Dealer Recommends Flushing Brake Fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Susan4ET, Aug 19, 2019.
  1. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    For the record, the container (the master cylinder reservoir) is not sealed. It's vented to allow for changes in fluid level.
    A good way to judge the condition of brake fluid is to visually inspect the master cylinder, and use beer as your guide:
    If it looks like Budweiser, it's good.
    If it looks like an amber/IPA it needs to be changed.
    If it looks like Guinness, it's way overdue for a change.
  2. Mendel Leisk
    42,364
    There is a Warranty Extension Program for the brake booster; it's not necessarily brake fluid deterioration. Check with Toyota USA, your dealership or whatever. In Canada it's SOLH-W31-1A, issued August 2018. Check sooner than later, there are a couple of cut-off dates/miles.
    Hmm, seems like it survived ok. But, I wonder, would they have known about the chicken dance, to put the car in "invalid mode", prior to draining any fluid? It's explained in the attachment I posted earlier, and @NutzAboutBolts demonstrates it (better) in his video (in thread pinned at top of 3rd gen maintenance forum).
    #22 Mendel Leisk, Aug 20, 2019
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    But Guinness is soo good though, how can you throw that out?:( :LOL:
  4. Mendel Leisk
    42,364
    Raytheeagle and Grit like this.
  5. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I'll get it flushed next inspection. Toyota in Torrance pointed out that dealers are independent and things like brake fluid get inspected and the mechanic determines a fluid level just needs to be refreshed or flushed based on what cars experience in the areas they are driven in over time. I'm all for preventive maintenance. Good for the body; good for the mind; good for the car; but at some point you are going to run out. Thanks...
    BTW, 1. I'm _glad_ I didn't end up getting a Prime--heads up display and price was my problem. Found a nice cell phone holder that fits on top of dash displaying just above steering wheel and below windshield view. Use Waze to navigate including posted speed limits. Use without taking eyes off road. 2. Floor mat company advertises cup holder to mount cell phone on--bad idea--takes eyes off road--should be outlawed. Imo.
    End of thread. Have a beer if you need one.
    #25 Susan4ET, Aug 20, 2019
    bisco, Ed Beaty and jb in NE like this.
  6. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    link?
  7. frodoz737
    frodoz737 Top Wrench
    4,810
    2,562
    33
    ...on a side note.
    Did full service on my Son's 2018 Tacoma OR last week at 32K miles. Both diffs, xfer case, auto trans, PS, full brakes, oil/filter, dry filters, lubes, alignment, rotate (5 wheel) and balance, wiper blades...and guess what...some of that wasn't scheduled in the manual either.
    Raytheeagle likes this.
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Wallet flush?
    Fostel and bisco like this.
  9. frodoz737
    4,810
    2,562
    33
    Not when you do most of it yourself. ;)
  10. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    What lubes are on that vehicle? Are there any grease fitting on any new vehicles other than commercial trucks?
  11. frodoz737
    4,810
    2,562
    33
    factory front drive shaft U-joints, aftermarket upper control arms, aftermarket rear leaf springs
    jb in NE likes this.
  12. fuzzy1
    10,720
    Most parents don't flush their children's wallets. If anything, they do the opposite, either in cash or in free parts and labor.
  13. frodoz737
    4,810
    2,562
    33
    Yep...just like most of our parents. ;)
    Raytheeagle and fuzzy1 like this.
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    All I can add, is that I recently passed the 3 year mark with my Honda Fit, and the owners manual DOES recommend changing the brake fluid every 3 years.
    This last routine maintenance go round, I had them flush and change the brake fluid.
    Was it strictly necessary?
    I speculate probably not. But it really wasn't that expensive, so I had them do it anyway.
  15. frodoz737
    4,810
    2,562
    33
    That's why it's called preventative maintenance. Speaking of which...time for me to shower up and go to work...and get dirty again.
    ASRDogman likes this.
  16. bisco
    52,878
    2012, 65k, same old brake fluid :oops:
  17. frodoz737
    4,810
    2,562
    33
    1958 Model...and way to many miles here. ;)
    But then, the Wife doesn't trade me in because see hates the newer models. :ROFLMAO:
  18. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    It is best to flush the brake fluid every 2 years.
    The reservoir is vented, it is exposed to air, air has moister.
    Moister is not good for brake system.
    You don't NEED to change the oil, just leave that oil in the engine. :)
  19. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    iOttie Easy One Touch 4. 8 52306 00675 6. (Best Buy)
    StarCaller likes this.
  20. johnHRP
    johnHRP Active Member
    646
    191
    KA, DE
    Excel
    I shared about the test that someone did in his Prius 100k miles/10 years. The moisture is still way too low to be considered as a replacement needed. The strip test also shows really good additives condition, no burn, and enough antioxidant/corrosion. 100K maint - 1
    Just get a $5 brake fluid tester, they are cheap and accurate for our purpose 1% tolerance. I had not replaced the brake fluid in the past 70k miles/6 years. It is still less than 1% water content and color-wise, they are the same as new fluid. Amber color. Probably I will replace it on the 10th birthday in hybrid. In non-hybrid, I usually replace it at about 5-7 years but I always have Toyota, Honda, and Nissan. At about 6 years, 80k miles, my Nissan brake fluid failed the strip test, and the anti-corrosion additives are depleted. Too high copper content.
