it hard to reach from the driver's seat, so I got the optional BT remote, which is literally just a button for locking the current video file and mounted it to the dash.
    You will want to consider something like that if it is available on your system, or place the forward camera so that you can reach the incident button on it.
