Dead 12 volt battery after ECU Update
Discussion in 'Gen 3 Prius Technical Discussion' started by jorez, Apr 14, 2014.
  1. jorez
    jorez New Member
    White House, Tennessee
    I got the ECU Update Friday.. Today my 12 volt battery died.(got it started after a jump)..Any correlation?? Toyota service days no. Is there any kind of a warranty on the 12 V battery? 2011 with about 40k on it seems way low for the battery to die. No changes in driving habits since ECU update either...ARGHHH!!!
  2. JC91006
    16,935
    8,646
    did you leave a light on? maybe door ajar?
  3. jorez
    jorez New Member
    nope. Im very diligent to turn the light off (all of them) and close the door and lock it each time
  4. JC91006
    16,935
    8,646
    How many miles have you put on your car since the update?
    Any correlation between the two events would be that your battery was weak to begin with when you brought the car in. They probably had the door open to re-program the car and the interior lights were on for the amount of time it's serviced. So it further weakened to the point where it died today.
    You can try charging it up and see what happens. Or you can just take care of the problem and get another battery at Toyota for about $200 and install it yourself.
    if you complain loud enough, the dealership might install it for you if you buy the part. The car only has a 3year/36k mile warranty, so you are out of that warranty.
  5. jorez
    jorez New Member
    Ugh. Thanks for the info!
  6. Tommy Johnsen
    Tommy Johnsen Junior Member
    33
    Norway
    Many reports on faulty 12v battery in Norway.
    Probably has nothing to do with the update.
    If you are within warranty period and battery test at your Toyota dealer says faulty battery, there's no reason why not? Defective cell is the most common fault, if you didn't leave anything on...
  7. Tommy Johnsen
    33
    Norway
    Sorry. .. In Norway we have 5years/160.000KM warranty. ..
  8. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    In general, except for the one year "all things covered" warranty, the 12V battery has no warranty. -Some- "aftermarket" batteries do have a warranty, usually a depreciating one (cost you more the older it is and you always pay something). But I'm not aware of any that will fit a Prius other than the Optima.
    Make sure they tightened the battery terminals if they disconnected it. Do check to make sure no interior light switch was turned on by them. Remember to check the hatch light as well.
