daughter car at college could use some help
Discussion in 'Gen 2 Prius Technical Discussion' started by jbv7, Jan 30, 2019.
  1. jbv7
    jbv7 New Member
    se wisconsin
    Had my daughter take her car to a repair shop after triangle came on along with VSC and the circle with the parentheses around it. codes read P3000, P0A80, C1256. Sounds like the battery or cell in the battery is failing. Would that also trigger the C1256 code?
    52,815
    brake actuator? not sure. are they using tech stream?
