Dead battery at dealer
Discussion in 'Gen 3 Prius Main Forum' started by drinksta, Aug 25, 2017.
  1. drinksta
    drinksta New Member
    Utah, USA
    Took in my 2010 Gen 3 prius in to the dealer today to get the airbag recall taken care of. Get dropped back home in their shuttle and get a phone call saying they can't turn on the prius and can't move it. They said they will investigate a bad auxiliary battery. I literally have had 0 indications of a bad battery. Seems like a big coincidence that this happens when I drop the car of for the free recall. Thoughts?
  2. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Does sound fishy BUT it is 7 years old, a lot for that little 12v. battery. What kind of treatment did you get previously from the dealer? If they've been good to you in the past I'd cut them some slack.
  3. drinksta
    drinksta New Member
    Utah, USA
    First time visiting the dealer. I've had the car for 6 months. Previous owner said they replaced the battery and they had it for 3 years.
  4. drinksta
    drinksta New Member
    Utah, USA
    Update: The dealer called me 2 hours after drop off and said that after jump starting the battery and moving the car out of the way they let it sit while they could get a technician to have a look at it. The technician said he jumped in and it started up right away and the battery is measuring 13.6v. Claimed it may have been a "computer glitch". I think the guy checking in the car didn't know how to start it.
    mypriuscious likes this.
  5. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    When they work on cars usually they leave the car doors open and the dome lights on, etc. The itty bitty 12v in the Prius dies quickly in these situations and most of these monkeys don't know enough or care enough to treat your car well. What do they care if your battery needs a jump because they let it die? Best case, they sell you a new battery now. Worst case, they sell you a new battery later after damaging this one.
    Lucifer likes this.
  6. JC91006
    16,937
    8,647
    I had this happen to me last time I went to the dealer, they blamed it on the service driver's not turning off the hazard blinkers and it drained the battery
  7. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    There are no rocket scientists working at a Toyota service shop.
    Johnny Cakes likes this.
  8. Mendel Leisk
    42,365
    Anytime people are working inside the car, recalls, tinting, detailing, they will leave the door hanging open. If they're really irresponsible they'll also turn it on to accessory mode, so they can have radio while they work. I think policy is going to come down the pipe, and it can't happen soon enough, that during any protracted interior work:
    1. They shut off all extraenious lights that have switches.
    2. For sure never turn it on to accessory and listen to radio.
    3. If possible hook up to a maintainer.
    4. Clamp the door switches, spoof a closed car. This hands down is the simplest.
    Maybe yes maybe no. I suspect they partially drained it, and got lucky with the jump and a bit of running. But it's still shite, and that 13.6 was just measured on the displays, with the car running, which means nothing.
    I would chalk it up to experience, since it's hard to prove. And get a smart charger asap (something in the 3~4 amp range), hook it up for a full recharge session. If you're really ambitious look into a digital tester like Solar BA5.
    CNYhybrid, fuzzy1 and JC91006 like this.
  9. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    I still recommend monitoring the battery condition for the next couple of weeks.
    While my 2010 was still on the original 12V back in May, I'd drive somewhere and parked the car and the door won't lock and the car won't start. If I let it sit for 5-10min and it would start right up. This happened randomly a few times within a 2 weeks period. I eventually replaced the 12V and everything is back to normal.
    When the battery is low, electronics do weird things.
  10. bisco
    52,880
    i would ask the dealer to go 50/50 with you on a new battery, because they just killed it, and your likely going to have trouble down the road.
  11. Mendel Leisk
    42,365
    Dealerships should have a pro-level tester, big brother to Solar BA5 style tester. It'll give you it's standing volts, and the Cranking Amps or Cold Cranking Amps, and a verdict: good, good-but-recharge or fail.
    If they don't have such a tester, maybe time to look for an alternate dealership, if that's practical. They're commonly referred to as "electronic battery tester".
    Clore Automotive
    #11 Mendel Leisk, Aug 25, 2017
  12. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Get a trickle charger and once a month charge at two amp till full
    #12 Lucifer, Aug 25, 2017
    Raytheeagle likes this.
  13. fuzzy1
    10,721
    Exactly. It is impossible for the 12V battery to put out 13.6V. That number is really the 12V inverter output while the car is 'Ready', the Prius equivalent to the charging system of a traditional car while the engine is running.
  14. bisco
    52,880
    shows you what dealers know about electricity.:unsure:
  15. paprius4030
    2,077
    296
    York,Pa.
    SHOCKING!!!!!!;) Sorry couldn't resist
    Mendel Leisk, bisco and Raytheeagle like this.
  16. drinksta
    drinksta New Member
    Utah, USA
    Thanks for the replies guys. I took the car home and the next morning checked the battery voltage. It is 12.3V with the car not on. Are there any other checks I can do on the battery to determine if it needs to be replaced?
  17. bisco
    52,880
    12.3 needs to be replaced. if you're strapped for cash, put it on a charger, or you can drive it around for 8 hours to charge it, but monitor it closely so you don't get stranded.
  18. spiff72
    spiff72 Member
    184
    37
    West Michigan
    What's the general consensus lately on replacement options for the 12v? OEM Toyota battery or Optima? I have read of some Optima failures lately, and the Toyota 12v has performed very well for me (and I drained it once over a long weekend by not fully closing the door, requiring a jump).
    My build date was June 2010, and i owned it since January 2011. The battery is (over)due for replacement. I checked the voltage on it (via the jump point under the hood), and it drops below 12v after just a minute or two with the car in "on" mode (not Ready).
    Even the typical Prius noises are sounding different to me lately (specifically the sound that comes from the rear of the car about 3 minutes after shutdown). Used to sound like a "whoosh-click", and now it is more of a weak "tick".
  19. drinksta
    drinksta New Member
    Utah, USA
    Just bought a new battery. Got this one: AutoCraft Platinum AGM S46B24R from Advance Auto Parts for $131.99 after their 30% off discount at the moment (finished tonight). Almost got the optima one but this one was $10 cheaper and has good reviews. Will let you know how it looks when I pick it up.
  20. spiff72
    spiff72 Member
    184
    37
    West Michigan
    I'm guessing you meant the 35% discount code? I saw that code earlier this week and added the Optima to my cart but never pulled the trigger on it. :)
