Dealer oil change error
Discussion in 'Gen 3 Prius Main Forum' started by subjective, Mar 25, 2012.
  1. subjective
    subjective Member
    203
    30
    In our case, our Toyota dealer has what I consider an excellent service mgr, excellent service writers, and excellent master mechanics. They do have a high turnover of oil change personel. I take my own Mobil 1 in quarts and only give them 4 qts for 2 of our cars, which spec. out for for just a little over 4 qts. In this way they can not over fill, which is a common practice from my own observations. In the last 5 yrs, they have neglected to put in the oil I provided for them. Once the oil was simply left in the car, unopened. The other two times I was able to convince service that the oil level was overfilled and over the level of the 4 quarts in which they changed the oil at their expense. The last time was just last week. I noticed the oil level was a little high but not much. Then I noticed the service panel droped down, so that made me check the oil more closely. Checked cold, I inserted the dipstick into a qt of Mobil 1 0 w 20 up to the full mark in which the oil ran off the end of the stick like water. When I did the same with the cold engine oil, just a drop formed, but it did't run off. This incident occured with our Scion XB but it could have been just as easily been our new 2011 Prius lll. The oil in the XB had less than 50 miles on it. Perhaps someone else has a better solution to this problem.
  2. Former Member 68813
    3,524
    983
    US
    Change oil itself. I had nothing but problems with dealer oil changes.
  3. krazypriuslady
    232
    metro Wash DC
    Some of don't have the tools or experience or courage
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    My advice: Either let the dealer handle everything or change the oil yourself.
  5. subjective
    subjective Member
    203
    30
    With due respect, The reason I started to provide the oil in quart containers, and only enough so they could not overfill, is because they were careless with the bulk oil fill, and to insure that I got the Mobil 1 in 0 w 20., rather than some cheap contract non synthetic oil of an incorrect viscosity. For years I changed the oil and did some maintenance on all the family cars. I no longer care to do this.
  6. sooperedd
    sooperedd Junior Member
    48
    Colorado
    If you want something done right, sometimes you have to do yourself.
    You shouldn't have to, but in the case of dealership service departments, I've always thought why would I take it to the same place that tried to screw me in the effort to maximize their profit when I was purchasing the car?
    Do they have the same "maximize profit" attitude in the service department?
    I change my own oil, but for some things I will take it in.
    Find a good local garage and build a relationship with the owner/mechanics there. I've been taking my vehicles to the same guy for almost 25 years and have never had a problem; I will when he retires next year though. LOL
    mp3_e46 likes this.
  7. bisco
    52,855
    why don't you have a serious conversation with the 'excellent service manager'?
  8. WE0H
    WE0H Senior Member
    3,247
    528
    I will forever change my own oil. I don't care if I get two years of free this or that. They can keep it.
    Mike :)
  9. Brett.
    Brett. Junior Member
    134
    26
    My thoughts exactly. They give away 25k miles of free service, or 2 years.. but all it takes is 1 tech not paying attention to my vehicle to give me 10w30 oil, the wrong amount, scratch my car, dirty my interior etc.. save the headaches and do it myself.
    As for a reply to the original poster, you may seriously consider going to another dealer for service in your area if it's close enough. Apparently this dealer may have a good service manager but a bunch of C techs working on your car that you just spend good money on.
    When I dropped my subaru off for warranty repair, I wrote them a list of what to do and they stapled it to the work order. Perhaps you can write specifics down and they will attach it for you as well.
  10. TruSound
    TruSound Member
    246
    32
    The 818
    As far as I know the lot boys or a mechanic in training working for minium wage is doing these freebie oil changes, I wouldn't trust them with my lawn mower, these guys don't give 2 shits if they overfill your car, strip your drain plug or send you home with an improperly tightened oil filter.
    Inless your physically unable to do it yourself...do it yourself, you'll be much happier knowing it was done with with care.
  11. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I take Mobil 1 into my dealer, and was taking in the quarts and would only give them 4 quarts so they could not overfill it, and all was good. I would add the last half quart myself when I got home. WalMart started carrying the 5 quart jugs so I started using them and all was fine until the last change. I left the dealership and after a few miles realized the jug with the remaining half quart was not in the car so I pulled over and called the service manager. He said he had it and I could come back and get it but it only had about a cup left in it. He said the guy that did the change is the only one that works on the hybrids and he said he filled it but did not overfill it. I checked it the next morning so it was all drained down and sure enough, about 3/8 of an inch above the full mark. Next time, I will ask them to fill it to roughly half way between the add and full marks and I will take care of filling it the rest of the way. I used to change my own oil for many years in both cars but after moving to Michigan with the cold weather part of the year I started going to the dealerships for oil changes. This really has me considering going back to doing it myself. BTW, while there are many reports of overfills in the Gen II causing an MPG drop, I have not observed any drop in MPGs. Maybe with the larger engine and subsequent larger oil reservoir, there is more of a buffer where MPGs are not impacted. I worked at a full service station in the early 80s and did MANY oil changes and can't figure out for the life of me why this is so hard for so many.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    One word IDIOTS :p
    Mike
  13. Mike500
    Mike500 Senior Member
    2,593
    767
    Over the past 45 years that I've owned cars, I have never had an oil changed by a dealer. I've always done every one myself.
    Now that I will get two free oil changes at the dealer for my new Prius v, I'll let them do the two.
    First, I'll change the oil myself at about 3k to get the asembly lube and "crap" out of the engine.
    Before I change it, I will mark the filter cap withpaint alignment marks in the factory tightened position, before remove it. This will give me the correct "angular torqued" tightened position. All I'll have to do it to tightened it back to align the marks together, and I will get it back to correct tightness without a torque wrench. I'll use the Assenmacher TOY640 cap wrench that I have already purchased from Amazon.com.
    Although I have many specialty tools and some way beyond what some dealers have included precision aierospace service torque wrenches and special sockets, using my method, you'd need no more than even an 8 inch adjustable "crescent" wrench to loosen or tighten the oil filter cap.
    Then, when I have the oil change done by the dealer, I can raise the car up on ramps, open the oil service door and see if the dealer changed the filter.
    More likely than not, the "monkey" at the dealer will either not tighten the cap enough or too much.
  14. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yet you had your dealer change the oil for you?
  15. rsgillmd
    rsgillmd Junior Member
    38
    Memphis, TN
    While I have never changed my own oil, I have seen it done and it seems easy enough.
    However, I have the dealer change my oil for two reasons:
    1) I live in an apartment complex that very clearly states I am not allowed to service my vehicle in the parking lot.
    2) More importantly, I have no clue where to take the drained oil for disposal.
    Can someone here address point 2? What do you guys do? Should I just Google oil disposal for my local area?
  16. WE0H
    WE0H Senior Member
    3,247
    528
    Google would work but I believe any retail store that sells oil has to have a program in place to take in used oil for recycling and not charge for taking it. Around here there are so many shops and other places that use used oil for heating and beg people for their used oil.
    Mike
  17. bisco
    52,855
    my local gas station always adds the 'recommended amount' to my gen II which brings it about 1/4 - 3/8 over the full mark. i have never noticed any adverse effects and my mpg's are consistently between 55 and 65 depending on the season.
  18. seb33
    seb33 Junior Member
    53
    Toronto
    I found out yesterday that my dealer has been putting regular oil in my car for the last four oil changes, despite my insistence EACH time I come in, that I get synthetic. I didn't realize my car takes synthetic oil but on the first oil change back in July 2010, they told me that. I wasn't happy about the $20 surcharge for the synthetic oil over the cost of a regular oil change but accepted that it is best for my car, and that is why I always insisted on it. Yesterday, the service manager checked my records and said that, aside from that first time, I have never had synthetic oil. And he told me that now the additional cost over a regular oil change is $60. I am livid that
    a) they don't KNOW that my car requires synthetic - the are the supposed experts on my car (as opposed to Costco or speedy oil change outfits)
    b) I specifically asked for it, and they ignored my request
    c) the last oil change, I was charged for synthetic, but they readily admit they didn't put it in
    d) they have the nerve to charge a $60 surcharge for synthetic now, when I can walk right over to their parts department and purchase it for $28 (a 1L jug sells for $6.85...and they told me I need about 4 L)
    I called Toyota Canada to complain about these shoddy and fraudulent business practices...and they suggest that I go back there today for my 48K maintenance and speak to the service manager....I feel like they are sending me back to crooks!!
  19. WE0H
    WE0H Senior Member
    3,247
    528
    No way I'd go back to that dealer. Find another or a oil change shop that will do it right every time.
    Mike
  20. TruSound
    TruSound Member
    246
    32
    The 818
    I'd be willing to bet...most requests for synthetic oil fall on deaf ears, even when the stealers get caught red handed, what happens...NOTHING. A dealerships service department is the most profitable department, and for one reason...most people have no clue when it comes to car service, they get lied to, cheated on and basically raped, with little or no recourse.
