DDM, HID 55W 8000K or 6000K w/relay harness questions
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Horndog, Feb 2, 2014.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Even if it ramps it up slower, it still needs 20,000 volts to even start the HID bulb. Not to mention if the ballast fails or something.
    That's really what you are protecting against although it would be interesting to hear if anyone has had a ballast fail without a relay and if the stock wiring was fine. I guess it would depend on what kind of failure it was.
  2. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    In the case of not using a relay- the stock wiring is fused, so in theory it should blow the fuse before the wire melts and causes a fire. With that in mind... is the aftermarket relay fused?
  3. mediahound
    903
    155
    The ones I've seen are, I think 40 amps.
  4. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    That voltage comes from the ballast. It isn't drawing that from the stock wiring.
  5. mediahound
    903
    155
    And where do the ballasts get the power from if not using a relay harness? The stock wiring.
    Should there be some short or problem/failure with the ballasts, that can affect your stock wires potentially.
  6. burstaneurysm
    469
    144
    Chicago, IL
    If the ballast fails, it's not going to suddenly draw 20kW from your stock wiring, it just won't fire.
  7. Horndog
    Horndog New Member
    25
    I need your help again with this....I found the two wires for the lead on the relay harness and plugged them into the fuse box like you have shown me above.....however, one end of the relay harness just has a circle to attach to something......any ideas where that is supposed to be clamped on?? Any help would be greatly appreciated
  8. xliderider
    xliderider Senior Member
    8,056
    3,224
    Honolulu, HI
    If it's a black wire, it goes to any good ground/bolt. If it is a thicker red wire, you need to cut that round ring terminal off and replace it with a 0.25 or 1/4 inch push on terminal.
  9. Horndog
    Horndog New Member
    25
    So one end connects to the terminal like in your picture....but the other red end needs to hook up to the batter all the way in the back of the car? Is there an easier way?
  10. xliderider
    8,056
    3,224
    Honolulu, HI
    No, the terminal in the fuse box is the "battery" in this setup. No need to run a wire to the battery in the trunk.
  11. Horndog
    Horndog New Member
    25
    So then I only use one of the red wires? Because one red wire goes from the fuse box to the small black box....and the other red wire just has a circle at the end? Should I just toss the red wire with the circle?
  12. xliderider
    8,056
    3,224
    Honolulu, HI
    Post a picture of your HID kit. Didn't it come with instructions?
    A relay typically has 4 connections. 1) Connect to power source, like the battery. 2) Connect to what you are going to power from the power source. 3) A smaller power source that is switched, AKA the signal wire for the relay's coil. 4) Ground.
  13. xliderider
    8,056
    3,224
    Honolulu, HI
    So it sounds like the red wire in your relay with the ring terminal goes to the battery/fuse box, the other red wire is the one that powers your ballasts.
    If you've already connected the red wire without the ring terminal to the fuse box, then you can just cut off the ring terminal on the other red lead and connect that to the ballast power lead instead. It really doesn't matter to the relay which red wire is coming from the fuse box.
  14. soheilm3
    soheilm3 New Member
    SoCal
    2014 Prius Plug-in
    i gave up on figuring out my ddm wiring harness. this is what i attempted
    • the wire with the fuse and a circle hook I connected to the 12v terminal inside the fuse box, inside the cover
    • the wire without the fuse and a circle hook connected it to the body/ground to the right of the fuse box
    • i could not get a combination of ballast, bulb, stock wiring and ddm harness cables to work for the life of me
    in the end, i connected the ballasts/bulbs thru the stock wiring, works fine. may attempt to use harnesses another day.
