Dead 12v Battery --- A Glove Box Remedy?
Discussion in 'Gen 2 Prius Technical Discussion' started by Rokeby, Feb 8, 2008.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I wonder if you could just temporarily disconnect the 12v battery and then test your jumper. I suspect you'll get an array of warning lights when the system figures out it doesn't have it's 12v onboard, but it shouldn't do any harm other than costing you your radio presets and auto-window settings.
  2. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    Evan,
    With a typically larger booster/hot start connected under the hood, I believe your suggestion would work.
    However, this particular B&D unit has its own circuitry that looks after its well being with as much particularity as does the Prius' CPU. Some while back I tried to hook this unit up using jumpers under the hood. When the 12v battery is disconnected, the booster goes into its charge regime then, in but a second or so, shuts down. Apparently, it doesn't "see" anything to boost.
    Interestingly, this is a 2008 model, I did not loose the "sticky-key" setting on the driver's window, the radio presets, or any nav information. All I lost was the unlocks-all-the-doors-when-the-passenger-door-is-the-first-opened option that I had input.
  3. tmorrowus
    tmorrowus Member
    514
    I bought one of the BB7B's when I saw it on the shelf at Target. I'm not sure if this has been mentioned, but the real appeal of this thing for me is the small size. It fits in the hidden trunk compartment on the side opposite the battery.
    I had the opportunity to test it out on a dead prius battery last night. Unfortunately I haven't yet gotten around to wiring an always on power port, and my Prius didn't have enough power to engage the power ports, so it had no connection and hence was useless. I ended up calling roadside assistance.
    So know that you WILL need to rewire an always-on power port if you want to rely on the BB7B.
  4. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    tomorrowus,
    thanks for your posting. For the record, I haven't had cause to use my BB-7B
    yet -- knock wood.
    The small size of the Black and Decker BB7B surely is one of its positive
    features. I keep mine in the lower glove box. I have mine here as I can
    recharge it from the now always-on under-dash port and leave it in place.
    The unit's cord is just long enough to do this -- coincidence?
    The BB-7B will also fit snuggly under the driver's seat from the back. Here it
    might be best to secure it to the carpeting with some of the "hook" tape of
    hook-and-loop fame.
    Yes, for the BB7B to work, you have to have access to an always-on power
    port. The Coastaletech mod is inexpensive and relatively easy to install. As
    an alternative, you could replace the BB7B's power port connector with
    alligator/small battery clips. With these you could tap into the 12V circuitry
    under the hood, a simple operation.
    If you were really gung-ho, I guess you could even make up a custom cord
    with a power port connector on one end and battery clips on the other. This
    would be plugged into the power port on the BB-7B, and then connected
    undet the hood.
    Sorry to hear that your 12V battery gave up the ghost. At the risk of
    sounding ghoulish, would you consider posting a brief account of how that
    happened?
    Edit: nevermind, just saw your new thread:
    http://priuschat.com/forums/prius-technical-discussion/49764-12v-battery-dead-related-transaxle.html
  5. tmorrowus
    tmorrowus Member
    514
    I am actually planning on installing an unswitched 12V power port connected directly to the 12V prius battery (through a fuse of course). I'd like to have convenient access so I could plug in a 300W inverter to drive appliances when I'm on the road. Once that is installed, I'll be able to just plug the BB7B into that whenever needed.
    But upon seeing this thread, I ordered the coastal kit. Even though the front power port doesn't have the juice to run a 300W inverter,having it always on would be useful for the exact thing you are doing: Keeping the BB7B topped up by plugging it in frequently.
  6. tmorrowus
    tmorrowus Member
    514
    I just had the opportunity to test out my BB7B under controlled conditions on my 2004 Prius. It worked well.
    Here's how I drained the battery for testing:
    My Prius 12V battery is on its last legs, and I was able to drain it down by leaving the headlights turned on for about a half hour. It was actually kind of interesting watching the car slowly die. After about 20 minutes only one of the two headlights would run. Then even that one wouldn't run. I kept discharging the battery by connecting a 300W indoor halogen light directly to the battery while monitoring the battery voltage, which was now below 10V under load. It burned very dimly, probably not using more than 30 or so watts, and I only ran it approx 5 minutes after the headlights died. Soon the door ajar beep beep beep turned into a long kind of pathetic drone, and then I decided I had probably got it low enough.
    I tried starting the car, and it wouldn't start (first time in my life I was thankful for that! :evil:). Annoyingly the car also didn't seem to have enough power to turn itself off; pressing the power button cycled between the green light and amber light modes, but wouldn't turn the power button light off (I've seen this in the past on dead batteries so it's not a big surprise). And reassuringly the car did turn off at one point although I wasn't sure how I made that happen.
    The results:
    The battery was reading about 7.1V under load, but when I disconnected the load it started heading back up resting somewhere just below 10V.
    I hooked up the BB7B to the front 15A outlet that I had rewired to be always on, and switched the BB7B into boost mode.
    The car didn't start up when I tried it immediately, or after a minute of boosting. But after a few minutes of boosting it did start up.
    Annoyingly, the multifunction screen continued to say the transmission is abnormal and needed to be returned to park, even though it was already in park. I got around that by shifting to neutral, which removed the full screen warning, but the MFD still said simply "Problem" and the dashboard big red triangle with exclamation symbol remained lit. After running the car for about 5 minutes I powered it off and then powered back up without the BB7B.
    The "Problem" message on the top of the screen and the light remained lit. I drove the car around the parking lot, and again powered it off then on. This time the Problem message and light were gone and they never came back.
    I've seen that behavior before where the transmission Problem screen comes up; it seems to happen every time I jump a dead battery in my Prius. It's nice to be able to explore it under controlled condtions and realize that it seems to always go away eventually, and the car is still driveable even when the Problem light is on. Someone on this forum said the transmission Problem screen is a red herring, that it comes on because the computers are clueless due to having lost power. I'm now thinking this is true, that it is a red herring and not something to worry over.
    Anyway, I'm now feeling happily confident about the BB7B. If it can take a battery from 7-10V back into operation, that's a pretty good sign.
    I'm going to replace my Prius 12V battery soon, but if there are any more quick tests I should do on the last legs battery, please let me know.
  7. Patrick Wong
    18,200
    6,501
    Fascinating. Since you have the ability to measure battery voltage, it may be interesting to measure how much voltage the BB7B produces in boost mode. If much more than 13.8V, then you may not want to have the Prius electronics in the loop while the boost is in effect.
    I also suggest that after allowing the 12V battery to discharge so deeply, that the battery will need to be charged up fully (one way is by leaving the car READY for an hour or so).
    Good luck with your new device.
  8. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    my battery hasn't held a charge since i reached 43k miles or so. i let it drain too many times so the charge only last 16 hour or so... so if i sleep in, or don't drive for a day, it's dead... 9v or so
    the car starts fine when supplied with over 10v.. under and you'll get the various warnings about the parking pin.. if you let the car sit and charge up a bit... then power off and on... you can hit the park button a couple times and it shuts up...
    i've attached 4 7v solar panels in two 13.5v series (a few panels read lower, so i arranged them to obtain the similar voltage readings) i can leave the car all day, and it's just enough to keep the battery up. right now my install is temp, so i have a long wires that go from my dash to the battery. i'm thinking of moving them to the roof...
  9. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
    My OEM 12v battery was also on it's way out and just before I replaced it I was able to run it down by simply having the doors open for about an hour while detailing the car. The transmission parking pawl solenoid seems to drop out at around 10v giving you random assorted errors.
    My solution: Optima yellow top battery:
    http://www.amazon.com/dp/product/B00075OSD8?tag=priuschatcom-20
    :bounce:
    I recently forgot to turn off a map light for about 2 hours and it didn't even register a significant drop in battery voltage. This would have killed my old battery.
  10. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    tmorrowus,
    Thank you for your post. It is very gratifying to read that you have been
    able to validate that the combination of the Black and Decker BB7B booster
    and Coastaletech power port mod can overcome a dead 12V battery and
    bring a Prius back to life. It was only yesterday when I was giving my BB7B
    its monthly top-off from the power port that I was again wondering if it
    would work.
    Well done, sir. Well done indeed.
    And today is my birthday! I can't think of a better present than having my
    ongoing doubts on the validity of the BB7B put to rest. WooHoo!
    I want to thank the many posters who offered their advice and comments
    which helped me move this project along to completion.
    Last but surely not least, it is the greatest pleasure to have sparkyAZ
    post up. Sparky virtually took me by the hand and lead me through the still
    as yet to me incomprehensible thicket of electrical realities as I blundered
    towards the final configuration.
    Sparky, again and always; many, many thanks. You're the Man!
  11. tmorrowus
    tmorrowus Member
    514
    Indeed, I have to give Sparky a shout out too. While I was doing the battery draining experiment I was taking apart my dashboard with Sparky's guide, to work on the radio. Thanks Sparky for your contributions that help us all.
    I saw that it is definitely way below 13.8V while the BB7B is boosting a drained battery; the battery sucks up all the current. I wouldn't worry about damage as long as you remove the BB7B soon after the car has started. The BB7B does make a whining noise while boosting, which indicates to me that it's using some sort of a switching dc/dc voltage step up system to output more voltage than the BB7B internal batteries put out. If so, then it likely has voltage regulation.
