Dealership charging me $3800 + tax to replace a bad actuator on my 07. Is the repair worth it?
Discussion in 'Gen 2 Prius Main Forum' started by CarOwner, Jan 7, 2021.
  1. ChapmanF
    18,224
    Um, no, I wrote "once that power fails", and the antecedent of that was "box of capacitors in back next to the 12 volt battery, just to supply emergency power to the brakes".
    Because of the way Gen 2 brakes work (and this is different from both Gen 1 before it and Gen 3 after it), if the electrical power fails you are without power assist even if there is still some pressure in the accumulator. That's why Gen 2, and only Gen 2, has that extra box of capacitors in back.
    As for the actuator failing, it's worth keeping in mind that it's a complicated box with around a dozen different valves in it, half a dozen pressure sensors and (in Gen 2) even the accumulator and pump integrated into it. That means there isn't much sense in just talking about "the actuator failing"; there are dozens of different ways it might fail, and what each different way of failing would do to your braking experience would have to be pieced together by squinting at the diagrams in the New Car Features manual (more info).
    CarOwner likes this.
  2. CarOwner
    CarOwner New Member
    16
    I just took a peek at my brake fluid container. The fluid looks "great" from my (mostly ignorant) point of view. No discoloration, and it's filled to the max. Though again, I'm ignorant, so I'm not even sure one would be able to discern the quality of brake fluid simply by looking at it.
    If you can discern the quality by looking and it looks fine, I'd much rather avoid having it changed, obviously.
    As an aside, this car was a hand-me-down and I'm not sure if the brake fluid was ever changed. If it was, I don't know if it was changed by a certified dealer (apparently dot 3 fluid is supposed to be blue... and mine is yellow?).
    Here's a pic of the brake fluid container for reference.
    #22 CarOwner, Jan 9, 2021
  3. ChapmanF
    18,224
    It's easier to tell fluid condition with a test strip.
    Mine at 145,000:
    Earlier reported test at 110,000 by hobbit:
    The fluid in the reservoir isn't where you would usually test, because a brake system doesn't really circulate: the lines out to the brakes at the four wheels are dead ends, and the fluid is stuck there. It might be better to crack one of the bleed screws open and let out enough to dip a strip in (while not letting any air in), because that's how you'll be testing the fluid that's in the brake and exposed to the greatest heat.
    On the other hand, the fluid in the reservoir has been circulating through the accumulator and pump and portions of the actuator, so maybe it does tell you something about the conditions there.
    Sanchan, SFO and CarOwner like this.
  4. PriusCamper
    PriusCamper Senior Member
    12,774
    5,175
    Pacific Northwest, USA
    Perhaps hold off on changing the fluid until you actually replace the accumulator as it's easier to get all that work at once and your situation isn't going to change much with new fluid.
    Rph74 and CarOwner like this.
  5. Aegean
    Aegean Active Member
    463
    208
    Alexandria VA
    The fluid looks ok on the photo. Maybe it has been changed at least once since car was new. I usually change the brake fluid myself using Techstream every 30k mi. On the hybrids that have an expensive regenerative brake system it’s a good insurance.
    CarOwner and PriusCamper like this.
  6. CarOwner
    CarOwner New Member
    16
    Guess I'm going to hold off on changing the brake fluid. I don't do all that much driving these days anyway due to COVID. Just local driving mostly.
  7. MilkyWay
    MilkyWay Active Member
    823
    359
    23
    MI
    Just popping in didn't read previous comments....But....the time to replace is when it kicks on the ABS/VSC/Brake light and has brake actuator codes....Is this the case?
    Reason so high is because part is really expensive OEM new.
    You can go to car-part.com and select ABS pump and pick the first one (they all fit the same way --- try to get the 2009 updated version but not big deal getting older one).
    You'll sometimes find them for $250 used....usually more like $300..
    My mechanic does it in 2 hours so I'm assuming not a very labor-intensive job....You should be able to knock the job out for about $600-$700 I would imagine.
    And from my experience doing about 7 of these --- we only have changed them when we get the brake actuator codes on scanner.
  8. MilkyWay
    823
    359
    23
    MI
    This is not how it happens.
    If you ignore it you'll stop just fine but you'll have lights on the dash....Eventually (I've driven one with a very bad actuator once) the pedal will be very stiff....It will still stop and you can still do an emergency drive or 2...You just have to be a little more cautious and give yourself time to stop because the pedal is stiff....still will stop, just not the way it was intended to lol.
    To clarify, I've driven around 10 with bad actuators and actuator codes: ZERO DIFFERENCE! Stops just fine and dandy....I guess you can say I did an experiment and kept driving one until it got really bad. That one eventually got a very stiff pedal and I was no longer comfortable driving it.
    No brakes (when they go all the way to the floor) is a much more terrifying drive vs. the stiff pedal bad actuator. Which again, gradually worsens (which you would be prepared and expect as you'd have tons of lights on the dash). It doesn't just explode out of nowhere when you are on the freeway.
  9. CarOwner
    CarOwner New Member
    16
    Thank you. That does make me feel more confident about the situation.
    PriusCamper likes this.
  10. ViH
    ViH Junior Member
    Hey @CarOwner -- did you ever resolve the actuator problem? I have the same problem, and it appears you researched it quite a bit so am curious to know how it turned out.
    Sanchan likes this.
  11. ViH
    ViH Junior Member
    I went ahead and got a used actuator from enet auto parts for $265. I installed the part following steps in the factory service manual and it went pretty well except that I misplaced one of the nuts (12mm wrench size nut with a free spinning captive washer) that is used to fasten the gusset in place. I am not able to find the part number for it -- does anybody know what the part number is (see pics)
    MilkyWay likes this.
  12. ViH
    ViH Junior Member
    I was able to find the part number with the help of the parts guy at a dealership. In case anybody else is looking, it is 90182-08008 ($2.01). Two nuts and a bolt (91635-80820) are required. It had to be special ordered and takes a week so I substituted an M8x1.25 (coarse) flange nut and washer that I got from the local hardware store. Downside is that the substitute requires a 13mm wrench (original needs a 12mm wrench).
  13. Soylent
    Soylent The v isn't a station wagon! It's just big boned
    443
    Fort Lauderdale, Florida
    2013 Prius v wagon
  14. Adan x
    Adan x New Member
    San bernardino
    I put a used one in and so far lasted a couple years. I did get a code but the dash lights did not come back from last time. I payed a few hundred at a mom and pop shop and bought my actuator off eBay. I am not sure how much new ones run but If you can afford it go ahead. he used ones will probably go bad as I don't recommend getting it done at the stealership. There are plenty of small places that work on hybrids
