Daytime Running Lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Montydude, Jul 29, 2013.
  1. Montydude
    Montydude Junior Member
    Denver
    2013 Prius v wagon
    I am wondering if anybody else has run into this issue: When I have the headlight switch set to "Auto" and the photoelectric eye turns the LED headlights off the Daylight Running Lights do not turn on. I have had this to the dealer twice and was told that since I had LED headlights that I do not have DRL's? Makes absolutely no sense since the manual seems to indicate that the DRL's are the same bulb that illuminates the High Beam but at a lower intensity. Please let me know if that is correct and if anyone has LED headlights where the DRL's are working correctly or not. I am thinking it is just an OBD setup that is the issue but I can't seem to get anywhere with the dealer. Thanks
  2. fuzzy1
    10,632
    Does the manual say for certain that your car has DRLs, or does it have weasel words such as 'if equipped'?
    The Canadian cars should have DRLs, but I'm not aware of U.S. Prii getting them before 2012.
  3. Air_Boss
    Air_Boss Senior Member
    4,234
    1,190
    New Yawk
    And this being the v forum, we don't have them at all in the US.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    DRL use less watts to light the DRL bulbs. Is it possible the LED bulbs will not light with the lower wattage? H
  5. fuzzy1
    10,632
    I missed this the first time: Toyota first put LED headlights on the Prius in 2010. The only way OP's 2005 could have them is if a previous owner installed some aftermarket kit.
  6. Montydude
    Denver
    2013 Prius v wagon
    Yes, the manual does day that it should have DRLs on the US version. The DRL's use the same bulb as the high beam which is not a LED bulb. The only LED headlight is the low beam so that is why this makes no sense. Thanks
  7. Montydude
    Denver
    2013 Prius v wagon
    Sorry, I now have a 2013 Prius V which is why I posted this on the V forum. I will update my profile. Thanks
  8. fuzzy1
    10,632
    All my earlier answers were based on your earlier profile of an '05 model, which lacked DRL in the US. Now that your profile is updated, maybe we can get a moderator to move this back to the 'v' forum, out of the GenII forum.
