Daylight lights Prius v
Discussion in 'Prius v Main Forum' started by Sldm, Dec 27, 2011.
  1. Sldm
    Sldm Junior Member
    MA
    Do you know whether lights come on automatically in the v3?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    They don't...
  3. rgilbert1
    rgilbert1 New Member
    Highland CA
    How do you or can you turn them on?
  4. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    In the owner's manual page 211-214. If you turn them ON via the left stalk, they will automatically turn off and on, so yes they will turn on automatically.
  5. Mickduc
    Mickduc Junior Member
    47
    Oak Park, IL
    So just to clarify, if you turn them on with the stalk they will turn off and on with the ignition? This is different from light sensing automatic lights that many cars have. The Gen III Prius has the light sensing disabled but if you leave the lights switched on they will go off after 30 seconds or so of powering the car down. So does the v have light sensing lights?
  6. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    The v Three definitely does not have light sensing headlights. If you leave the lights in the on position, they turn on whenever the car is on, even in daylight.
  7. rgilbert1
    Highland CA
    What about on the Prius v Five? I have no daylight running lights turning on.
  8. parnami
    parnami Member
    227
    48
    .Lancaster, PA (Amish Country) :)
    Fives do have light sensor headlights and you also have the ability to control the sensitivity. No running lights though the manual seemed to indicate otherwise.
  9. cmjars
    cmjars New Member
    Los Angeles
    I called Toyota Directly and although the Owners Manual says you can activate them via the left stalk it is a typo the US models do not have DRL's with no way to activate them.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I think about when I don't want other drivers to see me, and leave them on all the time.
  11. Mickduc
    47
    Oak Park, IL
    So it sounds like Toyota is using the same logic as they have with the Gen IIIs. I assume they are minimizing the use of the lights to decrease electrical/battery load. I'm not a fan of DRLs anyways, as long as the lights turn off on a timer after I power the car down I'm good.
