dead. just dead. battery? or??
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by barbie.gee, Jul 26, 2012.
  1. barbie.gee
    barbie.gee Junior Member
    70
    Chicago, IL
    2005 Prius, not even 40k miles on it yet.
    I last ran the car on Monday, parked it in the garage, and hadn't been out til just now. I clicked the keyfob to unlock the doors, but didn't hear anything. Door was unlocked, so I got in. Dead silence, no cabin light, no dash lights, nothing. Fob in the ignition, NOTHING. Zero, zip, nada.
    It's been horribly hot here in Chicago for the past 3 weeks. I had the car serviced about 2 months ago, no indications of "time to replace..." anything.
    Okay, so what do I do now? I want to believe it's just the regular battery that starts the car, right???:)How do I begin to at least troubleshoot this?
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    If you turn on your side lights and get nothing then your 12v battery is dead. If it's the one that came with the car new it's long past it's useful life. The dealer can fit a new one or you can order and fit an Optima replacement also look out for a battery called Exide Edge I believe these are available in Chicago at Exide dealers and are the best deal for the Prius with a 4 year full replacement guarantee. Sorry can't give you prices as I am not in the US.
    Putting your battery on charge should get you going or you can jump start but be very careful to connect correctly or $thousands damage can be done. The battery is in the trunk in the passengers side rear corner.
    John.
  3. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    This sounds like a dead 12volt battery. If you have the original battery then it makes sense that it went bad. Five years is the average lifetime for most people. With your low miles I am surprised that it hasn't given you problems before. Some people have problems with the aux (12v) battery when they drive a little as you do. Battery replacement is best left to the Toyota dealer since the Prius uses a non-standard battery that only the dealer will have.
  4. ETC(SS)
    7,557
    My guess is that it's the aux battery. The 12v battery doesn't really 'start' the car, but it boots it up.
    The "jump" start instructions are in the manual, or on this forum somewhere. I don't have G2, and so I'm not going to guess how to do it, and you shouldn't listen to me if I try.
    Do you store your keyfob near the car when you park it in the garage?
    I've heard where this will cause the aux battery to go Tango-Uniform.
    The good news is that the car requires very little to (current) boot up. I've heard where people have done it with a 12-v DeWalt battery in fact. My personal theory is that you could do it with 9-"D" cell flashlight batteries. The thing is....look in the OM, figure out how to boot it back up, verify that the aux battery has gone to the Duracell Valhalla and get another one if that's it.
    There's a very slim chance that you zorched a fuse, but so far....this doesn't smell like that.
    Your car is old enough to need another Aux (12-v) battery if you've still got the OEM unit installed.
    Good Luck!
    usnavystgc likes this.
  5. barbie.gee
    70
    Chicago, IL
    We do have a service out here that will come and do the work on-site...
    A tow to the dealer will stink, but there it is. What's the consensus then on a "knock off" battery vs. going Toyota true blue?
    JMD likes this.
  6. Britprius
    5,194
    1,922
    Sorry not true Optima and Exide both do a direct replacement battery for the Prius. The Exide is fairly new on the market so supplies are limited.
    I will post part numbers shortly.
    John.
    barbie.gee likes this.
  7. Britprius
    5,194
    1,922
    The (knock off batteries) are superior to the OEM battery from Toyota but if speed is important Toyota will probably be quicker.
    John.
  8. xpcman
    1,302
    295
    The poster has a dead battery and needs to get the car running. He/she probably can't wait. Probably the only quick source for a battery is the dealer and even then the local dealer may not have a battery in stock.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I recommend the superior Optima battery. They offer a direct drop in with correct posts. They are sold at some Auto Parts Stores and also at all Batteriesplus. $ 180 out the door last I looked.
  10. richard schumacher
    7,686
    1,067
    United States
    Note that the 12V battery is needed only to *start* the car, not run it. If you can get a jump you can drive it completely normally, until you shut it off at a dealer or other battery seller.
  11. barbie.gee
    70
    Chicago, IL
    thanks John for this info. I Googled for both Optima and Exide, and there are a few Exide distributors in and around Chicago proper. I'm in the city. The Optima stuff seems to ship from California, while Exide may actually have a plant here in Illinois.
    I only wish I had a battery charger! My boyfriend has one, but he's over an hour away... I'm going to ask the neighbors. It would be so much easier if I could drive to get the battery installed somewhere...
  12. barbie.gee
    70
    Chicago, IL
    I have low mileage, but I put on some good highway miles a few times a month, so maybe that's why the battery hasn't really given me much trouble til now.
  13. barbie.gee
    70
    Chicago, IL
    Couple things;
    I don't have the "smart fob", just a regular fob that locks and unlocks w/ a button press, not the proximity sensor thing.
    Wouldn't you know I backed into the tiny garage, so a jump start's going to be a PITA, if I go that route. I'll look at the fuse box once I look it up in the manual.
    thanks!
  14. barbie.gee
    70
    Chicago, IL
    Well, I can wait "a little". Living in a big metropolis gives me access to public transit, and I can even ride my bike til this is fixed, although with the heat cycling is kind of brutal. I may end up ordering the battery from the dealership if I can't get another kind in a few days, but I absolutely HATE the nearest dealership. They've tried upsells on me, and I really dislike giving them any business!
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    There is a Starting point under the hood, so it is not bad that you are backed in. Be very careful jumpstarting, it is a expensive mistake to do it wrong If you are going to have the dealer change the battery, I would have them tow it.
    http://www.toyota.com/t3Portal/document/om/OM47509U/pdf/5.pdf
    Three pages in, labeled page 243
    If you are going with a third party battery:
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 +
    or
    Toyota Prius Starting Battery - Exide Edge 51JIS Flat Plate AGM
  16. ETC(SS)
    7,557
    If it's going to be a PITA for you....it might also be difficult for Jimmy the Tow Truck guy.
    Mind you....Jimmy is a pro, and he/she probably has the right tools for the job (maybe/maybe not.....) however (comma!!!) it's your car.
    Nobody is going to care about it like you will.
    If booting the car up from a 12v source is inside your comfort zone, I'd try that first.
    If not....well.....Jimmy has to make a living too. ;)
  17. barbie.gee
    70
    Chicago, IL
    I'm confused about the different OEM aux. battery part number "w/ smart key" and "w/o smart key". My key is stupid, I have no GPS or Bluetooth, just the plain vanilla 2005 Prius. Are the batteries really any different? And why does the Exide spec keep mentioning "Requires Toyota battery tray/clamp assy P/N 74440-47020"? Isn't that what I have holding my current battery in place?
    For what it's worth, I had to open the hatch door via the back seat, man, that's a dumb design I hope they fixed in newer models... I hoped to see the part number on the battery so I opened the hatch and got down to the battery, but found that the clamp goes right over where I suspect the part number is. I don't have a ratchet set w/ an extension, so I may have to call on my brother-in-law, who has everything.
    After watching a few youtube videos on aux battery replacement, it's clearly a DIY thing. And, frankly, if it turns out that it's NOT the battery, well, it needed replacement anyway, is how I figure it...
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Toyota put in an even wimpier battery if you did not have the smart key, but both Optima and Exide replace them both with an even stronger battery.
    Optima has a good reputation and are available more places. Exide is new this year, and is available through Sears I think.
  19. richard schumacher
    7,686
    1,067
    United States
    The jump point is under the hood, so having backed into the garage is going to make a jump really easy.
  20. barbie.gee
    70
    Chicago, IL
    Oh, just thought I'd share this with you. I sent an email to one of the "we'll deliver and install" battery places, telling them I needed a "12v "auxiliary" battery for a 2005 Prius", and if he could get one and install it and I gave him my location. Here's what I just got back from him:
    "Hello your battery with installation comes to $449. My name is XXXXXX and i would perform your install. Thank you for contacting XXXX Batteries Inc. Please call me if you would like to set up an appointment."
    HA HA HA. Did I mention that I'm both handy AND cheap??? Should I counter with "too high. How about $250?"
    :p
