DC-DC Convertor Failure
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zaxbyc, Feb 7, 2024.
  1. ChapmanF
    19,060
    Those are two different things, both contained in the inverter assembly.
    Reference in the manuals to the "DC/DC converter" always means the simple buck converter from traction battery voltage down to aux battery voltage. That's located down below the main IPM in the inverter assembly.
    When the manuals refer to the "boost converter", that's the big one that's in fact bidirectional: it boosts traction battery voltage up to 650 for operating the motors, and also bucks motor voltage down to traction battery voltage for regen and charging. The transistors for that one are part of the main IPM, though the reactor and capacitors needed in that circuit are separate parts.
  2. Mendel Leisk
    42,379
    Why is that?
  3. Oliver Ingwall King
    Oliver Ingwall King Junior Member
    Sweden
    ----UK----
    This was really useful. I have just been quoted 13 000 SEK for our Gen 2 Prius. This has done close to 150 000 miles now and although we love it, it’s starting to become a question of what to fix.
    QUOTE="zaxbyc, post: 3428113, member: 211720"]UPDATE
    Fitted a second-hand part today.
    The total cost was £119 for the Inverter and £45 for the coolant. So about $207 USD in total.
    The most difficult bit was a plastic push-fitting of all things!
    Started at around 10am, and finished at 12:30 with everything back together and ready for a test drive.
    View attachment 251254 View attachment 251255
    Went on a 20-mile drive, filled her up the drive back home, and the mileage seems to be back in the range I'm used to! 67.9 MPG - Remember this is UK MPG.
    Thats 56.5 MPG US and 4.2L/100km for the Europeans
    Thank you everyone for your help :D[/QUOTE]
    T
  4. Oliver Ingwall King
    Sweden
    ----UK----
    thanks for your knowledge @Mendel Leisk on this. For some reason Google is saying I can not see these documents. Is there a setting I need to change or could you post them again
  5. Mendel Leisk
    42,379
    For the broken links:
    inverter replacement
    inverter coolant change
    hopefully works; let me know.
    VelvetFoot likes this.
