Dead Hybrid Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jodep, Apr 3, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I would hope in 165 pages it would have everything :).
    Just a bit of light weekend reading(y).
    SFO and Mendel Leisk like this.
  2. Mendel Leisk
    42,286
    The second gen Repair Manual is much more complete. I took a look at third gen Repair Manual for comparison: it does not go into anywhere near the amount of detail, regarding opening the battery right up, basically just what's needed to swap batteries. Which is ok I guess, if you're just swapping batteries. The illustrations and degree of detail in the second gen Manual are much better too.
    Raytheeagle likes this.
  3. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    When I spent the $15 for a 2 day subscription to tech info, I was a focused lad on the 2010 Prius and 2017 RX450h ;).
    Now having time to review the results, I’m noticing similar facets:(.
    But the bulk pull is done and if needed, I can go back for a more focused search:).
    Seems like certain facets should be standard and could be reused:cool:.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    That is a resource people should be using.
    Has good info well laid out.
  5. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Fantastic. Thank You Mendel. This will keep me busy for awhile.
  6. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Yeah before working on HV it might be a good idea to read through some instructions. (Under $30 for access to Toyota tech info)
    Maybe get some protective equipment. (Life is worth the $60)
    Maybe get some code reading/clearing tools that can also read HV battery info. (Cost less than $75)
    Andyprius1 and Raytheeagle like this.
