Daytime Running Lights (DRL)
Discussion in 'Prius c Main Forum' started by priusmatty, May 28, 2016.
  1. fuzzy1
    10,645
    And I suppose that visiting American cars without DRLs help provide some cover, especially in provinces without front plates.
  2. Tideland Prius
    16,642
    Probably but how many border states have front plates and how many do not?
    Funny thing is that I've met Americans that either turn on the DRL (if it's an option on the headlight stalk) or turn on the parking/full headlights to mimic Canadian cars.
  3. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    Mendel has hit on the problem of late model cars with the turn signals right next to the front headlights. When the headlights are ON you can't see a blinking turn signal. This has been done for styling reasons and the fact that it is cheaper to put lighting all within the same "pod". The Prius C is one of the few cars with the turn signals remote from the headlights.
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Actually, most of the late model cars I see these days extinguish the daytime running light that's on the same side as a blinking turn signal so that you don't have any trouble seeing it.
  5. dick_larimore
    162
    70
    Central Indiana
    Guys, the problem is not the day time running lights. When the headlights are on, you cannot see the turn signals on most new cars.
  6. Mendel Leisk
    42,119
    I've got one intersection in particular, where the far side traffic is on a bit of a rise, so their headlights (or Canadian DRL's) are tilted up, almost blinding. It's an intersection where 90% of those oncoming cars tend to be turning left, and the drivers in my direction are also turning left.
    So far so good, we all just dosy-doe past each other. Except, there's the occasional car going through, from either side. Anyway, with the bright headlights glaring at you, you're squinting, trying to discern if there's a little yellow pulsing light in the corner. Or not.
    I actually emailed Transport Canada about this, about a decade back. They basically said everybody's got to follow spec, they are, and there's no problem.
  7. RyanAtha
    RyanAtha New Member
    Cornwall, ON
    I'm trying to import my car from the US to Canada (2013 Prius C III) I NEED to find an easy way to get my DRL's on full time. I'm REALLY having trouble locating any information that will help...Any leads??
    Thanks in advance!!
  8. Mendel Leisk
    42,119
    One thought: I see a LOT of late model cars running around (here in BC, fwiw), with BC plates, and no daytime running lights. It's Ontario you're talking about? And you've checked out the requirements there, with the powers?
  9. RyanAtha
    RyanAtha New Member
    Cornwall, ON
    Yes, Ontario...and yeah I've got the RIV list and my car meets all of the other requirements as is, so this is the only one that I'm trying to handle. The car does have stock DRL's but you can turn them to the "OFF" position which isn't allowed. This is what I'm trying to sort out. even some wiring diagrams of that switch/ harness would be helpful. I bought a Canadian Prius C switch in hopes that since it doesn't have an "OFF" the wiring/ switching would be the same however it didn't tender the results that I was hoping for.
  10. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Safety, pure and simple, DRL's provide oncoming traffic more warning of an approaching vehicle, and you have more warning when someone is approaching you!
  11. fuzzy1
    10,645
    But did those DRLs get turned off before applying for registration in BC, or only after? I.e. owner personalizations,
    I've seen plenty of Alberta vehicles without DRLs too, but haven't traveled far enough to get a sampling of other provinces,
  12. Mendel Leisk
    42,119
    Cops don't care, and/or are reluctant to do u-turns. We used to have annual inspections for lights, brakes. Now nada, the world has moved on.
    Off topic, kind of PSA:
    Walking the dog last night, it seemed like every second car I saw had at least one license plate out. When we got home we checked ours (plus the rest): yup, one out. I had a bag with a few spares, changed it.
    #32 Mendel Leisk, Jan 30, 2018
  13. RyanAtha
    RyanAtha New Member
    Cornwall, ON
    no ideas, eh??
  14. RyanAtha
    RyanAtha New Member
    Cornwall, ON
    I'm at the point where i'm just going to glue some damn plastic tabs to the switch to stop it from going into the "off" position. I'm finding it extremely difficult to find technical information for this car (without paying for it)...
  15. fuzzy1
    10,645
    See post #38 here:
    Auto-on headlights for v2 and v3 | Page 2 | PriusChat
    Is this something you could use, but put a jumper (or other modification) around the switch so that it won't actually turn off, regardless of switch position?
