Dealer-added fog lights
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Dare, Aug 19, 2013.
  1. Dare
    Dare New Member
    Hi all,
    Not sure if this is the right forum for this. I've been considering a Prius for a while, but the colour/package combo my wife and I want is not available on our side of the country. BOO! :(
    Our dealer DOES have a moonroof package available in the colour we like, but we'd be giving up:
    • fog lamps
    • LED headlamps
    • 17" alloys
    I asked the dealer about adding fog lights to the moonroof Prius, but was told they would need to replace the grill and it would be over $2000. This seems a bit steep when I'm seeing DIY fog light kits for $100-$200..?
    I'm pretty new to all this, so I was just wondering if all this sounds accurate, or if perhaps I am being railroaded somewhat.
    Thanks! :)
  2. Dawit
    Dawit Active Member
    209
    137
    Phoenix, AZ
    You'll need a new lower grill with the foglight opening cost less than $100 and the foglights about $80 if you do it yourself.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Why not tell the dealer to get off his arse and ship the car you want from where ever in the country it is? He's trying to push his own inventory on you, but you can get one from anywhere.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's not as simple as adding fogs to the 2010-11, but it's significantly cheaper if you do it yourself or take it to a local shop.
    Not all countries have their own Dianne Whitmire.
  5. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
    I just added the foglight kit from juicedhybrid.com, it was $300
    Galaxy Note 8.0
  6. SteadyEddy
    SteadyEddy Junior Member
    28
    Western Florida
    Tekjunke, that's good to know. Could you enlighten us on how you installed them. A picture or two would also speak volumes. I too would like to add fogs to my 2013, but I'm not willing to spend a ton. Any info would be great. Thanks
  7. pauln64
    pauln64 Junior Member
    77
    Macon, GA
    if it's a 10 or 11, adding the fogs will be easy since it's replacing the part where the turn signal is located.
    12 and up is a little more involved.
    with fogs
    w/o fogs
  8. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
    Thanks for posting the pics, I completely forgot.
    The install was a bit involved, it took 4-5hrs working carefully and slowly. All of the install docs can be found on Juiced Hybrid.
    (Do yourself a favor while you have the front bumper cover off, replace the horns too)
    Here is the kit I ordered:
    2012 & 2013 Prius Fog Lights - Prius Fog Lamp Kit - Pair of Prius Fog Lights: Juicedhybrid.com
    Here are the instructions I followed:
    http://www.juicedhybrid.com/v/vspfiles/assets/images/2012-2013%20prius%20fog%20light%20installation.pdf
    http://www.juicedhybrid.com/v/vspfiles/assets/images/prius%20i-sheet_fog%20lamp_6-8-2011_color.pdf
    Michael M. Maslowski likes this.
  9. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Why people? I found the fogs useless, and don't look that good. They make the front end of the car look like a catfish.
    I can see on the 10/11, they fill the gray matter in the turn signal housing, but on the 12+, a bumper cover w/o the fogs look cleaner.
    As a side note, the 12+ use 19W fog bulbs, talk about useless... :(
    xpcman likes this.
  11. pauln64
    77
    Macon, GA
    I thought about putting fogs on mine...after I put the HID's on, don't even need them.
  12. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
    The kit I purchased had H11 bulbs installed. I replaced with yellow piaa bulbs to help with out torential rain here in So Fla. They are almost too bright to drive with on a regular basis so I only use them for rain.
    Galaxy Note 8.0
  13. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    You paid $300 for a kit with H11 halogen bulbs? :eek:
    I thought they were HID based on the price. Man you got ripped. Shouldn't have to pay more than a little over $100 for halogen foglight kit, maybe even $50.
    SCH-I535
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    But it comes with the new lower grill for the retrofitting, doesn't it? If so, that needs to be factored in and wouldn't be as cheap as $50.
  15. pauln64
    77
    Macon, GA
    ouch!!! I paid $35 for mine from hidextra (50% special at the time) with a 55w ballast.
  16. xliderider
    8,140
    3,278
    Honolulu, HI
    But that was just the bulbs and ballasts, right? Not the foglight housings and shrouds?
    SCH-I535
  17. pauln64
    77
    Macon, GA
    that's correct. I had contemplated on adding the fogs. After I put the HID's on, I didn't feel the need to add it. I did have a 2011 w/ fogs, and I could notice the difference w/ and w/o the fogs. Then when I got the 12, same thing until I put the HID's. These HID's are brighter than the factory HID on my Z06.
    Also, I do agree with the comment above that the fog light placement is not very functional. I felt that the 10/11 placement was more useful.
  18. Tekjunke
    Tekjunke Member
    77
    28
    South Florida
    The kit that I ordered had a Toyota factory lower grill, Toyota factory housings, aftermarket wiring harness, aftermarket switch, relay, hardware.
    I priced out the items separately, it was close to the $285 I paid.
    The fogs are low to the ground, but they are ridiculously bright and make quite a large difference on dark roads around here. I guess I need to try to take some pictures to get my point across...
  19. xliderider
    8,140
    3,278
    Honolulu, HI
    Not sure if this kit includes the lower grill, but it says everything needed is included. It doesn't even have a picture of the correct 2012/2013 model:
    http://pages.ebay.com/motors/link/?nav=item.view&id=171096024281
    But it is genuine Toyota parts, same as port/dealer installed. Price is $100 less than what was paid above.
    SCH-I535
  20. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    That's the Prius c, you know the compact Prius...
