Dealer changeable settings? (reverse beeping etc.)
Discussion in 'Gen 3 Prius Main Forum' started by GrumpyDave, Jan 20, 2013.
  1. GrumpyDave
    GrumpyDave Junior Member
    27
    Phoenix, AZ
    I about *this* close to buying a new Prius Three. I know I'll want the dealer to change the reverse beeping for me and I've heard something about the seat belt warnings too. Someone here suggested in another thread that a buyer should get a list of desired changes in writing during the sale so they won't be charged later by the service department. Sounds like a good idea, but I don't know what can be changed so I don't know what I might ask for. I've been searching the forums but can't find a concise list of common dealer changeable settings. Anyone have a link or a list?
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The owners manual has an entire chapter on customization items. There used to be a pdf version on this site, but it was apparently removed. You might try searching the web for a copy.
  3. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    I think by the 2013, you can do much of this yourself. The first G3s required the dealer's laptop. I got some dealer "push-back" on changing the seat belt alarm from continuous to one beep. They said I was overriding a safety feature but they did it anyway. The light still goes on, but there's just one beep in case a passenger unbuckles a belt. Yes, the continuous beeps for reverse were really annoying too. Glad I got that turned off.
  4. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    F8L likes this.
  5. GrumpyDave
    27
    Phoenix, AZ
    Thanks for the replies, I found what I needed in that owner's manual chapter. I didn't realize they would actually list those things that only the dealer can change and especially those that potentially deal with safety issues. After looking over the list the only two I want to ask the dealer for are the reverse and seat belt warnings.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The next challange is getting the dealer to do it for free. Make sure to get an agreement defore siging the dotted line.
  7. PriusTime
    PriusTime Junior Member
    53
    You will probably have the dealer do this for you, but both of these settings can be changed with a $15 OBDII bluetooth adapter and a smart phone in about 5 minutes if you ever need to go that route. I would do it for free for anybody that's near me.
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    My car is a 2010 and these things have to be done by a dealer with Tech Stream software or in the case of the reverse and seat belt beeps with a Scan Gage if you plan on buying one. Your 2013 may have the option of doing some of them yourself without a Scan Gage.
    There is no safety issue although some dealers will tell you there is because they don't want to do it, or don't understand what is done. The seat belt beeper, as delivered, will beep continuously if a belt is undone. A real pain if you have a dog in the passenger seat or even a heavy package. When the seatbelt beeper is reprogrammed it will still beep for 6 seconds when the car is first started and then shut off (the warning light stays on), this is what is required by the NHTSA. The extra continuous beeps are just included by some car manufacturers to keep us "extra safe".
    The reverse beep, as delivered, beeps continuously when in reverse, when reprogrammed it will beep once when you select reverse. Some people like continuous beeps, I consider them an unwanted distraction. It doesn't warn pedestrians because it only beeps inside the car.
    Another item you might want to have changed is the headlight off timer. As delivered it turns off the headlights 30 seconds after the driver's door is opened with the car turned off. It can be reset to 0 or 60 seconds.
  9. Beel
    Beel Junior Member
    Sorry to learn that I can't disable the reverse beep on this car. I guess I'll live with it till I go in for first service. It's hard for me to see this as a safety feature -- I've always had to be aware of what gear is selected in every other car I've driven without a beep to warn me. And none of those cars displayed it and turned on a backup picture. Makes it kind of very noticeable that you've selected "R". I was actually startled the first time I put the new car in reverse. I had completely forgotten about the annoying beep. The seatbelt beeps don't bother me -- I and everyone who rides with me will wear a seatbelt.
  10. JimboPalmer
    12,470
    6,866
    Greenwood MS USA
    If you included a location in your info, you may find a fellow driver who can use his OBDII device to set the reverse code.
  11. pichner
    pichner Metallic Maniac #001
    66
    Minneapolis, MN
    I am going to pick up a ODBII BT adapter and was hoping to monitor/make changes with my iPhone. Amazon has the adapters for cheap too.
  12. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    These are my personal settings. I did change the reverse from continuous beeping to one beep. I left the seat belt warning on because I thought this was a good safety warning system. I will on my next dealer visit have the smart key change from drivers door to all doors opening.
  13. pichner
    66
    Minneapolis, MN
    You can change that on your own, one of the threads on here has the info. I think you just hold down both the lock and unlock buttons (on the keyfob) for like 4 seconds until you here a beep (you cant be in the car when doing it).
    JMD likes this.
  14. Beel
    Beel Junior Member
    Somehow I hadn't noticed your post til Pichner quoted it. This sounds like the way to go for me -- I always prefer DIY if possible. I don't own a smart phone (believe it or not) but I certainly have BT capable laptops. Are there special drivers or software required?
  15. pichner
    66
    Minneapolis, MN
    As you as your laptop has BT you shouldnt need a driver. You just need an app on you rPC to connect to the hardware ODBII BT plugin. Look up Dash Command, i see they have a PC app you should be able to use to pull data over.
  16. Beel
    Beel Junior Member
    Thank's -- found some discussion in the audio/electronics forum. Thanks for pointing me in the direction.
  17. GrumpyDave
    27
    Phoenix, AZ
    Agreed on a car today, pick it up tomorrow. I told the salesman I wanted the two things adjusted before I take delivery and he said no problem. I'll double check when I see it tomorrow.
    I was reading about using the OBD scanners and it seems like Torque on Android is the way to go. Unfortunately I don't have an Android device much less a cell phone. I do have an iPad but I haven't seen any specific confirmation that it will work and what I would need. Apparently using Bluetooth to connect to the scanner is an issue with iOS. Anyway, I may look in to it further but to be safe I'll have the dealer adjust the two most important settings.
  18. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Asking about the dealer's policy before buying the car is always a smart idea. I believe many will be reasonable. If resistance or charges are encountered make free changes a condition of sale. Since the cars are sitting on the lot I am sure an attitude adjustment will happen before they let a sale walk.
    If they are going to treat you like crap before they have your money their attitude won't change after they have your money.
  19. Beel
    Beel Junior Member
    Yes and no. You're dealing with two different departments. I've never had anything but a good experience with my local Lexus dealer's service department, but my recent experience with their sales dept was a misery. Although I have to agree that any issue you have tends to be a reflection of what is acceptable to the dealership's management.
  20. priusincc
    priusincc Member
    332
    16
    NV
    I have tried both local dealers to disable the continious reverse beep. Neither would do it. They act like it isn't possible. They either don't have a clue; don't want to take the time; or don't want the liability.
    I'll have to renew my efforts at the 10K service.
