Dead Battery after leaving the car in the driveway for 2 months.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Gwynngal, Jul 6, 2019.
  1. Gwynngal
    Gwynngal Junior Member
    Gwynn's Island, Va
    I left my daily driver (2007 Prius) in the driveway in the hot sun for nearly 2 months and now it's totally dead. I have a Rockford Power Pack that I was going to try but the charger has a strangely puffed up appearance rather than the former compact shape I remember and the power switch doesn't seem to engage so no lights, no flashlight, no nothing there... [Question # 1: I guess it goes to the trash heap?] imageserve.jpg
    Question #2 So back to the car issue. My husband has a car charger but only with 2 A & 15 A settings. I saw that someone suggested putting it on 4 A overnight. Is this a problem? Is 2 A or 15 A okay? Anything else I need to do? Thanks for your attention in advance...
    49,796
    i think 2 amp is best. your gonna have to monitor it for awhile to see if it isn't permanently damaged. how old is it?
    you need to find a way to recycle the jump pack
    jb in NE likes this.
  3. Gwynngal
    Gwynn's Island, Va
    Yes, I'll drop the Power Pack in the rechargeable battery recycling bin I guess. I never thought about it being damaged by being in the hot car.
    The 12 volt car battery is only a little over a year old. How does one 'monitor' a battery?
  4. Patrick Wong
    18,200
    6,479
    “Monitor” means to see how long it takes for the battery to be recharged. At 2A charging rate, expect this will take most of a day.
  5. Gwynngal
    Gwynn's Island, Va
    We started it around 8 PM and planned to leave it overnight. It sounds like 12 hours may not be enough?
  6. Patrick Wong
    18,200
    6,479
    No. The battery has a capacity of around 40Ah (Ampere-hours). Hence if the charging process was 100% efficient, at a 2A charging rate it would take 20 hours.
    Further, the charging process is not 100% efficient as some of the electrical power goes into heating up the battery. Hence the charging process will take longer than 20 hours if you want to fully-charge the battery from a dead state.
  7. Gwynngal
    Gwynn's Island, Va
    OK, looks like more toward 24 hours. Thanks so much
  8. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
  9. Mendel Leisk
    38,952
    Look into "smart" chargers too. They can usually be left on indefinitely, say while you're on vacation, and if you do have a rundown battery it will assess it when you connect, let you know if it's viable, and then go through a multistage charging regimen.
    Not sure what the second Gen amp ceiling is, maybe 3? It's in the Owner's Manual.
  10. Gwynngal
    Gwynn's Island, Va
    Thanks! The battery I have was from the dealer whom I really respect. I had had a number of issues and they were the first dealer to put the old battery through a thorough test (under load?). I haven't had any more problems at all until I did this!
  11. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    This does not bode well if the HV battery is original.
    GOOD LUCK!
  12. bisco
    49,796
    i also meant that once the battery has been depleted, it may have suffered permanent damage. it is good that it's only a year old, and surprising that it didn't last two months. maybe the heat.
    but i would check the voltage every few days for a few weeks to make sure its holding
    Gwynngal likes this.
  13. Gwynngal
    Gwynn's Island, Va
    Thanks, I'll do that.
