1. Keith Elkin
    Keith Elkin Member
    116
    32
    I have the Directed SmartStart / Viper car alarm in my car and a few times in my life it has alerted me that my car battery was low... When I checked the car it was fine.. it did it again today and when I checked it, the battery is dead... I can't even start the car...
    I just found instructions on how to jump it.. but it's in park, head-in my garage... how can you put a dead prius in neutral so you can push it out?
    -Keith
    #1 Keith Elkin, Jun 29, 2014
  2. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    Be _VERY_ careful in jumping a Prius - check the polarity of the batteries & cables 2-3 times before connecting them.
    Connect the cables wrong even for an instant & you could be out $5K or more for repairs!
    That said - The car is not going to move until it gets powered up.
    This means you are going to have to get a good 12V battery connected to it somehow.
    If you have another vehicle available & are mechanically inclined you could pull the other battery & move it to the Prius then jump it.
    Another way is with a portable "jump pack" - someone you know may have one you can borrow.
    I don't know if you bought a new "jump pack" right now (from a store) if it would have enough power in its internal battery without charging it overnight.
    After you get it jumped you need to get the battery tested.
    Since the battery is dead now I would suggest keeping the Prius powered up for at least an hour to get the battery somewhat charged.
    The alarm system may be dragging down the Prius battery, especially if the vehicle is not being used on a regular basis.
    I'm sure others will chime in.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    You need a battery charger or a portable "jump pack".
    Connecting either for a few minutes should give it enough juice to start.
    And with that extra alarm, you will need to change the 12V battery more often and should consider using a battery tender when it will not be driven for 3 days or more.
  4. Keith Elkin
    Keith Elkin Member
    116
    32
    Thanks for the quick replies. I actually use this car every day, it has 32K on it in just 15 months so idle time isn't the issue.. I'm not quite sure what is, it's strange... I used it today to go out for a drive, parked it, and 30 min later got the battery alarm. I just went out and bought a battery charger, I'm going to give it a try right now. I'm a techie so no issues with not knowing the proper polarity.
    Thanks
  5. bisco
    52,525
    just hook up jumpers from another car to the battery in the hatch, your golden.(y)
    xpcman and Mendel Leisk like this.
  6. Easy Rider
    982
    210
    N. Central Florida
    How about the proper capacity ? What kind of charger did you get ??
    You really should measure the resting voltage of the battery at a time when you get that alarm.
    There is scant little extra capacity in the 12V system (some would say it is deficient just with stock equipment) and your added alarm might be CAUSING most of your observed problem.
    Do you enable the alarm every time the car is not in use......like at home parked inside the garage ??
  7. Keith Elkin
    Keith Elkin Member
    116
    32
    The alarm is passive and arms automatically, a car alarm is going to have the same load regardless if it's armed or not. I've had the alarm since day one so I doubt that's the cause, though I'm sure it's not making matters better since it's an additional load.
  8. Easy Rider
    982
    210
    N. Central Florida
    I think you will find that the load is MUCH less while it is not armed.
    I wasn't necessarily suggesting that it is the cause........but you need to know what the load when armed IS before making that call.
    Something has to cause it to arm. What is that.....doors locked, absence of a FOB signal or simply engine off for a set time ?
  9. Keith Elkin
    Keith Elkin Member
    116
    32
    It monitors ignition state and door lights to automatically arm, though I arm with a remote so it locks the doors. They just told me the battery tested fine. If it wasn't under warranty I'm sure I'd need a new battery :)
    In any case I'm going home and getting some sleep to fight off this cold..
    Thanks again everyone for your input
  10. Mendel Leisk
    42,042
    Look into a low amperage smart charger. And a digital multimeter to get a rough idea of battery status.
  11. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I found that aftermarket alarms, more particularly from DEI/Directed, eat batteries when armed. I have since stopped using it and use the key to lock and unlock.
    SCH-R530M ?
  12. Keith Elkin
    Keith Elkin Member
    116
    32
    Already have a multimeter, also have an ODB II reader, etc...
    Ty
  13. Keith Elkin
    Keith Elkin Member
    116
    32
    Oh... as far as the charger.. it's a smart charger and does 3A, 5A, 20A, and 70A charging... I guess I need to bring it with me along with an extension cord in case this ever happens again.. or at least a set of jumper cables.. ugh!
  14. kc410
    kc410 Active Member
    263
    255
    2010 Prius IV
    OR you could find out what is causing your dead battery problem, repair that & continue life not worrying about the vehicle.
    The oem 12V battery has enough capacity to get the vehicle to Ready for 4+ years before most ppl start having problems.
    It could last ever longer IF the vehicle is in daily use _constantly_.
    Abuse of the battery will drastically shorten its life!
    Abuse consists of running the battery down until it will not power up the vehicle (very bad), or adding any additional parasitic load to the 12V system so as to keep the battery from staying at the "close to fully charged state".
    Leaving the headlights on after the Prius is powered down puts an extra discharge on the 12V battery each time it occurs.
    Anything that draws power from the 12V when the car is not in Ready state must be recharged into the battery the next time it powers up.
    Even with no obvious abuse of the 12V system it is possible that the Viper alarm has always been a significant load to the battery. Now with a couple years on the battery it has lost some capacity & is going flat where 6 months ago it might just register a low-voltage alarm.
    Kim
  15. Easy Rider
    982
    210
    N. Central Florida
    Good post. The key phrase in that statement is "most people".
    And it doesn't have to be operated "continuously" to keep the battery reasonably fully charged, it just has to be driven every few days for about 10 miles or more.
    As in this case, there probably is a real "cause" of the problem.
    In most cases it appears to be useage patterns more than anything "fixable".
  16. Mendel Leisk
    42,042
    ^ Yeah, 12 volts don't die if not driven daily. Twice weekly, for example, would be fine. Try to consolidate your errands and trips, make the use count.
