Dealer Damage to my Prius Dashboard
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shimma, Dec 20, 2005.
  1. hv74656
    hv74656 Member
    145
    Morro Bay, CA
    Try the plain old multi surface cleaner they sell at Target. It’s orange and in a spray bottle with a dog on it. Spray the stuff directly on the mark and let it sit for about 3 seconds. Then scrub it with a soft sponge or cloth. I use it in the Camry and it is able to get the sun baked grime off the shifter, so it should work for talc powder. I think it costs six dollars. It's like armor all without the greasy feeling and surface damage.
  2. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    The reasons I like <a href=\'http://www.303products.com/main.php?infopage=protectant\' target=\'_blank\'>303 Protectant</a> so much are a little goes a long ways, it provides UV protection, and it's antistatic, in addition to the deeper color it gives the dash.
    Streaking problems are usually caused by using too much, and easily fixed by re-wiping with a moist cloth. The textured surface on the upper dash on the 2004/5 and overall on the 2006 should show less streaking than the smooth plastic on the lower dash of the 2004/5.
    Plastic is composed of polymers, long chains of hydrocarbons linked together. UV light, which is everywhere in the day, even coming through glass, can break the bonds of those hydrocarbon links, causing the plastic to age and the surface to deteriorate. The UV protection in 303 slows down this natural process.
    Another feature of most plastic is that it readily takes, and sometimes generates its own, electrostatic charge. Little particles of dust, dirt, diesel exhaust, and general gunk, can become charged, too, and attracted to the plastic. If you just clean the plastic, you can remove the gunk, but new gunk is likely to be re-attracted. The antistatic compounds in 303 tend to conduct the electrostatic charge away, and if the plastic has less charge, charged gunk is less likely to stick to it.
    I have no first hand knowledge of Mother's Back2Black, so I can't comment on how well it works, or doesn't. What I think both Galaxee and I agree on is that a goopy solution like Armor All actually tends to gather more gunk.
  3. xbdude
    xbdude opticat
    168
    North Central Florida
    The "tape" idea mentioned in post no. 4 works well. Just be very careful, and do not use a lot of pressure.
  4. shimma
    shimma New Member
    34
    I'm cautiously gleeful that I've repaired my dealer damaged dashboard with 303 Protectant. The stuff isn't cheap- $15 for a 16 oz spray bottle- but looks like it picked out all those tiny pieces of talcum powder that nothing else I tried could.
    Thanks to all, particularly Bill Mercant, for your thoughtful suggestions. :)
  5. Bill Merchant
    4,096
    81
    You're very welcome! I'm glad it's working. The great thing about PriusChat is that we can learn from each other and all benefit. Try the 303 on your tires and the black "skirts" on the back.
