Dealer says spiral cable, but all steering buttons work except horn
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Cody83, Jan 5, 2020.
  1. Cody83
    Cody83 New Member
    as the title says, we took the 2011 prius into the dealer and they told us it was the clockspring (spiral cable)... the symptom is only the horns to not work, not by pressing the steering wheel or the panic button. every thread i've read about the spiral cable says the panic button still triggers the horns which leads me to believe its not the spiral cable (also all of the other steering wheel buttons work just fine and there are no airbag codes being thrown) the dealers mechanic is just going with the most likely cause and not actually diagnosing this specific car or is it actually the 1k fix of a spiral cable to have a horn on the prius?
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    Test the horn by putting a live wire directly on it
  3. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    I would go to a dealership with techstream, it has a feature to let you know if the actual driver steeling wheel is no longer working when you press your palm against it.
  4. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    And check the fuse for the horn.
    Pluggo likes this.
  5. Pluggo
    Pluggo Senior Member
    608
    533
    Folsom, Pennsylvania
    Right. Check the fuse for yourself. If you're 100% sure it's good, then, connect a meter to the horn wires at the horn and watch for voltage when you press the horn button. After that, you can be certain there is a broken wire.
  6. Cody83
    Cody83 New Member
    If you go look at your prius if you have a Gen3, the fuse and relay locations labeled horn on the box map are completely empty... the horn fuse/relay is actually located in a white multi-relay in the fusebox I have tried like hell to get it out but I feel like i'm going to break it everytime I do... I have already tested the two horns via direct wire, nothing is wrong with them.
  7. Chrismich
    Chrismich New Member
    Louisiana
    Spiral cable. My daughters car started with the cruise going out then the radio button and eventually the horn. Changed the spiral cable and all works.
