Death Rattle...Not on Start-Up
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Chuck_Roberts, Jun 20, 2022.
  1. Chuck_Roberts
    Chuck_Roberts New Member
    Goodyear, AZ
    We have a 2013 Prius C with 258K miles with a death-rattle. This does not occur on start-up, and we are not losing coolant and there is no water in the oil, so I expect that rules out a leaking head gasket.
    While downloading codes, B1503, Exhaust Heat Management Warning seemed to be the only code that might be related to this condition (others include AC Air Duct damper control, TPMS, and an old Turn-signal and Brake light code). The Engine Coolant Temperature Sensor is on order.
    I did insert a putty blade between the EGR and its Cooler to check for a clogged EGR system, but it still started the death rattle after warmed up.
    I checked/swapped the #1 and #4 Plugs and Coils after a download finally kicked out a #1 Misfire, but that did not change it’s condition.
    Of note, the death rattle seems to display after the engine in warm, and low power situations. Accelerating, or higher speeds stops the condition. I will replace the Engine Coolant Temperature Sensor but am doubtful that it could cause this condition. Any other suggestions I might be missing?
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    "death rattle" sounds very dramatic... Can you describe it in more detail? Are you sure you aren't just referring to the nature of a normal atkinson engine that has slightly rough running on shut down?
  3. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    You will need to provide more details, if the head gasket were to be blown, there would be coolant in the oil. Maybe you can proved a video of the engine running.
  4. Chuck_Roberts
    Goodyear, AZ
    The "death rattle" IS very dramatic...shaking and knocking terribly at low power settings once warm...not on start-up. I'll expect to work on it again today, so I'll try to get some video if it repeats after I change the coolant temperature sensor. . It's not just on shut-down. There is no coolant loss, or coolant in the engine oil. I think something is telling the computer to significantly change the air/fuel mixture. That's why I tested the EGR, and I read that the coolant temperature sensor does this too if it fails to properly detect the coolant temperature, but if I can get a video for you, you'll swear it must be something much more dramatic than a little little fuel trim fault. I'll follow up. Thanks for your time.
  5. PriusCamper
    13,465
    5,431
    Check out the youtube videos for blown headgasket on Gen3 Prius. I suspect you'll see the same symptoms in those vehicles.
  6. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    I have been reminded more than once that minor ignition misfires tend to feel far worse in a Prius.
    Check/replace spark plugs? Be sure to use genuine parts from a trusted local source. Amazon & eBay have been overrun with counterfeits.
    PriusCamper likes this.
  7. Chuck_Roberts
    Goodyear, AZ
    Well, I changed out the Engine Coolant Temperature sensor, but the B1503, Exhaust Heat Management Warning code still exists. My diagnostic downloading tool now suggests a wiring problem in that circuit.
    On the videos, I saved a MP4 video of a normal (cold) start, one as it transitions to the rattle, and another warm start with all kinds of racket. I tried to upload the MP4 files on this post, but couldn't link to these. Suggestions?
  8. Chuck_Roberts
    Goodyear, AZ
    Leadfoot, thanks for the feedback, I just saw your reply. I'll try some some new plugs tomorrow.
    I'm just trying to come to terms with such severe shaking that only occurs when warm. I would think the head gasket would leak more when cold, but I'm starting to believe you might be right....
  9. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    It is worth remembering that while head gasket failure is strongly associated with the 1.8L 2ZR-FXE engine, the same is not true for the 1.5L 1NZ-FXE in the Prius c or gen 1 & 2 Prius.
    I'd keep looking for traditional sources of the misfires: plugs, vac leak, metering error (induction or o2).
  10. Chuck_Roberts
    Goodyear, AZ
    Well, the new spark plugs didn't help. Pulling the cylinder head to check that, and the EGR system to see if it's clogged...
    When it started today, I could smell a bit of an exhaust smell from the engine area. We'll see...
    If the O2 sensor was bad, wouldn't it show up on the download?
  11. Leadfoot J. McCoalroller
    8,289
    7,802
    Pennsylvania
    2018 Prius c
    There are some failure modes of an O2 sensor that are extremely easy for the ECU to detect. Others not so much. I don't happen to know Toyota's official diagnostic procedure. On other, older cars I have trusted the ECU to tell me whether it was a simple short or open, but then it was usually a good idea to read the data or scope the signal to see what it was actually saying and if that made any sense for conditions.
  12. Chuck_Roberts
    Goodyear, AZ
    Problem solved!
    To follow-up, for the benefit of others...
    I did ohm checks on the fuel injectors and found that the cylinder #1 fuel injector was less than 1 ohm, where the others were around 12.6. I never did remove the cylinder head, as I just couldn’t see how it could be a bad head gasket when it ran good when cold, but terrible when warm, with no loss of antifreeze.
    Similarly however, I initially discounted the fuel injectors as a possible problem as it ran good when cold. Odd.
    And the terrible shaking, I heard referred to as a death rattle, was really being caused by 1 missing cylinder. Shocking.
    Of note, I sprayed out some carbon inside the EGR valve, but the EGR cooler was in good shape…no clogging at all. Not bad for 258K miles. I also replaced the spark plugs.
    After replacing the defective fuel injector, and dumping a can of Sea Foam in for good measure to clean up the other fuel injectors, my wife reports that the Prius runs great now.
    Until next time….and thanks for the suggestions!
    Sonic_TH likes this.
  13. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Good to know that the problem has been solved.
    I have never seen a fuel injector fail on a Prius.
    Talking about the EGR cooler, indeed, the Prius C is very well designed, it seems like it is more robust and reliable than the Gen 3 Prius from the same years, it does not has engine problems at all. Only thing is that the hybrid battery lasts less because the hybrid battery cooling fans do not turn on as much due to cabin noise, this causes the battery to get hot, unless you run the A/C on full blast, if you don't the hybrid battery cooling fan will barely spin at decent speed to cool.
  14. Chuck_Roberts
    Goodyear, AZ
    Well, 20,000 miles later, and I have a similar setback. P304 #4 cylinder misfire. I cleaned the injectors with brake cleaner, then swapped the #4 and #1 fuel injector, and also swapped the #4 and #2 coil, hoping the problem would move with the bad part, but it still says #4 misfire. I blocked the EGR, to isolate that, but it made no difference. The plugs are new from this Summer. When the engine was cold, the hard knocking would cycle in, then running great with no missing before another round, repeating that cycle. Once warm, you can hear the cylinder missing very often, which transitions to heavy knocking at times, then back to regular missing. I wondered about the Air Fuel Sensor or Mass Air Sensor messing with fuel trims, but that should affect all cylinders. No loss of coolant, and the oil looks good.
  15. ChapmanF
    19,025
    The classic three things to check are fuel, spark, and compression. Through your swapping of the coils and injectors, you seem to have checked the first two. (Plugs? Other than new this summer, how do they look now?)
    After that, what does a compression or leakdown test say?
  16. Kerrynzl
    Kerrynzl Member
    60
    28
    New Zealand
    2016 Aqua
    Glad to see you got this sorted
    Thanks for the follow up report on this.
    #16 Kerrynzl, Nov 18, 2022
  17. Chuck_Roberts
    Goodyear, AZ
    Well, I feel pretty silly, but I previously set the spark plug gaps way too tight. I re-adjusted the gaps, and the engine has been running smooth again. Really, it's surprising that it didn't provide any problems with the previous spark plug gap since they were replaced this Summer. Maybe the last tank of gas had quality issues? Thanks ChapmanF! I ordered a leak-down tester to have one one hand next time things are in doubt.
  18. ChapmanF
    19,025
    These plugs are (intended to be!) properly gapped out of the box, and not meant to be field-adjusted. Made of metals that may take less to bending.
