Dealer says steel rims not strong enough?
Discussion in 'Gen 3 Prius Main Forum' started by CGYPrius, Nov 7, 2009.
  1. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    If you live where you need snow tires, the cold alone will cost you 3 to 5 mpg.
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Are You Strong Enough to be my Rim?
    Sorry, but I don't buy it. If we are talking strength of rims and Prius weight then The Prius is actually one of the lighter vehicles in Toyotas lineup. I think only The Yaris and The Corolla are lighter.
    Do not take my opinion as definitive answer, but it sounds more like a dealer trying to upsell you on some rims.
    I agree with others that say Toyota wouldn't provide rims that can't support the vehicles to which they are assigned.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed. Between winter blend fuels and 30-50deg winter temps I drop about 6mpg and I don't even have snow or snow tires. lol
  4. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    are you so cheap that losing $20+- in gas a winter season is going to make a difference?
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Actually at the moment I am. Some of us get hit with unexpected situations from time to time smart guy.
  6. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    The Prius' donut spare wheel is steel.
    The wheels on the larger and heavier base Camry are steel, as are the wheels of the base models of other larger and heavier cars.
    While alloys are stronger than steel pound for pound, I suspect that for most model cars that have steel wheels on their base models, that those steel wheels are stronger than the alloys on their higher line models.
    It has been my anecdotal experience driving over the pot holed streets of New York City the past 35 years that as a general matter, steel wheels are stronger and much more resistant to dents than alloys.
  7. dogfriend
    7,512
    1,190
    Carmichael, CA
    From a materials viewpoint, steel has higher [ame=http://en.wikipedia.org/wiki/Fracture_Toughness]Fracture toughness - Wikipedia, the free encyclopedia[/ame] than aluminum alloy. Fracture toughness is a measure of the ability to absorb energy without causing a fracture in the material. So a steel wheel may be able to absorb more energy from a pothole than an aluminum alloy wheel. But, again, it is also a factor of the overall design of the wheel.
    2 people like this.
  8. hill
    8,793
    No kidding. Remember when powerfull sports cars used to run steel SPOKE rims? I'm reminded of a W.C. Fields quote, suddenly.
  9. bac
    bac Active Member
    863
    52
    Pennsylvania
    Your dealer is either totally incompetent or completely disingenuous. Either way, I’d run for the hills, or at least to another dealer.
    -Brad
  10. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    It is totally BS. NASCAR only allow steel rims for the race cars. What does it tell you?
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    They have no fashion sense? :)
    Tom
  12. CGYPrius
    CGYPrius New Member
    Alberta
    I appreciate everyone's input. I did some checking around and I have three dealerships telling me that there is no Toyota steel rim available for the 2010 Prius. I called two other dealerships further away from my City, and they are selling tire and steel rim packages, and they say they are Toyota steel rims. I questioned them as to why other dealerships are saying they don't have steel rims, and they aren't able to confirm why. One dealership told me that the steel rims are from the base model of the Prius, and yes, I questioned him on what base model that was, as I didn't think there was a steel rim even on the base model. This is bizarre! :confused:
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Perhaps the Prius model I has steels rims?
  14. Jim05
    Jim05 Occasional Quasi-Hypermiler
    115
    Culpeper
    Give TireRack a try. You can put together a package for ~$600, although that won't come with sensors. You might also be able to get a decent deal at a local tire dealer. Sensors at TR are $356, and probably won't be much different at a local shop. I don't know if there are better deals out there, but I've always had good luck with TR. Only other option (not the greatest, but cheaper) would be to swap winter tires on your current wheels. hope this helps a bit.
  15. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Nothing actually, but they dont run Hybrids either.
    Nor do I ever remember a Nascar event held in a Blizzard!!!
    Or PINK paint schemes!!!
    What does that tell you!!!
  16. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I'm no NASCAR fan, but perhaps this is why? Not potholes, but maybe a cast wheel would be more likely to come apart when they start playing bumper cars?
  17. dogfriend
    7,512
    1,190
    Carmichael, CA
    I don't know their reasoning, but it would be true that an aluminum alloy wheel would be more likely to turn to shrapnel while a steel wheel might be bent but less likely to fly apart.
    I would also add that fracture toughness is the reason that they don't design wheels out of concrete or glass. :madgrin:
  18. Boo
    5,051
    488
    97
    Flushing, NY
    I don't know what that one dealership was talking about (maybe he doesn't know as well?).
    In the US at least, no generation or model of Prius has ever had steel rims (except the donut spare). Gen I, Gen II, Gen III, base, standard, Touring Edition, option packages, no option packages -- doesn't matter, they all came with alloy wheels.
  19. bedrock8x
    1,483
    137
    One of the reason is when there is a flat and lost the tire, the steel rim will keep the car running to go back to the pit stop. An aluminum rim will burnt up in no time and starts a fire.
    The point here is that the steel rims are strong enough for the cornering stress put on the rims running at 200+mph, so the argument that a steel rim is not strong enough for the Prius to run snow tires at highway speed is pure fiction.
  20. PriusDreamer
    PriusDreamer Member
    138
    Long Island, NY
    Steel wheels can be and are just as strong (or stronger in some instances) than aluminum. they can more easily be banged back into shape, rather than replaced, if you bend them. They are definitley heavier pound for pound to attain the same strength of aluminum rims. Let's go back to the weight issue. A four pound per wheel additional weight is equivalent to approximately forty pounds in the car. This is generally refered to as unsprung weight. That being said, other than a small mileage loss and some extra wear and tear on the brake and suspension components (due the the weight being on the wheel as opposed to in the car) there is little downside or risk to using steel wheels of the correct size and wheel offset.
