Daytime running light
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mrsocal, Sep 14, 2015.
  1. mrsocal
    mrsocal Junior Member
    25
    So Cal
    2018 Prius Prime
    Hello,
    I'm still enjoying my 2012 pip but I came across a couple of issues that I'd like to share and consult with you.
    The daytime running lights (DRL) were not working so I took it to Toyota to check it out. I also contacted the previous owner who thought that they working.
    Toyota performed their 101 multi point inspection and discovered that the DRL was disabled at one point and they had to enabled it from the ecu. I found that interesting but they are now working and they look great.
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Can't say about yours, but on the 2013 Model Three there is a setting in the user set up category where you can enabled or disable the DRL's.
    Default is ON (enabled).
    Enjoy your Prius and welcome to Prius Chat!
  3. fuzzy1
    10,048
    That setting is on the 2012 Three also. But I also cannot speak for the PiP.
    dorunron likes this.
  4. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    The 2012 PiP 3 trim has LED DRLs with a separate notch on the control stalk dedicated to turning it on or off.
    I prefer keeping the lights off during the daytime to save the miniscule amount of energy. If I had incandescent DRLs, I would be even more inclined to disable them since they tend to burn out frequently and consume even more power
  5. dorunron
    3,318
    1,103
    Houston, TX
    The 2013 Model Three has the same separate notch on the control stalk also.
  6. el Crucero
    el Crucero Senior Member
    1,628
    698
    Inland Empire
    I have a 2012 PIP Advanced with OEM navigation. Here is what you do:
    Press "setup" to the lower right of the navigation screen
    Press "vehicle"
    Press "vehicle customization"
    Press "lights settings"
    Press "daytime running lights"
    Press "on"
    Set your lighting stalk on the left of the steering wheel to "auto" Your DRLs will now come on automatically during the day when starting the car, and shutoff automatically when your headlights turn on in the evening.
    #6 el Crucero, Sep 15, 2015
  7. fuzzy1
    10,048
    That menu path sounds right, but I haven't looked at it for several years.
    I don't know if all PiPs have the 'auto' position on the control stalk. But my Liftback certainly doesn't. Instead, it has a manual DRL position, just like Dorunron's later model. This particular stalk is not illustrated in my Owner's Manual.
  8. el Crucero
    1,628
    698
    Inland Empire
    You could be right, but the OP has a 2012 PIP Advanced just like mine, they are all the same. My instructions will work for him.
  9. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Actually, you don't even need to switch to 'auto', DRL will light when the lighting stalk is off and automatically turned off when switching to 'parking' (position lights) and/or to on. The parking brake should be released though.
  10. el Crucero
    1,628
    698
    Inland Empire
    True, I was just trying to simplify things for him.
  11. mrsocal
    25
    So Cal
    2018 Prius Prime
    Thank you. That's very helpful.
  12. mrsocal
    25
    So Cal
    2018 Prius Prime
    Thank you all for the valuable information.
  13. dorunron
    3,318
    1,103
    Houston, TX
    Sounds like you got it all sorted. Best of luck to you.
  14. mrsocal
    25
    So Cal
    2018 Prius Prime
    Thank you.
    I love this car. Something about this car that's very relaxing. One focus on the ride quality, gas saving and taking the car pool lane :) instead of performance.
    radiocycle and el Crucero like this.
