Daytime Running Lights: yes or no?
Discussion in 'Gen 3 Prius Main Forum' started by Nora, Aug 7, 2013.
  1. Yes, DRLs
    68.3%
  2. No lights at all
    23.2%
  3. Headlights on all the time
    8.5%
  1. Nora
    Nora Member
    128
    44
    CO
    Today I was turning off my headlights and noticed that Toyota thinks I should run DRLs. All the bevels on the light stalk line up when DRL is selected, not when Off is selected. I've never had a car with DRLs, so I just flipped it all the way to Off.
    Are DRLs a positive thing, should I have them on all the time? Is this yet another case of "get with the 21st century"?
    Update: Was I not supposed to make poll results "publicly visible"? Apparently can't change that, so I'm sorry if that was the wrong choice.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Well on my previous vehicle "Honda Fit" the DRL's were automatic. No choice, if the vehicle was on, and running, with your lights off...then your DRL's were on. Many owners found the fuse that controlled this and pulled it, leaving them with no DRL's.
    I think Toyota is a bit unique in allowing you the choice.
    I personally like the idea. Car accidents can happen in quick but subtle ways, and I figure anything that makes me even an iota more visible to another vehicle makes me that much safer. So I tend to try to use them.
    However, even though on my Gen 3 Prius, the DRL's will turn off when the vehicle is turned off, I also tend for some reason to turn them off manually on my stalk. So a lot of times I forget to turn them back on. Don't ask me why I just don't leave them on all the time, I really have no logical reasonable answer.
    So for me the real answer is YES, I use them, when I remember to turn them on.
  3. WaltD
    WaltD Junior Member
    31
    I keep my headlights on all the time to be more visible. I especially want my back lights on so that I'm visible to fast moving traffic coming from behind. I'm a new Prius owner and I'll need to research DRL before I make a comment.
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Safer with them on
  5. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    I don't currently, but I'm planning on adding some LED units in the lower grille to act as DRL.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    As DRLs aren't mandated in the United States, they're liable to come and go like a fad.
  7. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Fully agree. I generally keep mine on for visibility. On the other hand, as 'Merican I like have the choice to turn them off if I want. If I didn't have the option of manually turning them off, I too would look for an alternative. It would be nice if the DRL was on a separate switch (like fog lights).
  8. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Experts disagree on the safety value of DRLs so it's not a given that they increase safety.
  9. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    I run with all my lights on. They shut off when I leave the car.
  10. hlunde
    hlunde Member
    419
    75
    An issue for Gen 3 is that the lamp-failure warning system does not monitor headlamps. So, a headlamp can fail during the day time and you will not notice the failure until it's night time and you really need the headlamps.
    I like factory-integrated DRL's which operate at reduced voltage during the daytime to extend bulb life life and have headlamp failure indicators.
  11. JeffHastings
    JeffHastings Member
    223
    79
    Whippany, NJ
    I didn't even know I had DRL's but am unlikely to use them since I fear they'll decrease bulb life of my headlamps.
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Unless you have a Canadian model, you don't. DRL's came standard on 2012 and up Prius. They use separate LED bulbs so won't decrease headlight bulb life. I have them on all the time. There is insufficient data that says DRL's are safer. So you are either safer with them on or they have no effect whatsoever. But no one is going to argue that you are more visible with them on.
  13. abra
    abra Member
    197
    Austin, Tx
    Three Touring
    GM was big on the DRL back in the early 2000, my 2002 Astro has them. I leave my headlights 'on" on my Miata due to its size and same with the Prius.
  14. Tideland Prius
    16,666
    I don't have an option (Canadian-spec vehicle). At my latitude, they are definitely useful as you can't count on people to turn on their headlights (or parking lights if they're bright enough like some GM vehicles) in broad daylight in the middle of winter.
  15. The Electric Me
    9,083
    5,801
    Don't quite understand. They are factory installed. The only thing is you DO have the option of turning them off. Which I think most people like.
    And they are separate lights from the headlamps.
    You know what you call a "lamp-failure warning system" that does not monitor headlamps? Well not much of a lamp failure warning system at all.
    I did not know that was the case with Gen 3 Prius. But it really is a separate issue from whether you want to use DRL's or not.
  16. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I like DRLs and the concept. More visibility is best. Audi was first with the LED DRLs. Now most new cars have some variation of the LED DRLs. At first, I was disappointed that all parking lights, light up with DRLs. Makes sense.
  17. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Wouldn't running DRL's reduce gas mileage? The electricity has to come from somewhere!
  18. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    There was some very conclusive Swedish research in the 70s which showed a 50% reduction in head-ons and 30% reduction in all other collisions when headlights are used during the day. I've driven with headlights on ever since and never had a head on collision.;)
    Nora and JMD like this.
  19. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
  20. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    I have never used them. Do they turn off automatically if you use the function?
