Dead Prius plug-in
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CarmelPrius, May 27, 2015.
  1. JC91006
    16,936
    8,647
    Can you leave the car running and have it plugged in at the same time? To no waste fuel and charge the 12v?
    52,855
    no, it won't start if it's plugged in, and won't charge if you plug it in when it's in ready.
  3. iluvmacs
    iluvmacs Member
    280
    104
    Madison, WI, USA
    The 12V battery charges while the HV battery is charging anyway. But of course to start the HV battery charging, the 12V system has to be good enough to get it going... :)
    52,855
    good point, i hadn't thought of that.
  5. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    The Toyota dealership checked my battery, and said it was A ok. If it had failed, it would have been under warranty. So, the moral of the story is, make sure you close the hatchback!!!!
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Another moral - keep the manual handy.
    BTW I think the car will beep on you if you try to lock it when the hatch is not completely closed.
  7. Mendel Leisk
    42,345
    You can switch off the hatch light. Cheap insurance, who needs lights.
    Birthday/XMas suggestions:
    and:
    Much better in the long run than this:
  8. ETC(SS)
    7,555
    The Prius has a very puny battery, because you can start one with 9 flashlight batteries.
    After all.....you're not really 'starting' the car, but rather booting it up.
    Make sure the AAA people know how to jump start the Prius, before you set them loose inside your engine compartment.
    ---just sayin.
    You might want to consider one of these:
    Three pocket-size jump starters - CNET
    Good luck!
  9. Mendel Leisk
    42,345
    Is it just me: I have this picture that the AAA guys are going to show up with...: AAA batteries. Yeah, just me. :whistle:
    iluvmacs, giora and bisco like this.
  10. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Or change the interior lights to LED. Battery will not drain overnight maybe even two days.
    roflwaffle likes this.
  11. ft3sfty
    ft3sfty Junior Member
    Martinez
    2015 Prius Plug-in
    Has anyone successfully changed all their interior lights to LEDs? If so, did you keep the same color temperature or are they bright white LEDs? Know of bulb size? That's a great thought.
  12. hill
    9,038
    the thing is - the battery needs a load on it to more accurately determine its health - and a volt meter can't provide that.
    Once the Prius' 12v aux batter is allowed to drain flat - you CAN charge it .... BUT ... being that it's a pathetically weak 12v battery to begin with - it's just a matter of time before you realize that draining it causes it to be mortally wounded. It ain't no deep cycle marine configuration - and many a pc member (that has done the same thing - including yours truly) can tell you that generally the best thing to do is just replace it.
    yea - you're not the 1st person (including yours truly) told by the dealership, "no warranty claim necessary .... have a nice day!!" Then in either a few weeks or months ... warranty expires ... and you find your self unable to start. But you never know ... you may get lucky. As Clint Eastwood once said, "do you feel luck? ... well, do ya ..... ? " If your aux battery was only drained for a really really short time - you may get lucky.
    #32 hill, May 29, 2015
    j12piprius likes this.
  13. bisco
    52,855
  14. Windhorse23
    Windhorse23 Junior Member
    25
    Felton, CA.
    Hi all--I'm a new happy owner of a used 2012 PIP. Not so happy tonight trying to charge the 12 v. battery that died because I apparently left my lights on. Doh. I don't have a charge station, so engine has been running for 30 min. after jump-starting. I was told 30 min. is enough, but I'm skeptical, esp. seeing that someone on this thread said that draining a Prius 12 v. can inflict a mortal wound. I purchased an extended warranty, so hopefully that will be covered. But meanwhile--advice on charge time? Feels too dangerous to drive in this CA. storm in mountains, so just running the engine while I dry off inside. :) Thanks!
  15. bisco
    52,855
    welcome!
    it needs 8 hours to charge from the engine. but it also charges when plugged in.
    Windhorse23 likes this.
  16. Mendel Leisk
    42,345
    Your best bet would be smart charger, 4 amp range. It'll probably take about 8 hours. Or as much as 12 hours.
  17. Nougatti
    Nougatti Member
    119
    59
    Norway
    So many jumping tips and shenanigans on here when the PiP charging cable charges the 12V as well...
    iPhone ?
  18. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    20 minutes is enough. 30 minutes if you're paranoid. If 30 minutes isn't enough then it's time to replace your 12v. I'm carrying a portable battery jumper. Charge it once a month and toss in the trunk.
  19. bisco
    52,855
    see post #35.
  20. Windhorse23
    25
    Felton, CA.
    Thanks, all! Helpful community. Bisco--8 hrs w/engine running to charge the 12 v.? I left engine running a little over an hour in park, and it started up, but don't know if that means it's fully charged; haven't driven yet. Since I don't yet have a way to plug in the PIP at home, I like the idea of a portable battery charger (I take it that's for 12 v. only), but the Geico guy's portable didn't work. Had to use jumper cables. Not sure if that's a sign of mega-drained battery or indication it's on its way out.
