dear members i just purchased this car i have seen some caution code on it can somebody advise
Discussion in 'Gen 4 Prius Technical Discussion' started by muhammad jahangir, Jun 5, 2018.
  1. muhammad jahangir
    muhammad jahangir New Member
    pakistan
    yes car was in auction hit from back
    yes car was in auction hit from back slight bumper damaged.
    #21 muhammad jahangir, Jun 8, 2018
    51,947
    see post #8.
  3. Al Bundy
    Al Bundy Member
    140
    69
    florida
    flood car that is hydro-locked? could the rear impact force fuel from the gas tank into the crankcase like a lawn mower with a stuck float?
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,813
    So. Texas
    :LOL::LOL::LOL:
    Did Kelly Bundy take over your account?
  5. fotomoto
    5,638
    3,813
    So. Texas
    Check negative (ground) battery lead at ground location at the back of the car.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Check the orange safety plug is not pulled out on the HV battery.
    fotomoto likes this.
  7. fotomoto
    5,638
    3,813
    So. Texas
    And if it is out, three steps: push in, flip up, push down.
    kithmo likes this.
  8. bisco
    51,947
    check the 12v health.
  9. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    what a Bastard thing to do, selling a fairly new Prius with so many problems.
    To start I would say it is still under warranty, but I don't know if that applies in Pakistan. If the dealer is too far, that could be another problem. So, you must fix it yourself or find a exceptional Hybrid Mechanic.
    What the previous comment or might have said is: many problems can and do occur when the oil is overfilled.
    So your first job is to drain the oil out of the engine, save it, you MAY be able to reuse it. Then check the air filter, if you think it's dirty, change it. Absolutely change the oil filter. Just this will keep you busy over the weekend. Also the air throat is probably saturated with oil, all the oil must be cleaned out with clean rags and the sensor in the center of the throat. This is called the air mass sensor, it's delicate, so be careful. There should be NO OIL OR RESIDUE IN,ON THE WALLS, FLOOR OF THE AIR THROAT.
    Just curious, how many miles on it? And, what did you pay for it?
    I'm going to look at the other pics and Im sure many members will give you more support
    Try to find history of car.
    you think he understands "taking the Mick"
    #29 Andyprius1, Jun 8, 2018
    RCO likes this.
  10. bisco
    51,947
    auction
  11. Andyprius1
    2,327
    859
    Cool CA
    Thats funny, while Im writing one long reply 12 others show up.
    RCO likes this.
  12. bisco
    51,947
    that's priuschat for you.:whistle:
    RCO likes this.
  13. Andyprius1
    2,327
    859
    Cool CA
    Yes, I saw that, if you can't test a car first, don't buy it.
  14. bisco
    51,947
    that's a motto i live by.
  15. Andyprius1
    2,327
    859
    Cool CA
    Get as many numerical trouble codes as you can and then our Geniuses will translate them into useable information. Engine oil pressure shortage, sounds bad.
    If you get oil pressure and mechanical moving engine parts MOVE OK, then rebooting at a good 12 V Bat plus rebooting at Power Switch at least twice. If at this point you get a ready light, your good to go.
    Don’t own a 2016, so I can’t say.
    I agree, it must be mechanically sound first.
    #35 Andyprius1, Jun 8, 2018
