Debadged Rear End with Pictures
Discussion in 'Gen 3 Prius Accessories and Modifications' started by krisirk, Jun 28, 2009.
  1. krisirk
    krisirk Junior Member
    49
    24
    West Fargo, ND
    A while ago I posted about debadging my 2010 Prius IV and showed the holes that the two rear emblems left. Link to the thread
    I decided to remove the horizontal strip that the emblems and the Toyota logo were on and paint it glossy black. I hoped it would blend in nicely with the tinted lower rear glass.
    Here's some before, during, and after pics.
    Before (if it looks dirty, that's because it is):
    During, note the clip holes and the opening for the hatch release/lock:
    After:
    I think it turned out well. I like the blue peeking out behind the blacked out emblem.
    If you have any questions or comments, please post.
    Kris
    maurices, C.R.E.A.M., Young and 6 others like this.
  2. greylar
    greylar New Member
    283
    38
    Montana
    Very nice work. I like the look. How did you get the back panel off? I also did you remove any of the inside panels on the hatch? I would very much like to know how you did it so I can re-route my backup camera. I'm just a chicken and don't want to break anything.
    UR Gutsy BTW
    G
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Different...
  4. krisirk
    49
    24
    West Fargo, ND
    To remove the panel on the outside, you must remove a panel on the inside. The reason is that there's four bolts on the outside panel that go through to the inside.
    The panel on the inside is the lowest one on the hatch. There's an indentation that you can pry up on each side. I put a piece of folded up paper towel against the paint and pried each side up with a screwdriver. The panel is held on with yellow snap-in clips. You just need to pry hard enough to get them to snap out of their holes.
    Once each side is pried up I went around down along the bottom until I got to the latch. From there you should be able to see if there's any more clips to pry up.
    The outside panel is held on by a bunch of the snap-on clips as well as four bolts. Two of the bolts are in the center where the latch release/lock is located. The other two bolts are about halfway over on each side. Unclip the connector to the latch, remove the nuts holding the back on, and then pry up the clips by hand. Start at one side and work your way over prying up gently until you hear them release.
    If you'd like some pictures of the procedure let me know and I'll post them.
    Kris
  5. Flying White Dutchman
    4,374
    313
  6. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Almost makes the car look a bit wider to me since the white is now that much 'thinner'. Doesn't look bad at all IMO, but I'm not daring so I'll be leaving mine alone lol.
  7. greylar
    greylar New Member
    283
    38
    Montana
    Thanks for the info. I think I will try the wire re-route in a week or two. Again I have to say I really like the de-badged look and you did a really nice job on the paint. Do you have your own paint booth or did you have someone do it for you?
    G
  8. krisirk
    49
    24
    West Fargo, ND
    I've got a paint booth at my workplace. A guy I work with has done lots of painting of machinery. He has his own gun and did most everything for me on Saturday. However, I was the one who sanded the emblem. :D
    He used one coat of sealer to cover the filler and then three coats of paint. We waited 30-40 minutes between coats.
    As for your camera, the black plug where the factory camera is located comes off easily if you take the outer panel off. It's held in place by two tabs. It should not be too tough to put the camera there if that's your plan.
    Kris
    #8 krisirk, Jun 28, 2009
  9. RadioZero
    RadioZero Member
    154
    59
    Orlando
    2018 Prius
    nice work!
  10. exbauer
    exbauer Active Member
    1,185
    101
    Washington
    Looks great. I like debadged cars, too bad there are holes back there and so much work to fill them.
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i think the car looks awesome...almost makes me wish i had gotten the white instead. could nt see your option working on my blue spectra though
  12. patsparks
    10,664
    567
    Adelaide South Australia
    I love it, that looks awesome!
    I'd love to see a 3/4 from the rear shot taken from greater distance because the pic is taken so close, the angle isn't quite right.
    I also love the hybrid blue peeking out of the blacked out badge.
  13. krisirk
    49
    24
    West Fargo, ND
    Let me wash the car up and I'll try to take a pic tonight.
    Kris
  14. krisirk
    49
    24
    West Fargo, ND
    I think it might work for you too since the black just blends in with the lower rear window. Anyone good with Photoshop?
    Kris
  15. krisirk
    49
    24
    West Fargo, ND
    Here's a picture taken from farther away and zoomed in.
    Here's a one from each side.
    Thanks for the comments,
    Kris
  16. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Nice mod! I just hope your state does not have a loud license plate!
  17. greylar
    greylar New Member
    283
    38
    Montana
  18. krisirk
    49
    24
    West Fargo, ND
    They look pretty good with the Blizzard Pearl.
    Kris
    #18 krisirk, Jul 19, 2009
  19. Slovewell
    Slovewell New Member
    95
    Va
    So, what are you going to do with the wheels? I have the same wheels but I don't like the flat gray look. I would like to find some chrome ones that won't hurt my gas mileage. I have the dark blue 2010. Your mod on the back looks good.
  20. Mark57
    2,945
    2,737
    OK
    Kris, I think it looks great. I also like the accent of the blue on the Yota emblem shining through. Good job.
