Deadly CO Generators vs Prius Inverter
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Dec 24, 2012.
  1. bwilson4web
    16,533
    I went looking for carbon monoxide risks at the CDC and found:
    • portable generators
    • boats
    • furnaces
    I found one report on vehicle risks:
    Source: http://www.cdc.gov/co/pdfs/veh_co_abstract.pdf
    I am especially impressed that suicides are failing because it is so difficult to get enough carbon monoxide to kill themselves.
    Now I understand there are folks who honestly believe standalone generators are a great idea. But the Center for Disease Control has a different point of view that lists them as a real, carbon monoxide hazard.
    Having gone through over four days of Prius powered, power outage, we know:
    1. portable generators are noisy
    2. generate hazardous levels of CO
    3. require frequent refueling
    4. return no other value
    5. go months and years without testing or maintenance
    In contrast, Prius inverter power:
    1. cycles and when the engine runs, Prius quiet
    2. very low levels of CO
    3. run days without refueling
    4. provides in-car power for laptops
    5. are used daily for commuting and errands
  2. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    Here are other pros and cons of a Pruis with a $200 1,000 watt inverter vs a $95 stand alone gas generator.
    Pros
    1. It will give a small amount of power for a couple devices.
    2. It sure beats not having power
    3. That is all I can think of.
    Cons
    1. It can only provide about 1,000 watts. This will not provide an enough power for a hair dry or microwave
    2. It cost 2X buying a off the self gas generator that can be converted to natural gas or propane for a unlimited run time.
    3. You have to run wires from a huge car that can only sit in the driveway or garage. A portable generator can be placed near the front door, back door, side of house. It is small.
    4. The efficiency of running a full car for a little 1,000 inverter has to be less than 50%. That is a huge waste of gas and money.
    5. If hooked up wrong it can hurt a $25,000 car.
    52,848
    even my 12 kw lp generator was required to be installed 20' or so away from the house to prevent co into an open window.
  4. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    A 1k power supply is likely not enough for most but doesn't a connection to the 12v allow for a 2k inverter? Surely for minimal camping or low demand home emergency needs that would be a lot better than nothing and safer and quieter than the stand alone generator.
    Is the higher watt inverter connection to the HV battery system too complex prohibitive for the DIYer? That would be like 5k right?
  5. bwilson4web
    16,533
    Welcome to the standalone generator thread:
    Now this is an approach that begins to make sense for standalone generators:
    Using a water cooled engine and running lines to a radiator-fan in the house and the first elements of co-generation are beginning. Better still, add a large battery array to buffer the energy and the engine need only run to replace charge with a substantial improvement in efficiency. Convert the engine into an Atkinson cycle or replace by diesel and another step improvement in efficiency. A Prius combines both a battery array and Atkinson cycle engine that runs only as necessary to maintain traction battery charge.
    Even so, the absence of a catalytic converter for gas and natural gas operated engines means CO is a real and credible risk. Even a diesel should have some sort of soot trap to minimize a known carcinogen. Air cooled and often with a minimum muffler, they make a racket. Yet the Prius comes with an efficient catalytic converter that all but eliminates the CO risk.
    I have no problem with standalone generator advocates having their own thread to discuss the technical aspects of their preferred solution. Heck, make the thread into a catalog of standalone generators. Things like transfer electronics and the mitigations to the health, safety, and noise issues are important and worthy of its own discussion. Distracting from the technical aspects of Prius-inverter installation does nothing to improve the experience of Prius owners looking at inverter technology.
    ftl likes this.
  6. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    But the Prius engine runs only when it has to charge the battery. A generator has to run 24/7.
    I used my Prius c with an 80 watt inverter after Sandy to run my steam heat, a couple of LED 60 watt equivalent lamps, my cablemodem, wireless router, VoIP phones and laptop. Used under a gallon of gas in 54 hours of continuous operation. See my more detailed post here.
  7. bwilson4web
    16,533
    There has been at least one successful installation but it is not portable. My technical interest is in configuring the MG2 inverter to provide house power. This potentially provides up to 18 kW (MG1 rating) of emergency power.
  8. SteveLee
    645
    180
    North Carolina
    I
    Bob, I appreciate the work and reports you and others have provided here on this benefit of our car. Being electrical knowledge challenged myself, it is most helpful in gaining a better understanding of the capabilities, process, and issues related to this function. I am also especially interested in the discussion of the portable aspects. With your list of uses for 1kw it sounds like it is much more capable than I originally thought. You saying your 1kw inverter will power all those devices separately, right? Not all at once.?
    I see different threads on how to put together a system to run off the 12v in READY mode. Is there a ready made system out there that just connects to the 12v? Is that even feasible?
  9. bwilson4web
    16,533
    Emergency power is typically limited compared to house power:
    Column 1 Column 2 Column 3 Column 4
    0 [th]watts[th]amps (110 VAC)[tr][td]1 000[td]9 A[tr][td]1 500[td]13 A[tr][td]1 650[td]15 A
    Source: Watts / Volts = Amps
    Whole house power will often include six or more, 15 A circuits. But in an emergency, the power is typically a fraction of one circuit so decisions have to be made:
    • light duty loads - lights, TVs, small computers, cable and satellite boxes
    • heavy duty loads (pick one) - fridge, small air conditioner, small hot plate, house furnace fan
    In an emergency, you'll be shifting the heavy load based upon the immediate need. The light duty loads are typically turned off when sleeping. So load management becomes part of dealing with an emergency or power outage . . . camping out at home.
    ftl likes this.
  10. fuzzy1
    10,706
    In the 1980s, I remember regional news reporting of about one death per year from parents discovering that their child 'sleeping' in the back seat was permanently asleep with CO poisoning. Those reports seem to have vanished.
    While I suffer from an inherited susceptibility to motion sickness, I now suspect that backseat CO was also a contributor to my own frequent childhood car sickness.
  11. bisco
    52,848
    i am not advocating one way or another, just referring to co issue you mentioned. generator was here when we moved in and we didn't know anything about prius capability. i do not like the fact that the gen has to run 24/7 anf uses about a gal./hr, so i shut it off when we go to bed. apologies for sidetracking the thread.
    bwilson4web likes this.
  12. bwilson4web
    16,533
    I understand small catalytic converters are becoming available for boating applications. How well they last absent the Lambda cycle (oscillating between lean and rich that helps scrub the surface) is not something I have expertise. But the CDC has some research showing significant CO risk reduction from such units in boats.
    That is two of us. In the winter of 1961, we had open flame, gas heaters that froze up the metal framed windows and almost wiped out our family. I was in the upper bunk bed and remember reaching our parent's bedroom and then the coldest air and a splitting headache. Carbon monoxide is deadly and even now, when I follow a 'fixed truck' with a modified exhaust, I soon find another route to avoid the smell and malaise.
  13. rcf@eventide.com
    173
    85
    Sedona
    Some time ago, mostly in response to people who expressed concern about carbon monoxide generated by the Prius, I did a bit of testing. The results are here:
    Carbon Monoxide
    Make of them what you will. I don't see it as a big problem.
    Richard
    b2j2 likes this.
  14. bwilson4web
    16,533
    Kudos!
    Richard is the first documented traction-battery to inverter experimenter. His extensive and well documented experiments are well worth the read!
    Merry Christmas Richard!
  15. fuzzy1
    10,706
    Home CO poisonings were such a problem in a widespread winter power outage here a few years ago that CO detectors become mandatory next week.
    Unlike other regions where near universal use of combustion appliances led to this regulation long ago, many homes here have no built-in potential source of CO. But so many people, primarily recent immigrants with poor English skills, brought barbeque grills inside for heating and cooking that we had a rash of poisonings. Apparently in Somalia, this sort of indoor cooking is standard practice. But these immigrants were accustomed to hot climate homes with slatted walls, probably with several air changes per minute. Do this in a home with one air change every few hours, and the results are deadly.
    But generators and other CO emitters also caused problems, and we have native speakers of gazillions of languages, so the local paper printed filled the top half of the front page with warnings in six languages. The county's Carbon Monoxide Facts warning page has 24 languages.
  16. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    It is my understanding that a generator running on natural gas or propane is not a CO threat unless you starve the intake. That's why they use propane or natural gas to power indoor forklifts.
    Keeping it away from a house is mainly in case it catches fire.
    My choice, if I lived in an area susceptible to hurricanes or earthquakes, would be a stand alone generator in a steel cabinet, set up to run natural gas (first choice) or propane (first choice in earthquake areas) and sited away from the house, of perhaps 10 kW capacity and 220V two phase, so it could run the refrigerator, freezer, and furnace. -Most- of the time natural gas won't be interrupted as it is underground. Sandy was the exception, due mostly to the fires and it being shut off. But if you were in that area your generator wouldn't have survived anyway. And neither would your Prius.
    You DO have to run the generator at least once a month to ensure reliability. A good excuse to have a monthly "emergency exercise" for the family.
    I have an emergency generator stored in the basement (without fuel of course). It has been unused for 15 years now. I pull the starter cord once in a while to ensure the oil keeps everything coated. I usually store fuel in the garage (detached) in the winter only. A power failure in our winter of more than about 12 hour duration would result in a plumbing disaster! In our case keeping "RV antifreeze" in the house to pour into drains (and toilets) to keep them from freezing is a good idea. But we have never had a power failure lasting more than a hour so we are rather complacent.
  17. El Dobro
    El Dobro A Member
    7,106
    3,282
  18. fuzzy1
    10,706
    A cracked head will also release CO. That is how a malfunctioning propane-powered ice resurfacing machine, at an ice rink in my community, sent 67 people to local emergency rooms. CDC-MMWR: Carbon Monoxide Poisoning at an Indoor Ice Arena and Bingo Hall -- Seattle, 1996
  19. bwilson4web
    16,533
    Less bad but not totally risk free. But the ones I've seen are running over a thousand dollars and there is still the installation. Personally, as a cogeneration system, one that provides HVAC from the waste heat, it makes a lot of sense.
    No problem as long as it exercised. In contrast, the Prius is often used daily and can provide evacuation transportation.
  20. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
