Dealer wants $4500 for brake repair.... WHAT?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by HeinzCatSoup, Nov 1, 2013.
  1. Mr.Electric
    Mr.Electric Member
    287
    105
    San Francisco
    There is a nitrogen filled pressure accumulator on many cars. It saves brake pressure for later use. The nitrogen gets compressed like a spring when pressure is stored. The nitrogen leaked out and filled the brake fluid with bubbles on some 2010's.
    I think you could get it fixed free if you complain loud enough. It is a known issue. You not in the production range they earmarked for the recall. They probably installed the bad part on your car at the factory on a date not know to be subject to the defective part use in assembly. There is a way to tell if you have the new or old part in your car by looking at the orientation of the sticker on the accumulator.
    Turn off signatures in Tapatalk Tapatalk
  2. El Dobro
    El Dobro A Member
    7,086
    3,263
    I wouldn't give in just yet. Go around the dealer and get hold of Toyota. Who knows, the recall may have to extend past the original recall build dates.
  3. ETC(SS)
    7,131
    See that little light?
    It's called the "change dealer" light.
    I would immediately get a second opinion from a independent shop.
    $4500 for brakes is beyond stupid.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    can you provide a link or more details on this recall? i had a 2010 Prius (build date april 2009) that rear ended a car.
  5. El Dobro
    El Dobro A Member
    7,086
    3,263
    Try your VIN here and see if anything comes up.
    Toyota Safety Recall and Car Service Information
    jdcollins5 likes this.
  6. HeinzCatSoup
    HeinzCatSoup Junior Member
    Southern California
    General consensus at the dealer seems to be that these parts should not break with 90,000 miles, but they can't do anything about it and to bring it up with Toyota.
    Spent an hour talking to Toyota HQ, they passed me around to 3 people only to tell me that its not covered under the recall, and that they'll have the "case manager" call me monday or tuesday.
    In the meantime I went to pick up my car from Toyota and drove it home (i live 2 miles away). Anyone know the cost of the Brake Booster & Master Cylinder? I actually have a dealer license and can get 15% off with no tax of dealer parts, but I'm wondering if theres anywhere I can get it cheaper than Toyota.
  7. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Unfortunately this is a complex braking system and only Toyota is going to have these parts.
  8. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    The case manager will most likely grant a one time exception and give you the parts for free and you will have to pay labor.
    Be patient. That is why they assigned a case manager who will contact you and make arrangements to comp this repair after inspection
  9. Former Member 68813
    3,524
    983
    US
  10. JMD
    3,779
    1,282
    Don't file a case until you hear from Toyota. They will most likely compensate your parts. Wait to hear from them before you file a complaint.
  11. Former Member 68813
    3,524
    983
    US
    He needs to file with NHTSA regardless what Toyota does. This is a major safety issue and he or someone else could have been killed. Feds need to know about it and it should be fixed in all 2010 Prius ASAP.
  12. HeinzCatSoup
    Southern California
    I almost hit 4 cars trying to go from the very left lane to safely exit with no brakes. luckily it wasn't heavy traffic and everyone got out of the way safely.
  13. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    That sounds scarey. Especially given the traffic in SoCal. How did you get stopped?
  14. JMD
    3,779
    1,282
    I'm not saying don't file. Just file after Toyota replaces your brakes which will happen if it is assigned to the field. Once you file Toyota will not give you brakes and lawyer up.
  15. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I lost my brake master cylinder earlier this year (see my thread, "The $3000 Brake Job") at 50K miles. I drove it a few days with all the alarms screaming until I could get it into a dealership for diagnosis.
    After about two months' effort, I got half the cost back from Toyota. The dealer service manager did a lot to get that amount. I was an original owner, and I had quite a bit of hassle proving that the car had been well-maintained. I've lost almost all of the faith I had in Toyota products - I certainly don't suggest it to others any more as I once did. I reported mine to the NTHSA.
    My experience suggests that it will be some time for Toyota to come up with some reimbursement for your repairs, and it probably won't be the whole amount if you're lucky enough to get anything.
  16. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    If you have not called Toyota Customer Relations to open a file with them- do that first. This is absolutely unwarranted for a call only three years old with less than 100K miles on it. I do not care how the car was driven, how do you wear out a brake booster, etc. My '05 had 190K miles on it when I sold it and was still on the original brakes with out a single issue.
    Merkey and JMD like this.
  17. Former Member 68813
    3,524
    983
    US
    Sorry, but you have no clue how NHTSA works and should not give advices when you don't know what you are talking about.
    Public NHTSA database doesn't include any personal information. The name, VIN, etc is for internal NHTSA use.
  18. Mendel Leisk
    41,282
    I've had a similar experience in past, with Honda. There seems to be an abysmal shift in the corporate culture: nobody gives a damn about keeping customers. Guess it's "get my golden handshake and get out" that rules.
  19. Former Member 68813
    3,524
    983
    US
    I don't blame you. It's one thing to have tons of cosmetic issues (like the squeaks, noises, rattles, cracks I'm having in mine) and another thing to have a life threatening failure. It's disappointing to hear about these problems, even if they are rare, especially since gen 2 didn't have them. Another thing that keeps me concerned are the battery issues in taxi service overseas. I'm driving almost 100% city and thus similar to taxis in Europe.
    Prius is my 3rd Toyota. The previous ones were not as trouble free like as I would like. So far, my Prius is a reliable car, but if battery, inverter, or brakes fail on it, my opinion will change 180 degrees.
  20. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Mine has the same squeaks, rattles and creaks that my 2010 Prius had. It's as if I it had the same interior transplanted into the PIP. I do a lot of city driving and hope the Li-on battery is a step up in that department, but only time will tell.
    Years ago I had a '76 Celica GT 5-spd manual that was absolutely free of any defects or problems after 60k miles. Since then I haven't had one car that hasn't had issues of some sort. Nothing dangerous or life threatening, but issues none the less. I guess we're supposed to accept that as fact and move along.
