Dealership Repair Help
Discussion in 'Generation 1 Prius Discussion' started by Reincarnation Bicycle, Jan 21, 2018.
  1. Reincarnation Bicycle
    Ravenna, Ohio
    2002 Prius
    I just spent $1,500 on the 2002 Toyota Prius that I drive on a Front Exhaust Pipe Assembly. They are now saying that the "Cap" on it need to be replaced this is also called the Exhaust Actuator Vacuum ($230.72).
    It's the last thing I need to get fixed so the engine light will go off.
    Can I get the part cheaper from somewhere else? My friend suggested either going to a junkyard or buying a part from NTB.....???
  2. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Try a muffler shop
  3. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    You could also get one from a junkyard if you check wm out
    51,139
    welcome! eBay?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Brian in Tucson and WHCSC like this.
