Dashcam wire A pillar , 2007 Prius Base
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ccna101, Apr 16, 2024.
  1. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    So I search, there seem to be multiple thread out there but since it is very important, I hope I can get your SME give me the insight :
    1. Disconnect the 12V negative and wait for 30 min. ( airbag )
    2. To run the Viofo dashcam (12V) from windshield, slide wire between windshield and headliner with credit card, correct ?
    3. Any detail how to unmount the side plastic cover ? I do know it is tricky ( all Utuber skip over this ).
    4. Once it reach the side where the SRD logo is, pop the weather strip and thread the cable -BEHIND- the curtain airbag... try to stay along the existing wire and we are safe ???
    5. it is standard dashcam so I can extend ( tap into ACC fuse ) ....
    Let me know if I miss anything ?! last thing I want is cause issue with airbag/safety thing.
  2. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    Use both hands. (That's also why they can't film it.)
    ccna101 likes this.
  3. Aloe
    Aloe Junior Member
    61
    Canada South
    3) Pull off the black rubber door frame surround (just along the pillar). Now you have access to pull on the plastic pillar trim.
