"De"-nginer
Discussion in 'Gen 2 Prius Technical Discussion' started by Bruce Meacham, Jul 3, 2012.
  1. Sure, why not
    87.5%
  2. You are high
    0 vote(s)
    0.0%
  3. Did you think about...
    12.5%
  1. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    116
    Okay so I need DunioMite mega, obd y spliter(will also use scangauge), and canbus adapter, ......this will also require a interfaces .....so small monitor and keyboard too required .....??
  2. jdh2550
    jdh2550 Co-Founder, Current Motor Company
    317
    249
    Ann Arbor
    I'm not sure what "Canbus adapter" is in your list.
    Yes, small monitor and keyboard will be required. I suggest a 7" VGA monitor designed to run off of 12V. ~ $150 on ebay. And I just ordered a compact PS/2 keyboard from Amazon ($35).
    dave77 likes this.
  3. NortTexSalv04Prius
    915
    116
  4. Flying White Dutchman
    4,376
    314
    Then also WiFi is useless
    Its was for home intented
    Public station here are for me 4 x more then home charging.
    But on the road a umts mobile internet gateway and a ethernet would work
    -Htc Tapatalk ( sorry for auto spell correct )
  5. jdh2550
    317
    249
    Ann Arbor
    So go get an eMega and do it...
  6. Flying White Dutchman
    4,376
    314
    Just saying WiFi is also useless.
    And if cam bus not working then thats also useless for the eMega ;-)
    So i get a normale mega :p
    This board could also work as a ice temp spoofing auto on and off switch
  7. NortTexSalv04Prius
    915
    116
    Okay
    I took the plunge and order mega with box about 53plus shipping, what about the can adapter and touch screen
  8. jdh2550
    317
    249
    Ann Arbor
    Yes to the touchscreen. No to the can adapter (your mega will take the place of the can adapter)
    dave77 and NortTexSalv04Prius like this.
  9. Bruce Meacham
    Bruce Meacham 2005 Prius/Enginer 4kwh and BMW EV conversion
    45
    Kansas
    Any software updates or project updates? I was surfing before work and found a site where someone was selling a CAN board for this conversion (actually for parallel stock hybrid battery packs). I was busy and didn't bookmark it, so of course it's lost now. But if anyone knows what i'm talking about, I'd like to mark it.
    -Bruce
  10. Bruce Meacham
    45
    Kansas
    I found it... Unlike what we are considering, this uses additional OEM Panasonic packs. But it's interesting none the less.
    blank
    Enjoy!
  11. Flying White Dutchman
    4,376
    314
    Mmm. Thats what a few of us already using and postings about for years now incl lopez...
    You missed that thread?
  12. NortTexSalv04Prius
    915
    116
    What is top balance and bottom balance and some say you do no need to balance at all
  13. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Top balancing is done during charging at the end of the charging process. Excess power is burned on cells that are higher volts than others until they are all about equal at the top. This is used by miniBMS and Pacific EV.
    Bottom balancing is done when cells are around 30% SoC and have rested for a while before starting. The balancer takes power from the whole battery pack and feeds it to the lowest cell/s volts until they are all about equal. This is used by Enginer. Last time I checked you have to open the BMS16D to switch on the balancing - PIA.
    There is a group of people who do not use a balancer and will balance the pack by connecting all the cells in parallel and let them equalize to the same voltage over 24 hours. They do this every so often.
    [email protected] likes this.
  14. NortTexSalv04Prius
    915
    116
    thanks
    The EV community has variable proponets on these methods. EVTV is educational and hands on....
  15. NortTexSalv04Prius
    915
    116
  16. NortTexSalv04Prius
    915
    116
  17. NortTexSalv04Prius
    915
    116
    My new avatar reveals what is low end workman ship by enginer phev kits............the BMS has six count them six connection points and you only use five the far left square opening is of no value to the BMS
  18. NortTexSalv04Prius
    915
    116
    well I have open up or taken apart both BMS and converter to have a curious look and found nothing that could be adjusted.
  19. NortTexSalv04Prius
    915
    116
    FYI
    Enginer
    To restate, no sells on EBAY....currently the website(hosted/maint colorado) no longer allows direct purchase via google checkout only email, phone contact.....
  20. bisco
    52,888
    i wonder how bruce's project is coming along?
