DC-DC converter failure or am I missing something?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jamalhollis, Jan 30, 2023.
  1. jamalhollis
    jamalhollis New Member
    Central Ohio
    08 GenII
    149k
    Original traction battery
    12v battery ~2 years old
    This weekend, I re-started the car after going on a few short drives during which it had performed normally. The red triangle popped up along with a host of other warning lights and a shrill beeping sound. Brakes felt a little less assisted. I power cycled the car cycle times with no change. OBD scan showed code P0A08 - DC/DC Converter Fault Circuit Open. I cleared the code and re-started the car. Drove approx 25 miles with several stops, no issues. The red triangle/shrill beeping re-occured once in an intersection at the end of the drive and stopped after power cycling the car again.
    I drove it home and got out my tools. Multimeter shows ~14v at jump starting block & battery terminals at idle. I load tested the 12v battery and it tests very strong especially for a battery of its size.
    Hooked up OBD2 scanner and logged data for ~45 minutes of drive cycles. Naturally, the car performed flawlessly while I was data logging.
    The next day, after several short drives, the fault reoccurred. This time, I was able to see that the OBD reflected the current voltage as ~10.8v at idle. The terminals of the 12v battery reflected a similar voltage at idle and also with the car powered off. I power cycled the car and it performed normally. After several short drives with the OBD voltage showing as its normal 13.9v, the 12v battery recharged to about 12.7v measured with the car powered off.
    - *No* jump starts or any electrical work has been done on the car within 2+ years of ownership (unless replacing headlight bulbs counts, lol)
    - No fault codes are in the OBD related to the traction battery; the Dr Prius app shows the traction battery to be in fair condition with about ~60% capacity remaining. (Note: I wasn't able to use the Dr Prius app to test for fault codes and found it to be disappointing in this regard)
    - The jump starting connections in the fuse box area under the hood are clean and tight
    - The battery terminals on the 12v battery are perfectly clean and tight
    - I did check to verify that the inverter cooling pump is operational; it is, and the coolant is full. I don't think these symptoms sound like the inverter is overheating but thought I would check regardless.
    These symptoms seem to point to failure of the DC-DC converter within the inverter. This seems to be uncommon. Many people suggest that this is caused by some sort of electrical tampering or by someone jump starting the car backwards, but this car has not been jump started in 2 years. I bought it 2.5~ years ago after it had sat for an extended period of time, replaced the 12v battery and it has driven flawlessly since- I've put about 19,000 miles on it.
    Am I missing something, or should my next step be to replace the inverter or at least the DC-DC converter board inside of the inverter? Troubleshooting advice or advice on if I should replace just that board, some part of the inverter, or the whole inverter, is appreciated.
    #1 jamalhollis, Jan 30, 2023
  2. Tombukt2
    Tombukt2 Senior Member
    13,788
    2,497
    Durham NC
    Well seeing as how I have complete inverter sitting here that came off good running cars I don't know how fast it is to change the DC to DC inverter board versus bolting in the hole inverter these silver top Gen 2 inverters are pretty heavy duty Hitachi internals If the board comes out easy enough and everything else is clean in there change the board that is a funny reading that 10.8 volts when the car is ready but yet when the car is off you have 12.7 interesting so then it seems like like you say the DC inverter portion is not maintaining your battery but yet a few minutes ago you had 14 volts with the car ready and on? So at best it's intermittent it seems
  3. BiomedO1
    BiomedO1 Senior Member
    4,482
    2,355
    Left Coast
    Sounds like you've got an intermittent diode; when the car heats up the diode opens and no battery charge. Check your inverter coolant and make sure it's moving. Regular car alternators do this too.
    I would probably replace the entire inverter rather than crack open the unit and mess something else up while replacing the board. Besides; it'll be faster and easier job this way - less down-time.
    Good Luck....
    rogerdpack likes this.
  4. Pepe Bono
    Pepe Bono New Member
    Seville
    Design
    Thanks a lot, I was expected to run out of battery with P0AFA code, When I dismounted the battery I found a wire cut. When I was mounting all of the componentes of the battery seizing to clean all sulphated metals, I made a mistake with the terminals, connecting positive and negative inside out. Then the big fuse and one of the big relays (positive I think) crashed and the code was P0A08 and therefore I had to bought an used inverter because I couldnt find a dealer that sell a DCDC used board. After mount it all dtcs was cleared automatically, so thank you everybody for the help.
    BiomedO1 and Brian1954 like this.
