Deadly CO Generators vs Prius Inverter
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Dec 24, 2012.
  1. rcf@eventide.com
    173
    85
    Sedona
    There are "booster" devices available, typically for communications equipment, that will add a volt or two to the output of a lead-acid battery so that the equipment gets closer to it's nominal 13.8V desired power input. This would be a lot more efficient in your case than buying a new battery, using an inverter to get AC, and then using the AC to power your boiler ignition system. An even better solution would be to contact the ignition system manufacturer and ask them if there's a dropout adjustment on their product. It should be about 10V; 11.5 is much too high for something designed to work on 12V.
    Richard
  2. hlunde
    hlunde Member
    419
    75
    This issue was that the inverter would drop out at reduced battery voltage. This makes sense since the typical use of an inverter is for something like powering a laptop and the alarm would warn the user to start their car well before the battery become discharged. One cannot use DC to directly power the boiler igniter since there's a high voltage transformer that provides a spark.
  3. bwilson4web
    16,514
    I am curious, does the heater system have fans that need to exchange the warm air with cold air in the living spaces?
    Even if it is a radiator-water based system, I would still expect some pump power needed to move the water/coolant through the system. Of course if it uses steam to transfer heat and gravity return, no pump would be needed.
  4. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Gravity based hot air systems exist (generally very old systems).
  5. bwilson4web
    16,514
    Oh Lord, I'd forgotten about them. Built into the floor with a metal 'grill' on top, cold air comes in from the side and hot air goes straight up to the ceiling:
    • stand on the grill and cook - lot of fun with snow encrusted shoes as the pieces fall off and sizzle
    • stand to side and freeze
    • put a baking pan to increase humidity
    Well better than the standalone, wooden stoves of my farm relatives but that is another story or another day to bore the young. . . . and one was coal fired. I wasn't sure of the source but I do remember finding 1-2" coal seams as a kid roaming the farm(s).
  6. Corwyn
    2,171
    659
    23
    Maine
    They aren't all that badly designed. I had two in my former house, the heat was quite even. My current heat is provided by the standalone wood stove you malign, which is great. Nice even heat generally, but a place to go to warm up when I am feeling cold. Very cheap (about $1600 per decade), but a bit work intensive.
  7. bwilson4web
    16,514
    Well they say (and I've comfirmed) wood warms you up twice:
    • once when you cut and stack it
    • again when you burn it
    DadofHedgehog likes this.
  8. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    And one more time when you carry the wood to the stove. But a wood stove (I have a fireplace insert) is a great excuse to have one room that is warm in these energy conscious times.
    JeffD
  9. Corwyn
    2,171
    659
    23
    Maine
    I submit that if your wood stove only heats one room, you are doing it wrong. Mine heats my whole house, at about a 40% duty cycle on the coldest days (i.e. 1 fire for 8-9 hours will keep it warm when it is below 0°F outside).
  10. jdenenberg
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My fireplace insert is a small, efficient, one from Quadrafire that supplies heat to the whole house, but my recreation room (The room where it is located) gets nicely warm so that convection (and some fans) distribute heat to the rest of my home. Our oil furnace then only runs intermittently on cold days when I fire up the wood.
    JeffD
  11. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    "Hydronic" is the key word in the OP's description. I've had both hot water and steam hydronic (aka "gravity") systems; no circulators or pumps are used.
  12. Corwyn
    2,171
    659
    23
    Maine
    'Hydronic' in heating contractor speak just means 'water' (hot or steam). Gravity fed is another issue.
  13. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Yeah, good point. I've never had one of them new-fangled hydronic systems with circulators, and I'm assuming the OP has a similar (old) system to mine, which will run on 20W or less.
  14. hlunde
    hlunde Member
    419
    75
    In my case, it's a hydronic boiler with (4) zones. If you just open up all zone valves manually, there's quite a bit of gravity flow. The duty cycle is of course 100% unlike a thermostadt-regulated flow. In fact, with this arrangement the master bedroom got too warm so I had to throttle back one of the zone valves. I'm in NJ, and the boiler's in the basement which does help. Boiler is not ancient --- circa 1991.
  15. Daddy Dave
    Daddy Dave Member
    94
    39
    Sheridan, WY
    Finally - something that I know about! I design emissions control systems for natural gas engines (compressor stations on gas wells). Starving the intake would make the air/fuel mix more lean which reduces CO but spikes NOx through the roof. With a correct AFR, these engines can run very clean with low CO and NOx simultaneously.
  16. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Not sure someone mentioned this or not, it's not very good for a car's engine to idle for a long period of time. It was not designed to idle unlike generator's engine.
  17. Daddy Dave
    Daddy Dave Member
    94
    39
    Sheridan, WY
    Whoops - I interpreted this incorrectly. Starve the system for Air and AFR is rich which is high CO. Starve fuel and NOx is high. In my defense, the systems I deal with on a daily basis are controlled by fuel, not air. My reference is fuel starvation, not air starvation!
  18. rico567
    rico567 Junior Member
    Central IL
    In your area, I'm surprised they didn't make you locate it in Newton. Here in Central IL, we've more options. A Prius is of no use to me as a standby generator, because it has to go into action even if we're not at home. So- a Generac 5871 running off the 1K gal LP tank in the back yard was the solution we adopted. The generator sits about three feet from the house (new standard is 18" from wall), and exhausts past a window four feet away. Secret to the window not causing a problem with the generator exhaust = close the window. Some regulations make sense, some are just bureaucratic lunacy.
    Also, a note about standby generators and exercise- they do it automatically, once a week, and let you know if anything goes awry.
  19. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    This solution does not work for me either. I went the route of a natural gas powered 10K generator for $1,099.00. I can power the entire house including central air. It can run indefinitely and I when I need to use the car to go somewhere the house keeps getting power.
  20. bwilson4web
    16,514
    The Prius engine cycles:
    It only runs the engine long enough to generate the existing and replacement charge. Once the traction battery is back to normal state of charge, the engine shuts down and the stored traction battery energy powers the inverter.
    ftl likes this.
