Day light savings time.
Discussion in 'Prime Main Forum (2017-2022)' started by White 17, Mar 13, 2017.
  1. White 17
    White 17 Junior Member
    59
    17
    Nor Cal
    I was reading another post that mentioned day light saving time and noticed that my advanced didn't catch the change in time today. I had to change the time in the nav unit and on the dash separately. I think it makes a difference when I have it set to charge for a ending time. I use Time Of Use with the power company and it would try to finish at 7am which would have been 8am.
    Maybe this will help someone else also.
  2. huskers
    huskers Senior Member
    2,548
    2,488
    Nebraska
    Might have something to do with not all states changing over to DST.
  3. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    Interesting. My 2016 Ram changed the time to DST automatically. You'd think Prius Prime would have the latest most advanced technology.
  4. geguia
    geguia Active Member
    210
    108
    los angeles
    okay so my time is updated but the clock up top isn't updating.
    Any suggestions?
  5. Toptimus
    Toptimus New Member
    Bay Area, CA
    You need to update the time in the Nav settings, as well as in the settings for the dashboard display.
    Meanwhile, Toyota engineers are still researching how to synchronize two clocks in a car...
    Wattup and Since2002 like this.
  6. YPizza
    YPizza Junior Member
    San Antonio
    The clock on the dash can be changed via the info display settings using the steering wheel controls.
  7. geguia
    210
    108
    los angeles
    Thanks - how do i get to that SETTINGS menu?
  8. YPizza
    San Antonio
    Navigate all the way to the gear icon on the right and the time related settings are the first few at the top of the list.
    geguia likes this.
  9. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    DST caught me too. I hadn't been in the car since Friday. Departure time set for 5:30 AM. When I left it had 50 min til full. Showed 26.4 EV but should have been around 28.4 from past experience. So 93% full but 15% time remaining.
  10. bwilson4web
    16,507
    Reminds me, my BMW i3-REx probably 'preconditioned' an hour later. Doesn't matter because I've been driving the Prime this week and haven't updated the clock on it either.
    You know the web site stability has been much improved since Daylight Savings Time.
    #10 bwilson4web, Mar 13, 2017
    Prius from Dad likes this.
  11. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I was really impressed when my auto-set wall clock actually changed to DST by itself. The mechanism cost about $16 and does not use the radio broadcast time signal. I don't understand how it knows when to change - it came without the battery installed. Anybody take one of these apart or know how it maintains the date without the battery installed?
  12. White 17
    59
    17
    Nor Cal
    On the nav screen, menu then settings, general,time settings or something close to that.
  13. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    I've got two of these clocks radios that were made before GW Bush changed when daylight savings time occurs. Now I've got to change these clocks manually a number of times each year.
  14. CharlesH
    2,798
    1,166
    Roseville, CA
    You would think that with all the sophisticated software in the system, that Toyota engineers would be able to connect the clock in the multi-function display to the one in the NAV system, where the GPS is. With both the time (down to microseconds) and location info (down to a couple of feet), the system can determine the local time. The Safety Connect system can get the location info from the GPS. Why can't the clocks?
  15. huskers
    2,548
    2,488
    Nebraska
    That would be a great leap in technology. Look for something like that in 2030.
  16. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    In the continental U.S. the so called "atomic clocks" in your home get the time from the government owned shortwave radio station WWV in Ft. Collins, Colorado. In many areas it can only pick up this signal at night. The WWV time signal includes an indication of when DST begins and ends, clocks that utilize this bit of information are not affected by changes in the DST schedule. Clocks that don't utilize this information instead use a built in DST calendar, which works fine unless the schedule changes like it last did in 2007, then you either live with it or get a new clock. Either type of clock contains a setting to turn off automatic DST in areas that don't observe it, although in continental U.S. it's now only Arizona that doesn't, because they believe it would increase air conditioner usage in the evening.
    Meanwhile the time on your computer is set via the Internet, based on your time zone setting in Windows or Mac OS.
    Your cell phone clock is set via the cellular network (which also knows where you are).
    Your GPS (portable or built-in) time is set by the radio signal received from the GPS satellites. Of course your GPS also knows where you are (if it doesn't you need to get a refund)
    Some FM radio broadcasts have a time signal embedded using a standard protocol known as Radio Broadcast Data System (RBDS). Although I am not sure how many consumer devices actually use this for clock setting.
    And finally this leaves our lowly dash clock. GPS would seem to be the obvious choice for obtaining the time, however since NAV is still optional in most vehicles, many auto makers presumably prefer to save a few bucks by just having one dash clock that works in all trim levels. Not sure how that explains it in the Prime, since NAV is standard. Maybe Prime shares the dash clock with the liftback? But whatever the reason I am sure it falls into the category of saving a few bucks.
  17. RobH
    RobH Senior Member
    2,385
    991
    70
    Answer my own question... The $16 auto-set clock mechanism that I have uses a small battery to maintain the date when the larger battery is missing/dead. If the rules change, I'll just buy another $16 mechanism with the updated rules.
    Since2002 likes this.
  18. priuslast
    priuslast New Member
    Tumwater, WA
    People have mentioned that there is a time on the navy system and on the dash. Where is the time on the navigation system? I've looked and looked on my advanced and don't see it!!
  19. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    The setting is found in the navigation system by pulling up the navigation system menu, selecting settings and looking in the general settings. There is a system time setting under the general settings. You will find options here. The option you should need to affect is the daylight savings button. This will automatically switch you to the opposing setting which is what you want at this time so that it moves the clock forward 1 hour.
    It is unfortunate that Toyota didn't provide an option to automatically adjust to daylight savings, and since they already link the navigation to the multi purpose display up in the dash, it is also unfortunate that they didn't bother to link the clock. It is linked to other things such as navigation, audio and air conditioning, you would think this wouldn't have been hard to add. It is unlikely, although possible, that the clock is a unique panel behind the multi-info display.
