Dead battery and clicking sound
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by aging-millenial, Jan 14, 2022.
  1. aging-millenial
    aging-millenial New Member
    Houston, TX
    2015 Prius c
    My battery dies if I don't drive it after 3-4 days so I probably need a new battery. I went to start it to see if it was dead and was about to jump start my car but there's a weird clicking noise from under the hood. Is it safe to charge or should I just leave it be?
  2. JohnPrius3005
    JohnPrius3005 Active Member
    416
    224
    California and Hawaii
    Do you have a charger?
  3. aging-millenial
    Houston, TX
    2015 Prius c
    I have a portable jump starter.
    49,397
    yes, safe to charge. probably a relay trying to close but the voltage is too low. charge it up and put a maintainer on it, even if you buy a new one
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You mentioned "jump start" and charging; two different things.
    It certainly would be OK to try and charge it with an actual charger since the current is limited.
    Jumping it from another battery or other high current "jump device" might not be such a good idea though.
    JohnPrius3005 likes this.
